Visitor hduhxc
Linux image running in QEMU can not connect to built-in tftp server
I am trying to build a linux image by buildroot, using kernel config copied from PetaLinux.
When I boot this image with the following instruction, I can download corresponding images through tftp service provided by U-boot.
qemu-system-aarch64 -M arm-generic-fdt -nographic -m 4G \
-global xlnx,zynqmp-boot.cpu-num=0 -global xlnx,zynqmp-boot.use-pmufw=true \
-device loader,file=qemu/bl31.elf,cpu-num=0 \
-device loader,file=qemu/u-boot.elf \
-hw-dtb qemu/zcu102-arm.dtb \
-machine-path qemu/tmp \
-net nic -net nic -net nic -net nic -net user,tftp=.
The eth0 device does not enable automatically,  but I can enable it manually:
ifconfig eth0 up
ifconfig eth0 10.0.2.15 netmask 255.255.255.0
 Unfortunately, when I ping 10.0.2.2, it is unreachable. I also tried to use udhcpc to get an IP address, but failed.
It is so weird that when I boot my Image on ZCU102 development board, everything seems OK.  Similarly, the pre-built image of PetaLinux running in qemu works correctly.
Could anyone give me an advice? Thanks in advance.
Re: Linux image running in QEMU can not connect to built-in tftp server
Hi @hduhxc
If it is working fine in Petalinux flow, may I know the difference? Did you make any modifications to rootfs?
Best Regards
Shabbir
Visitor hduhxc
Since the network connection on real hardware works well, is there any option that is related to QEMU?
Hi @hduhxc
Can you try something like this:
petalinux-boot --qemu --u-boot --qemu-args "-net nic -net nic -net nic -net nic -net user,tftp=./images/linux/,hostfwd=tcp:127.0.0.1:2222-10.0.2.15:22,hostfwd=tcp:127.0.0.1:2322-10.0.2.16:22"
