schvab
Linux doesn't boot using U-Boot - hang after 'Freeing unused kernel memory', although simpleImage works fine
I'm running Linux on Avnet's MiniModule AES-MMP-V5FXT70-G. I have build a custom kernel, ramdisk and device tree and successfully built a simpleImage.initrd.virtex440-sfcvem.elf which runs totally fine when loaded through xmd or EDK bootloader. As you can imagine loading kernel and initrd from S-record in flash is really slow and takes up way to much space. So I have decided to utilize u-boot-xlnx and I'm getting kernel panic after 'Freeing unused kernel memory'.
First, for the reference, here is output from working simpleImage.initrd.virtex440-sfcvem.elf:
zImage starting: loaded at 0x00800000 (sp: 0x00c1ffa0)
Allocating 0x4b535c bytes for kernel ...
gunzipping (0x00000000 <- 0x00810000:0x009bda60)...done 0x397330 bytes
Attached initrd image at 0x009be000-0x00c1eec6
initrd head: 0x1f8b0808
Linux/PowerPC load: console=ttyS0,115200 root=/dev/ram ip=192.168.1.20:::255.255.255.0
Finalizing device tree... flat tree at 0xc2c300
[    0.000000] Using Xilinx Virtex440 machine description
[    0.000000] Linux version 2.6.37-sfcvemlk+ (schvab@schvab-lpc1) (gcc version 4.4.5 (crosstool-NG-1.10.1) ) #143 PREEMPT Wed May 25 11:06:58 CEST 2011
[    0.000000] Found initrd at 0xc09be000:0xc0c1eec6
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000000 -> 0x00004000
[    0.000000]   Normal   empty
[    0.000000] Movable zone start PFN for each node
[    0.000000] early_node_map[1] active PFN ranges
[    0.000000]     0: 0x00000000 -> 0x00004000
[    0.000000] MMU: Allocated 1088 bytes of context maps for 255 contexts
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/ram ip=192.168.1.20:::255.255.255.0
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 57596k/65536k available (3516k kernel code, 7940k reserved, 164k data, 1140k bss, 144k init)
[    0.000000] Kernel virtual memory layout:
[    0.000000]   * 0xfffdf000..0xfffff000  : fixmap
[    0.000000]   * 0xfde00000..0xfe000000  : consistent mem
[    0.000000]   * 0xfde00000..0xfde00000  : early ioremap
[    0.000000]   * 0xd1000000..0xfde00000  : vmalloc & ioremap
[    0.000000] NR_IRQS:512
[    0.000000] clocksource: timebase mult[a00000] shift[22] registered
[    0.000000] Console: colour dummy device 80x25
[   64.425543] pid_max: default: 32768 minimum: 301
[   64.426234] Mount-cache hash table entries: 512
[   64.443865] NET: Registered protocol family 16
[   64.504497] bio: create slab <bio-0> at 0
[   64.507753] XGpio: /plb@0/plb@90000000/gpio@91300000: registered
[   64.520477] Switching to clocksource timebase
[   64.615410] NET: Registered protocol family 2
[   64.616040] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[   64.618103] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[   64.618212] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[   64.618267] TCP: Hash tables configured (established 2048 bind 2048)
[   64.618285] TCP reno registered
[   64.618309] UDP hash table entries: 256 (order: 0, 4096 bytes)
[   64.618355] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[   64.619209] NET: Registered protocol family 1
[   64.621290] RPC: Registered udp transport module.
[   64.621323] RPC: Registered tcp transport module.
[   64.621339] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   64.625205] Trying to unpack rootfs image as initramfs...
[   64.638019] rootfs image is not initramfs (no cpio magic); looks like an initrd
[   64.663651] Freeing initrd memory: 2435k freed
[   64.696570] ROMFS MTD (C) 2007 Red Hat, Inc.
[   64.697814] msgmni has been set to 119
[   64.700289] io scheduler noop registered
[   64.700317] io scheduler deadline registered
[   64.700471] io scheduler cfq registered (default)
[   65.656501] SPBSSMM: -=SCHVAB=- Pixel Bus SubSystem Memory Manager - initialize
..some custom stuff...
[   66.545197] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[   66.560849] 91200000.serial: ttyS0 at MMIO 0x91201003 (irq = 22) is a 16550
[   67.166315] console [ttyS0] enabled
[   67.215913] brd: module loaded
[   67.241428] loop: module loaded
[   67.246398] xilinx_spi 82000000.spi: at 0x82000000 mapped to 0xd1100000, irq=25
[   67.254833] Device Tree Probing 'ethernet'
[   67.259470] of:xilinx_lltemac 81c00000.ethernet: MAC address is now  0: a:35:61:51: 0
[   67.267334] of:xilinx_lltemac 81c00000.ethernet: XLlTemac: using DMA mode.
