Linux demux mpeg ...
I would like to create a IPcore for implement "demux" mpeg style, for use with existing linux drivers.
Can someone show me a starting point ?
Is it possible to do this ?
secureasm.
in a big enought fpga with enough time, anything is possible,
start small, get a dev board from you local xilinx supplier,
    see what happens
Hi drjohnsmith,
> start small, get a dev board from you local xilinx supplier, see what happens
I can easily think big (not very big anyway) :smileyhappy:
I just have made simple demux (PID, transport ID, section ID), with my own code on Microblaze (Spartan 3A DSP), and work very well (without OS).
I buyed ML402 (Virtex4 SX35, low cost board) and with help of Petalogix 0.40 I have made my first Linux System, for now only with console that work very well.
I would try in the development of a device and create my custom driver for see in "device tree". Then use the device with "open", "close", "fread", "fwrite", "IOR_", "IOW_" ecc.
On "user-PC" with linux and PCI-SAT board, linux add on device tree "demux", "frontend", ecc.
I would like to implement a hardware "demux" to appear in the "device tree" and use the driver already exists in Linux for the "demux" (dvb-core or linux-video).
I search only a starting point, since I still have not understood how to get started.
Thanks very much.
secureasm
your outside my knowledge range re linux on spartan 3
mpeg demux I know a bit about.
PID filters are simple comparitors on the correct bits ib the transport stream,
  if you have full rate transport stream, and linux on an fpga I'd be impressed.
sorry
You need to learn to write drivers, I would get a device driver book for Linux and go from there. Device tree is not documented that well but there are plenty of examples of drivers using it. I would use platform data to get the driver working as it's easy then you can pull the data from the device tree if you want. You don't have to pull it from device tree ever if the driver data is not really changing (interrupts, memory addresses, etc....)
[for drjohnsmith]
I've seen Linux on Spartan 3A DSP, this is no a problem. Go here : Linux on Spartan 3
OK, it's true and my fpga hardware work with this technique.
My goal is not to process mpeg in real time but only      demux PAT, PMT, SDT, EIT, NIT, ecc, for post processong info on Transport stream input. Utilizing everything is already written by the community for DVB: dvbsnoop, demux, libsi, ecc.
[for linnj]
Be so, I can not understand very well.
I read a lot of drivers for dreambox, QBOX, etc.. but not yet come to nothing.
There is still no link between the hardware and Linux :smileysad:
secureasm
