ilya1976
Linux u-boot build for zc702 make
I've encountered a problem with building  u-boot for arm of zc702.
I followed instructions from https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841973/Build+U-Boot
I downloaded u-boot-xilinx from github, set environment variables and paths as:
export ARCH=arm
export PATH=/vivado/u-boot-xlnx/tools/:$PATH
source /vivado/Vivado_2020_2/Vivado/2020.2/settings64.sh
source /vivado/Vivado_2020_2/Vitis/2020.2/settings64.sh
and after that I tried to run make from u-boot-xilinx directory.
[ilya@localhost u-boot-xlnx]$ make zynq_zc702_defconfig
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
YACC scripts/kconfig/zconf.tab.c
LEX scripts/kconfig/zconf.lex.c
HOSTCC scripts/kconfig/zconf.tab.o
HOSTLD scripts/kconfig/conf
*** Can't find default configuration "arch/../configs/zynq_zc702_defconfig"!
make[1]: *** [scripts/kconfig/Makefile:128: zynq_zc702_defconfig] Error 1
make: *** [Makefile:540: zynq_zc702_defconfig] Error 2
Thank you very  much in advance for any help, advice or suggestion!
Prasanna_K
Hi @ilya1976 ,
You need to run below command, Because For 2020.1 and above releases common defconfig is being made
make distclean
make xilinx_zynq_virt_defconfig
export DEVICE_TREE="zynq-zc702"
make
Prasanna
Give kudos if helpful. Accept as solution if it solves your problem.
ilya1976
Thank you!
Config passed ok, but now I have error on make stage.
/bin/sh: arm-none-linux-gnueabi-gcc: command not found
I use CentOS 8, I know that this version is not supported, also
I haven't found arm-none-linux-gnueabi-gcc for CentOS 8.
But maybe there is any alternative way to build u-boot?