[   67.274151] XLlTemac: DCR address: 0x80
[   67.277943] XLlTemac: buffer descriptor size: 32768 (0x8000)
[   67.283554] XLlTemac: Allocating DMA descriptors with kmalloc
[   67.290270] XLlTemac: (buffer_descriptor_init) phy: 0x38c8000, virt: 0xc38c8000, size: 0x8000
[   67.322941] XTemac: PHY detected at address 1.
[   67.329837] of:xilinx_lltemac 81c00000.ethernet: eth0: Xilinx TEMAC at 0x81C00000 mapped to 0xD1036000, irq=16
[   67.343405] i2c /dev entries driver
[   67.349082] Device Tree Probing 'i2c'
[   67.355855] xilinx-iic #0 at 0x91100000 mapped to 0xD1120000, irq=21
[   67.366881] TCP cubic registered
[   67.370176] NET: Registered protocol family 17
[   67.881281] eth0: XLlTemac: Options: 0x3fa
[   67.885486] eth0: XLlTemac: allocating interrupt 27 for dma mode tx.
[   67.891831] eth0: XLlTemac: allocating interrupt 26 for dma mode rx.
[   69.898346] NATIONAL DP83865 PHY
[   74.913775] XLlTemac: speed set to 10Mb/s
[   74.917772] eth0: XLlTemac: Send Threshold = 24, Receive Threshold = 4
[   74.924233] eth0: XLlTemac: Send Wait bound = 254, Receive Wait bound = 254
[   75.931979] IP-Config: Complete:
[   75.935035]      device=eth0, addr=192.168.1.20, mask=255.255.255.0, gw=255.255.255.255,
[   75.942938]      host=192.168.1.20, domain=, nis-domain=(none),
[   75.948827]      bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
[   75.959027] RAMDISK: gzip image found at block 0
[   76.621083] VFS: Mounted root (ext2 filesystem) readonly on device 1:0.
[   76.628030] Freeing unused kernel memory: 144k init
Initializing random number generator... done.
Starting network...
ip: RTNETLINK answers: File exists
[   76.932674] eth0: XLlTemac: PHY Link carrier lost.
-=SCHVAB=- FPGA-based Computer Vision Embedded Module
sfcvemlk login:
And now failed customized u-boot.
Well, I have basically only copied and renamed ml507_config, modified memory size, disabled IIC and SysACE.
The u-boot elf-file has been downloaded and executed using xmd, kernel, initrd and device tree were prelaoded to flash using EDK.
U-Boot 1.3.4-00327-ge094f24-dirty (May 27 2011 - 12:58:41)
CPU:   Xilinx PowerPC 440 UNKNOWN (PVR=7ff21912) at 400 MHz
       32 kB I-Cache 32 kB D-Cache
### No HW ID - assuming ML507
DRAM:  64 MB
Top of RAM usable for U-Boot at: 04000000
Reserving 191k for U-Boot at: 03fd0000
Reserving 1024k for malloc() at: 03ecff00
Reserving 128 Bytes for Board Info at: 03ecfe80
Reserving 56 Bytes for Global Data at: 03ecfe48
Stack Pointer at: 03ecfe28
New Stack Pointer is: 03ecfe28
Now running in RAM - U-Boot at: 03fd0000
FLASH: flash detect cfi
fwc addr fc000000 cmd f0 f0 8bit x 8 bit
fwc addr fc000000 cmd ff ff 8bit x 8 bit
fwc addr fc000055 cmd 98 98 8bit x 8 bit
is= cmd 51(Q) addr fc000010 is= 0 51
fwc addr fc000555 cmd 98 98 8bit x 8 bit
is= cmd 51(Q) addr fc000010 is= 7e 51
fwc addr fc000000 cmd f0 f0f0 16bit x 8 bit
fwc addr fc000000 cmd ff ffff 16bit x 8 bit
fwc addr fc0000aa cmd 98 9898 16bit x 8 bit
is= cmd 51(Q) addr fc000020 is= 0051 5151
fwc addr fc000aaa cmd 98 9898 16bit x 8 bit
fwc addr fc000000 cmd f0 00f0 16bit x 16 bit
fwc addr fc000000 cmd ff 00ff 16bit x 16 bit
fwc addr fc0000aa cmd 98 0098 16bit x 16 bit
is= cmd 51(Q) addr fc000020 is= 0051 0051
is= cmd 52(R) addr fc000022 is= 0052 0052
is= cmd 59(Y) addr fc000024 is= 0059 0059
device interface is 1
found port 2 chip 2 port 16 bits chip 16 bits
00 : 51 52 59 01 00 0a 01 00 00 00 00 17 20 85 95 08  QRY......... ...
10 : 0a 0a 00 01 02 02 00 19 01 00 0a 00 02 fe 00 00  ................
