Linux crash when use axi_ethernetlite IP core
Hi guys,
   I'm trying to run a Linux system in a new custom board with Zynq XC7Z020, using u-boot-xlinx-master and linux-xlnx-xilinx-v2015.4(using xilinx_zynq_defconfig),I want to use the AXI Ethernetlite IP core support my eth1。The Xilinx_emaclite driver probe ok,but when i config the eth1,the system crashed.
The interrupt configure as follows:
The dts file about this Ethernet as follow:
              ethernet@40e00000 {
                     compatible = "xlnx,xps-ethernetlite-1.00.a";
                     device_type = "network";
                     interrupt-parent = <0x3>;
                     interrupts = <0x0 0x1d 0x1>;
                     reg = <0x40e00000 0x10000>;
                     xlnx,duplex = <0x1>;
                     xlnx,include-global-buffers = <0x1>;
                     xlnx,include-internal-loopback = <0x0>;
                     xlnx,include-mdio = <0x1>;
                     xlnx,rx-ping-pong = <0x1>;
                     xlnx,s-axi-id-width = <0x1>;
                     xlnx,tx-ping-pong = <0x1>;
                     xlnx,use-internal = <0x0>;
                     local-mac-address = [00 0a 35 00 00 00];
                     phy-handle = <0x6>;
                     mdio {
                            #address-cells = <0x1>;
                            #size-cells = <0x0>;
                            phy@1 {
                                   reg = <0x1>;
                                   linux,phandle = <0x6>;
                                   phandle = <0x6>;
The Xilinx_emaclite driver probe ok,the system dmesg :
xilinx_emaclite 40e00000.ethernet: Device Tree Probing
libphy: Xilinx Emaclite MDIO: probed
xilinx_emaclite 40e00000.ethernet: MAC address is now 00:12:ae:a7:7c:ce
xilinx_emaclite 40e00000.ethernet: Xilinx EmacLite at 0x40E00000 mapped to 0x608E0000, irq=167
But i can’t find eth1’s IRQ number in /proc/interrupts:
When I type : ifconfig eth1 192.168.1.10 up   The system crashed。I had to use the reset button or the power switch,to restart the system.
Thanks!
Re: Linux crash when use axi_ethernetlite IP core
By the way ,The phy chip is KSZ8041TL.
You won't see the interrupt in /proc/interrupts til after the ifconfig completes as the request_irq() is not called in the probe but in the open() function.
John
You need to put in any crash dump that happened as that's the key to understanding the issue. There is also debug in the driver so that turning on debug (command line, adding #define DEBUG in driver, etc...) might help also. Nothing obvious is jumping out at me as wrong in the device tree. Have you tried running with an older release as 2015.4 is really new.
Thanks for your replying. I have tried 2015.2 and zynq-dt-for-4.3-v2. They have same issue. The system crash,and terminal no response,so i had to push the reset button or the power switch to restart the system.
So it almost sounds like we don't know if it crashed but it's not responsive on the serial console such that it likely did or it's hung somehow.
Have you tried to ping it just be sure of that? I imagine your right, but sometimes I get surprised and chase the wrong problem.
Or telnet into the other EMAC as it looks like you might be using eth0 also.
I would add "debug" to the kernel command line in u-boot when it boots and then if nothing add #define DEBUG to the driver and see what you get.
John
