Linux boot halted when the FPGA is power cycled and the programming cable is connected
We are using zynq ultrascale now.
We want to capture the wave during Linux boot process using JTAG calbe.
Linux boot halted on kernel loading when the FPGA is power cycled and the programming cable is connected.
The same problem did not occured on zynq platform.
Is there any more attention should be pay on zynq ultrascale platform?
Thanks in advance!
Any relplies are appreciated!
Hi @mage
Can you try  with disabling the cpu_idle i kernel configuration.
For reference see this link:https://www.xilinx.com/support/answers/69143.html
Thanks & Regards
Aravind
Could anyone help me?
Hi @mage
Thanks & Regards
Aravind
Thank you very much!
Your reply is very helpful to me!