20 : 02 03 00 80 00 00 00 00 00 ff ff ff ff fd 00 00  ................
fwc addr fc000000 cmd 90 0090 16bit x 16 bit
manufacturer is 1
manufacturer id is 0x89
device id is 0x19
device id2 is 0x0
cfi version is 0x3134
size_ratio 1 port 16 bits chip 16 bits
found 2 erase regions
erase region 0: 0x020000fe
erase_region_count = 255 erase_region_size = 131072
erase region 1: 0x00800003
erase_region_count = 4 erase_region_size = 32768
32 MB
Using default environment
MAC address unavailable, set to default
MAC address: 00:0a:35:01:02:03
In:    serial
Out:   serial
Err:   serial
U-Boot relocated to 03fd0000
### main_loop entered: bootdelay=3
### main_loop: bootcmd="<UNDEFINED>"
=> cp.b 0xFC900000 0x01100000 0x300000            <--!! When I pass ramdisk image addr in flash directly to bootm, kernel crashes instantly, although image is successfully verified.
=> bootm 0xFC428000 0x01100000 0xFC837000
*  kernel: cmdline image address = 0xfc428000
## Booting kernel from Legacy Image at fc428000 ...
   Image Name:   Linux-2.6.37-sfcvemlk+
   Image Type:   PowerPC Linux Kernel Image (gzip compressed)
   Data Size:    1758500 Bytes =  1.7 MB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
   kernel data at 0xfc428040, len = 0x001ad524 (1758500)
*  ramdisk: cmdline image address = 0x01100000
## Loading init Ramdisk from Legacy Image at 01100000 ...
   Image Name:
   Image Type:   PowerPC Linux RAMDisk Image (gzip compressed)
   Data Size:    2494150 Bytes =  2.4 MB
   ramdisk start = 0x01100040, ramdisk end = 0x01360f06
*  fdt: cmdline image address = 0xfc837000
## Checking for 'FDT'/'FDT Image' at fc837000
*  fdt: raw FDT blob
## Flattened Device Tree blob at fc837000
   Booting using the fdt blob at 0xfc837000
   of_flat_tree at 0xfc837000 size 0x00004000
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x00000000, end = 0x03ecf9d8
## Current stack ends at 0x03ecf988
## device tree at 0xFC837000 ... 0xFC83AFFF (len=16384=0x4000)
   Loading Device Tree to 00ffc000, end 00ffffff ... OK
Updating property 'timebase-frequency' =  17 d7 84 00
Updating property 'clock-frequency' =  17 d7 84 00
Updating property '/plb/clock-frequency' =  02 fa f0 80
Updating property '/plb/opb/clock-frequency' =  04 00 04 2c
Unable to update property /plb/opb:clock-frequency, err=FDT_ERR_NOTFOUND
Updating property '/plb/ebc/clock-frequency' =  00 ff c0 00
Unable to update property /plb/ebc:clock-frequency, err=FDT_ERR_NOTFOUND
Updating property 'clock-frequency' =  02 fa f0 80
Updating property '/plb@0/xps-ll-temac@81c00000/mac-address' =  00 0a 35 01 02 03
Updating property '/plb@0/xps-ll-temac@81c00000/local-mac-address' =  00 0a 35 01 02 03
Unable to update property NOR mapping, err=FDT_ERR_NOTFOUND
## initrd_high = 0xffffffff, copy_to_ram = 1
   Loading Ramdisk to 03c6e000, end 03eceec6 ... OK
   ramdisk load start = 0x03c6e000, ramdisk load end = 0x03eceec6
## Transferring control to Linux (at address 00000000) ...
   Booting using OF flat tree...
[    0.000000] Found initrd at 0xc3c6e000:0xc3eceec6
[    0.000000] Memory: 55160k/65536k available (3516k kernel code, 10376k reserved, 164k data, 1140k bss, 144k init)
[   42.950692] pid_max: default: 32768 minimum: 301
[   42.951385] Mount-cache hash table entries: 512
[   42.969010] NET: Registered protocol family 16
[   43.029446] bio: create slab <bio-0> at 0
[   43.032800] XGpio: /plb@0/plb@90000000/gpio@91300000: registered
[   43.045472] Switching to clocksource timebase
[   43.139807] NET: Registered protocol family 2
[   43.140369] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[   43.142352] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[   43.142464] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[   43.142676] TCP: Hash tables configured (established 2048 bind 2048)
[   43.142698] TCP reno registered
[   43.142738] UDP hash table entries: 256 (order: 0, 4096 bytes)
[   43.142793] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[   43.143432] NET: Registered protocol family 1
[   43.145632] RPC: Registered udp transport module.
[   43.145663] RPC: Registered tcp transport module.
[   43.145679] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   43.149354] Trying to unpack rootfs image as initramfs...
