frosteyes
Linux tries to disable pll - dpll
After upgrade to 2019.1 I noticed the following error.
[    1.543817] zynqmp_pll_disable() clock disable failed for dpll_int, ret = -13
The reason is because I don't use any of the available clocks on the dpll when looking at clk_summary
    dpll_post_src                     0        0        0    33333333          0     0  50000
    dpll_pre_src                      0        0        0    33333333          0     0  50000
       dpll_int                       0        0        0  2399999976          0     0  50000
          dpll_half                   0        0        0  1199999988          0     0  50000
             dpll_int_mux             0        0        0  1199999988          0     0  50000
                dpll                  0        0        0  1199999988          0     0  50000
                   gpu_ref_mux        0        0        0  1199999988          0     0  50000
                      gpu_ref_div1       0        0        0   599999994          0     0  50000
                         gpu_ref       0        0        0   599999994          0     0  50000
                            gpu_pp1_ref       0        0        0   599999994          0     0  50000
                            gpu_pp0_ref       0        0        0   599999994          0     0  50000
                   sata_ref_mux       0        0        0  1199999988          0     0  50000
                      sata_ref_div1       0        0        0    99999999          0     0  50000
                         sata_ref       0        0        0    99999999          0     0  50000
                   dpdma_ref_mux       0        0        0  1199999988          0     0  50000
                      dpdma_ref_div1       0        0        0   599999994          0     0  50000
                         dpdma_ref       0        0        0   599999994          0     0  50000
                   gdma_ref_mux       0        0        0  1199999988          0     0  50000
                      gdma_ref_div1       0        0        0   599999994          0     0  50000
                         gdma_ref       0        0        0   599999994          0     0  50000
                   dp_video_ref_mux       0        0        0  1199999988          0     0  50000
                      dp_video_ref_div1       0        0        0   119999999          0     0  50000
                         dp_video_ref_div2       0        0        0   119999999          0     0  50000
                            dp_video_ref       0        0        0   119999999          0     0  50000
                   dpll_to_lpd        0        0        0   399999996          0     0  50000
Though is the dpll used for the ddr controller. But the ddr controller is not part of the clk tree?
For now I have created the following in the device tree
/* Force dpll on - This removes the error
   "zynqmp_pll_disable() clock disable failed for dpll_int, ret = -13"
   when booting 2019.1. It is a hack to use the fclk module to
   always enable it. */
        dpllClk: dpllClk {
                status = "okay";
                compatible = "xlnx,fclk";
                clocks = <&zynqmp_clk 3>;
So I "misuse" the xlnx,fclk hack for this also, so this remove the error, and when looking at clk_summary
    dpll_pre_src                      1        1        0    33333333          0     0  50000
       dpll_int                       1        1        0  2399999976          0     0  50000
          dpll_half                   1        1        0  1199999988          0     0  50000
             dpll_int_mux             1        1        0  1199999988          0     0  50000
                dpll                  1        1        0  1199999988          0     0  50000
But Xilinx. Please for the 2019.2 fix it, so I don't need to use this hack, but it just see that dpll is used for the ddr controller, and only tries to disable it if it not used.
Tags (2)
stephenm
Can you share your HDF and I can reproduce this issue please?
frosteyes
I can't share the HDF on this public forum.
Xilinx and Phase One has NDA together (From early ZynqMP ES1 work). So I can easly send it, to your Xilinx mail, if you want.
