Linux rootfs file system 32MB
I am trying to boot Linux with a 32MB root filesystem. I am using busybox to create the rootfs with the following steps:
-$ dd if=/dev/zero of=ramdisk32.image bs=1024 count=32768
-$ mke2fs -F ramdisk32.image -L "ramdisk" -b 1024 -m 0
-$ tune2fs ramdisk32.image -i 0
-$ mkdir ramdisk
-$ sudo mount -o loop ramdisk32.image ramdisk/
-$ sudo cp -R _rootfs/* ramdisk
-$ sudo umount ramdisk/
-$ gzip -v9 ramdisk32.image
-$ mkimage -A arm -n 'RAM disk 32MB' -T ramdisk -C gzip -d ramdisk32.image.gz uramdisk.image.gz
However, when I attempt to boot Linux on my system, I get the error message
RAMDISK: incomplete write (17106 != 32768)
write error
EXT4-fs (ram0): bad geometry: block count 32768 exceeds size of device (16384 blocks)
Any help is appreciated. Thanks.