[   43.162244] rootfs image is not initramfs (no cpio magic); looks like an initrd
[   43.181690] Freeing initrd memory: 2435k freed
[   43.214482] ROMFS MTD (C) 2007 Red Hat, Inc.
[   43.215737] msgmni has been set to 114
[   43.218163] io scheduler noop registered
[   43.218190] io scheduler deadline registered
[   43.218355] io scheduler cfq registered (default)
[   44.161974] SPBSSMM: -=SCHVAB=- Pixel Bus SubSystem Memory Manager - initialize
...custom stuff...
[   45.049976] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[   45.065624] 91200000.serial: ttyS0 at MMIO 0x91201003 (irq = 22) is a 16550
[   45.671197] console [ttyS0] enabled
[   45.720628] brd: module loaded
[   45.745970] loop: module loaded
[   45.750978] xilinx_spi 82000000.spi: at 0x82000000 mapped to 0xd1100000, irq=25
[   45.759362] Device Tree Probing 'ethernet'
[   45.764002] of:xilinx_lltemac 81c00000.ethernet: MAC address is now  0: a:35:61:51: 0
[   45.771862] of:xilinx_lltemac 81c00000.ethernet: XLlTemac: using DMA mode.
[   45.778685] XLlTemac: DCR address: 0x80
[   45.782473] XLlTemac: buffer descriptor size: 32768 (0x8000)
[   45.788088] XLlTemac: Allocating DMA descriptors with kmalloc
[   45.794811] XLlTemac: (buffer_descriptor_init) phy: 0x38c8000, virt: 0xc38c8000, size: 0x8000
[   45.827365] XTemac: PHY detected at address 1.
[   45.834206] of:xilinx_lltemac 81c00000.ethernet: eth0: Xilinx TEMAC at 0x81C00000 mapped to 0xD1036000, irq=16
[   45.847763] i2c /dev entries driver
[   45.853378] Device Tree Probing 'i2c'
[   45.860097] xilinx-iic #0 at 0x91100000 mapped to 0xD1120000, irq=21
[   45.871089] TCP cubic registered
[   45.874397] NET: Registered protocol family 17
[   46.385271] eth0: XLlTemac: Options: 0x3fa
[   46.389477] eth0: XLlTemac: allocating interrupt 27 for dma mode tx.
[   46.395820] eth0: XLlTemac: allocating interrupt 26 for dma mode rx.
[   48.402332] NATIONAL DP83865 PHY
[   48.415728] XLlTemac: speed set to 10Mb/s
[   48.419682] eth0: XLlTemac: Send Threshold = 24, Receive Threshold = 4
[   48.426160] eth0: XLlTemac: Send Wait bound = 254, Receive Wait bound = 254
[   49.433962] IP-Config: Complete:
[   49.437029]      device=eth0, addr=192.168.1.20, mask=255.255.255.0, gw=255.255.255.255,
[   49.444937]      host=192.168.1.20, domain=, nis-domain=(none),
[   49.450826]      bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
[   49.460993] RAMDISK: gzip image found at block 0
[   50.085072] VFS: Mounted root (ext2 filesystem) readonly on device 1:0.
[   50.092021] Freeing unused kernel memory: 144k init
[   50.103965] ------------[ cut here ]------------
[   50.108520] kernel BUG at arch/powerpc/kernel/traps.c:1001!
[   50.114051] Oops: Exception in kernel mode, sig: 5 [#1]
[   50.119225] PREEMPT Xilinx Virtex440
[   50.122768] last sysfs file:
[   50.125705] Modules linked in:
[   50.128735] **bleep**: c000a920 LR: c000cf5c CTR: 48001f00
[   50.133664] REGS: c3833e70 TRAP: 0700   Tainted: G        W    (2.6.37-sfcvemlk+)
[   50.141084] MSR: 00029000 <EE,ME,CE>  CR: 44002044  XER: 00000000
[   50.147137] TASK = c3831970[1] 'init' THREAD: c3832000
[   50.152057] GPR00: 00000001 c3833f20 c3831970 c3833f50 08000000 bff5a1d8 4800d560 00000000
[   50.160352] GPR08: 10002304 c03a0000 08000000 c000a79c 24002042 4f7777f7 00000001 bff5a1b0
[   50.168646] GPR16: bff5a1b0 00000001 00000000 4800d560 bff5a1e0 bff5a1dc bff5a1e4 bff5a1d8
[   50.176941] GPR24: 4802df40 4802dd10 100022fc 4801e000 00000000 100c8f30 08000000 c3833f50
[   50.185448] **bleep** [c000a920] program_check_exception+0x184/0x58c
[   50.191211] LR [c000cf5c] ret_from_except_full+0x0/0x4c
[   50.196381] Call Trace:
[   50.198807] [c3833f20] [4802dd10] 0x4802dd10 (unreliable)
[   50.204166] [c3833f40] [c000cf5c] ret_from_except_full+0x0/0x4c
[   50.210040] --- Exception: 700 at 0x480176e4
[   50.210048]     LR = 0x4800dfe0
[   50.217377] Instruction dump:
[   50.220315] 38600005 480003f4 7c008146 77ca0804 41820028 3d20c03a 88098060 2f800000
[   50.228004] 40be0010 38000001 98098060 480003ec <0fe00000> 48000000 77c00c04 41a2035c
[   50.235873] ---[ end trace 2ad4d79aab0818d2 ]---
[   50.241425] Kernel panic - not syncing: Attempted to kill init!
[   50.247355] Call Trace:
[   50.249833] [c3833c70] [c00066b4] show_stack+0x80/0x194 (unreliable)
[   50.256101] [c3833cb0] [c028abf0] panic+0xc8/0x1f8
[   50.260854] [c3833d00] [c0023d98] do_exit+0x88/0x650
[   50.265780] [c3833d50] [c000a134] kernel_bad_stack+0x0/0x4c
[   50.271301] [c3833d70] [c000a2e0] _exception+0x68/0x124
[   50.276489] [c3833e60] [c000cf5c] ret_from_except_full+0x0/0x4c
[   50.282370] --- Exception: 700 at program_check_exception+0x184/0x58c
[   50.282381]     LR = ret_from_except_full+0x0/0x4c
[   50.293552] [c3833f20] [4802dd10] 0x4802dd10 (unreliable)
[   50.298861] [c3833f40] [c000cf5c] ret_from_except_full+0x0/0x4c
[   50.304734] --- Exception: 700 at 0x480176e4
[   50.304742]     LR = 0x4800dfe0
[   50.312112] Rebooting in 180 seconds..
Could anybody please tell me what's going on and why?
I have attached a u-boot board header file, some other u-boot settings:
TEXT_BASE = 0x02000000
XPAR_IIC        := n
XPAR_LLTEMAC        := y
XPAR_SYSACE        := n
schvab
So the problem was caused by FPU - although I still do not quite understand why simpleImage worked fine...
To sum up:
My code uses FPU so I need CONFIG_PPC_FPU=y in my kernel .config, the described problem dissapeared after enabling CONFIG_MATH_EMULATION=y.
Thank you for the hints.
Jan Svab
linnj
Nothing seems familiar with that issue.  I would probably disable all the device drivers in Linux 1st to minimize what's running in the kernel.
I'm assuming you pulled the u-boot from the xilinx git server.  I guess I would try to better understand that exception that's happening and where in the kernel you're getting it.
Can you tftp a kernel image into ram and run it as I would try to isolate it a bit more if possible?
schvab
Yes, this is Xilinx U-boot, although it seems to have problems with DP83865 PHY - it is able to have a stable link (i.e. not to loose a lot of packets and freeze) only when connected to 10Base-T hub. The kernel works fine with this PHY.
The exeption is produced in arch/powerpc/kernel/traps.c:1001, particularly this code:
#if defined(CONFIG_XILINX_VIRTEX_5_FXT) && defined(CONFIG_PPC_FPU)
    if (reason & REASON_ILLEGAL) {
        if (excep_state < 1) {
            excep_state++;
            return;
        /* should never get here */
        BUG();
#endif
This is output when I tried to load kernel using tftp and attach a nfs root:
U-Boot 1.3.4-00327-ge094f24-dirty (May 29 2011 - 01:03:16)
DRAM:  64 MB
FLASH: 32 MB
In:    serial
Out:   serial
Err:   serial
=> tftp 0x3000000 uImage.bin
TFTP from server 11.0.1.1; our IP address is 11.0.1.111
Filename 'uImage.bin'.
Load address: 0x3000000
Loading: ##################################T ############T ###################
         ##T #######T ##############################################
done
Bytes transferred = 1758777 (1ad639 hex)
=> tftp 0x3200000 udevtree.dtb
Filename 'udevtree.dtb'.
Load address: 0x3200000
Loading: ##
done
Bytes transferred = 16384 (4000 hex)
=> setenv bootargs root=/dev/nfs rw nfsroot=192.168.1.1:/nfsshare/sfcvem_root ip=192.168.1.20:::255.255.255.0:sfcvem:eth0:off console=ttyS0,115200
=> bootm 0x3000000 - 0x3200000
## Booting kernel from Legacy Image at 03000000 ...
   Data Size:    1758713 Bytes =  1.7 MB
## Flattened Device Tree blob at 03200000
   Booting using the fdt blob at 0x3200000
[    0.000000] Linux version 2.6.37-sfcvemlk+ (schvab@schvab-lpc1) (gcc version 4.4.5 (crosstool-NG-1.10.1) ) #150 PREEMPT Sat May 28 13:29:06 CEST 2011
[    0.000000] Kernel command line: root=/dev/nfs rw nfsroot=192.168.1.1:/nfsshare/sfcvem_root ip=192.168.1.20:::255.255.255.0:sfcvem:eth0:off console=ttyS00
[    0.000000] Memory: 60032k/65536k available (3516k kernel code, 5504k reserved, 164k data, 1140k bss, 144k init)
[  118.112627] pid_max: default: 32768 minimum: 301
[  118.113315] Mount-cache hash table entries: 512
[  118.130922] NET: Registered protocol family 16
[  118.191328] bio: create slab <bio-0> at 0
[  118.194679] XGpio: /plb@0/plb@90000000/gpio@91300000: registered
[  118.207354] Switching to clocksource timebase
[  118.301663] NET: Registered protocol family 2
[  118.302226] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[  118.304182] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[  118.304294] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[  118.304349] TCP: Hash tables configured (established 2048 bind 2048)
[  118.304367] TCP reno registered
[  118.304392] UDP hash table entries: 256 (order: 0, 4096 bytes)
[  118.304610] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[  118.305292] NET: Registered protocol family 1
[  118.307367] RPC: Registered udp transport module.
[  118.307459] RPC: Registered tcp transport module.
[  118.307474] RPC: Registered tcp NFSv4.1 backchannel transport module.
[  118.343346] ROMFS MTD (C) 2007 Red Hat, Inc.
[  118.344609] msgmni has been set to 119
[  118.347049] io scheduler noop registered
[  118.347079] io scheduler deadline registered
[  118.347238] io scheduler cfq registered (default)
[  119.289751] SPBSSMM: -=SCHVAB=- Pixel Bus SubSystem Memory Manager - initialize
[  119.289824] ------------[ cut here ]------------    <--this is because I call boot memory allocation when the SLAB allocator is already up, it is only a warning and requests are passed to SLAB allocator
[  119.289843] WARNING: at mm/bootmem.c:672
[  119.289855] Modules linked in:
[  119.289874] **bleep**: c0354b7c LR: c0354b64 CTR: 00000001
[  119.289897] REGS: c3833e60 TRAP: 0700   Not tainted  (2.6.37-sfcvemlk+)
[  119.289913] MSR: 00029000 <EE,ME,CE>  CR: 2482eb84  XER: 00000000
[  119.289952] TASK = c3831970[1] 'swapper' THREAD: c3832000
[  119.289965] GPR00: 00000001 c3833f10 c3831970 00000000 000c0080 00000010 3fffffff 00000000
[  119.290005] GPR08: c049a1b8 c04a0000 00000000 00000001 248ceb82 4f7777f7 03fffd00 00000004
[  119.290045] GPR16: 00000024 00000000 03fdf770 03ff4dd1 03ff4dc6 00000001 c0000020 00000000
[  119.290084] GPR24: c036a4e8 00000000 000c0080 00000010 c036a4cc 00000000 3fffffff 000c0080
[  119.290148] **bleep** [c0354b7c] alloc_arch_preferred_bootmem+0x30/0x74
[  119.290171] LR [c0354b64] alloc_arch_preferred_bootmem+0x18/0x74
[  119.290185] Call Trace:
[  119.290209] [c3833f20] [c03554e0] ___alloc_bootmem_nopanic+0x78/0x148
[  119.290235] [c3833f60] [c035583c] ___alloc_bootmem+0x18/0x50
[  119.290273] [c3833f70] [c018a10c] SPBSSMM_init+0x78/0x33c
[  119.290312] [c3833f90] [c035e894] spbss_fcn_init+0x34/0x148
[  119.290341] [c3833fb0] [c0001544] do_one_initcall+0xf4/0x1ec
[  119.290373] [c3833fe0] [c034b1e4] kernel_init+0xc4/0x170
[  119.290400] [c3833ff0] [c000c710] kernel_thread+0x4c/0x68
[  119.290416] Instruction dump:
[  119.290430] 9421fff0 7c0802a6 93e1000c 7c9f2378 90010014 4bd302e1 2f830000 38600000
[  119.290469] 41be002c 3d20c04a 8809163c 68000001 <0f000000> 2f800000 41be0028 38000001
[  119.290544] ---[ end trace f147f6e3efbba487 ]---
[  119.346076] SPBSSMM: tSPBSS_mem_img1024 0 at C3A00000
[  119.401453] SPBSSMM: tSPBSS_mem_img1024 1 at C3B00000
[  119.456818] SPBSSMM: tSPBSS_mem_img1024 2 at C3000000
[  119.512139] SPBSSMM: tSPBSS_mem_img1024 3 at C3100000
[  119.567483] SPBSSMM: tSPBSS_mem_img1024 4 at C3200000
[  119.788942] SPBSSMM: tSPBSS_mem_intimg1024 0 at C2C00000
[  120.010618] SPBSSMM: tSPBSS_mem_intimg1024 1 at C2800000
[  120.017499] SPBSSMM: tSPBSS_mem_lmpb32p 0 at C39C0000
[  120.024352] SPBSSMM: tSPBSS_mem_lmpb32p 1 at C39E0000
[  120.031214] SPBSSMM: tSPBSS_mem_lmpb32p 2 at C3300000
[  120.038070] SPBSSMM: tSPBSS_mem_lmpb32p 3 at C3320000
[  120.044929] SPBSSMM: tSPBSS_mem_lmpb32p 4 at C3340000
[  120.051798] SPBSSMM: tSPBSS_mem_lmpb32p 5 at C3360000
[  120.058667] SPBSSMM: tSPBSS_mem_lmpb32p 6 at C3380000
[  120.065540] SPBSSMM: tSPBSS_mem_lmpb32p 7 at C33A0000
[  120.072391] SPBSSMM: tSPBSS_mem_lmpb32p 8 at C33C0000
[  120.079259] SPBSSMM: tSPBSS_mem_lmpb32p 9 at C33E0000
[  120.086083] SPBSSMM: tSPBSS_mem_lmpb32p 10 at C2400000
[  120.092938] SPBSSMM: tSPBSS_mem_lmpb32p 11 at C2420000
[  120.099797] SPBSSMM: tSPBSS_mem_lmpb32p 12 at C2440000
[  120.106656] SPBSSMM: tSPBSS_mem_lmpb32p 13 at C2460000
[  120.113526] SPBSSMM: tSPBSS_mem_lmpb32p 14 at C2480000
[  120.120370] SPBSSMM: tSPBSS_mem_lmpb32p 15 at C24A0000
[  120.134136] SPBSSMM: tSPBSS_mem_sdb64p 0 at C24C0000
[  120.147902] SPBSSMM: tSPBSS_mem_sdb64p 1 at C2500000
[  120.161668] SPBSSMM: tSPBSS_mem_sdb64p 2 at C2540000
[  120.175456] SPBSSMM: tSPBSS_mem_sdb64p 3 at C2580000
[  120.176018] SPBSSDTP: adding new device spb-dcfg902
[  120.176197] SPBSSDTP: adding new device spb-pdmab900
[  120.176544] SPBSSDTP: adding new device spb-rcsic901
[  120.176668] SPBSSDTP: adding new device ssio903
[  120.176821] SPBSSDTP: adding new device spb-lmf890
[  120.176978] SPBSSDTP: adding new device spb-lmf891
[  120.177965] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[  120.193590] 91200000.serial: ttyS0 at MMIO 0x91201003 (irq = 22) is a 16550
[  120.777348] console [ttyS0] enabled
[  120.826688] brd: module loaded
[  120.851953] loop: module loaded
[  120.856964] xilinx_spi 82000000.spi: at 0x82000000 mapped to 0xd1100000, irq=25
[  120.865334] Device Tree Probing 'ethernet'
[  120.869980] of:xilinx_lltemac 81c00000.ethernet: MAC address is now  0: a:35:9e:10: 0
[  120.877837] of:xilinx_lltemac 81c00000.ethernet: XLlTemac: using DMA mode.
[  120.884658] XLlTemac: DCR address: 0x80
[  120.888452] XLlTemac: buffer descriptor size: 32768 (0x8000)
[  120.894059] XLlTemac: Allocating DMA descriptors with kmalloc
[  120.900949] XLlTemac: (buffer_descriptor_init) phy: 0x25f0000, virt: 0xc25f0000, size: 0x8000
[  120.933579] XTemac: PHY detected at address 1.
[  120.940401] of:xilinx_lltemac 81c00000.ethernet: eth0: Xilinx TEMAC at 0x81C00000 mapped to 0xD1036000, irq=16
[  120.953986] i2c /dev entries driver
[  120.959634] Device Tree Probing 'i2c'
[  120.966266] xilinx-iic #0 at 0x91100000 mapped to 0xD1120000, irq=21
[  120.977302] TCP cubic registered
[  120.980593] NET: Registered protocol family 17
[  121.491162] eth0: XLlTemac: Options: 0x3fa
[  121.495367] eth0: XLlTemac: allocating interrupt 27 for dma mode tx.
[  121.501710] eth0: XLlTemac: allocating interrupt 26 for dma mode rx.
[  123.508222] NATIONAL DP83865 PHY
[  123.521623] XLlTemac: speed set to 10Mb/s
[  123.525573] eth0: XLlTemac: Send Threshold = 24, Receive Threshold = 4
[  123.532058] eth0: XLlTemac: Send Wait bound = 254, Receive Wait bound = 254
[  124.539833] IP-Config: Complete:
[  124.542896]      device=eth0, addr=192.168.1.20, mask=255.255.255.0, gw=255.255.255.255,
[  124.550800]      host=sfcvem, domain=, nis-domain=(none),
[  124.556168]      bootserver=255.255.255.255, rootserver=192.168.1.1, rootpath=
[  126.671267] VFS: Mounted root (nfs filesystem) on device 0:12.
[  126.677444] Freeing unused kernel memory: 144k init
[  128.464025] ------------[ cut here ]------------
[  128.468579] kernel BUG at arch/powerpc/kernel/traps.c:1001!
[  128.474111] Oops: Exception in kernel mode, sig: 5 [#1]
[  128.479282] PREEMPT Xilinx Virtex440
[  128.482827] last sysfs file:
[  128.485765] Modules linked in:
[  128.488795] **bleep**: c000a920 LR: c000cf5c CTR: 48001f00
[  128.493722] REGS: c3833e70 TRAP: 0700   Tainted: G        W    (2.6.37-sfcvemlk+)
[  128.501144] MSR: 00029000 <EE,ME,CE>  CR: 44002044  XER: 00000000
[  128.507196] TASK = c3831970[1] 'init' THREAD: c3832000
[  128.512116] GPR00: 00000001 c3833f20 c3831970 c3833f50 08000000 bff421a8 4800d560 00000000
[  128.520411] GPR08: 10002304 c03a0000 08000000 c000a79c 24002042 4f7777f7 00000001 bff42180
[  128.528705] GPR16: bff42180 00000001 00000000 4800d560 bff421b0 bff421ac bff421b4 bff421a8
[  128.537000] GPR24: 4802df40 4802dd10 100022fc 4801e000 00000000 100c8f30 08000000 c3833f50
[  128.545506] **bleep** [c000a920] program_check_exception+0x184/0x58c
[  128.551269] LR [c000cf5c] ret_from_except_full+0x0/0x4c
[  128.556440] Call Trace:
[  128.558867] [c3833f20] [4802dd10] 0x4802dd10 (unreliable)
[  128.564225] [c3833f40] [c000cf5c] ret_from_except_full+0x0/0x4c
[  128.570097] --- Exception: 700 at 0x480176e4
[  128.570106]     LR = 0x4800dfe0
[  128.577434] Instruction dump:
[  128.580373] 38600005 480003f4 7c008146 77ca0804 41820028 3d20c03a 88098060 2f800000
[  128.588062] 40be0010 38000001 98098060 480003ec <0fe00000> 48000000 77c00c04 41a2035c
[  128.595931] ---[ end trace f147f6e3efbba489 ]---
[  128.601669] Kernel panic - not syncing: Attempted to kill init!
[  128.607636] Call Trace:
[  128.610047] [c3833c70] [c00066b4] show_stack+0x80/0x194 (unreliable)
[  128.616324] [c3833cb0] [c028abc8] panic+0xc8/0x1f8
[  128.621077] [c3833d00] [c0023d98] do_exit+0x88/0x650
[  128.626001] [c3833d50] [c000a134] kernel_bad_stack+0x0/0x4c
[  128.631531] [c3833d70] [c000a2e0] _exception+0x68/0x124
[  128.636711] [c3833e60] [c000cf5c] ret_from_except_full+0x0/0x4c
[  128.642592] --- Exception: 700 at program_check_exception+0x184/0x58c
[  128.642603]     LR = ret_from_except_full+0x0/0x4c
[  128.653769] [c3833f20] [4802dd10] 0x4802dd10 (unreliable)
[  128.659083] [c3833f40] [c000cf5c] ret_from_except_full+0x0/0x4c
[  128.664957] --- Exception: 700 at 0x480176e4
[  128.664965]     LR = 0x4800dfe0
[  128.672333] Rebooting in 180 seconds..
It seems to produce exactly the same exception as when the ramdisk is utilized, so I guess the fault is really on the u-boot side. Although I do not understand kernel too much, this exception looks like it has something to do with FPU... Is it maybe possible that U-boot doesn't bring it up and simpleImage does? Maybe do I need some extra CFG_ or CONFIG_ for u-boot?
linnj
Seems like you should start disabling things (like FPU) to get to a minimal system that's working.
That's typically my method, minimize it to get a system working, then add incrementally from there.
I don't know of anything specific to the FPU, but I don't use it regularly.  You don't mention your kernel defconfig being used.
schvab
Well, I have started this work on ML507, so defconfig came from there, but throughout the course of time I've changed a lot of things - I attached my current kernel config If it would be somehow helpful.
I will try the minimal-system approach, but I will get back with results in a week - I have to defend this project as a master's thesis and pass a state exam :)  ...As I said earlier - it works with EDK bootloader and simpleImage...
P.S.: Here is a small video about my project - http://www.youtube.com/watch?v=ojfTEXZvQOg - FPGA is used for a computer vision task - extraction of local image features acording to SURF algorithm.
schvab
To sum up:
Jan Svab
