Voyager
Voyager
Linux-xlnx IRQ management ( Kernel 4.6 to 4.9)
Hello :)
After updating linux-xlnx kernel from 4.6 to 4.9 (HEAD detached at xilinx-v2017.4), some modification seems appear because of our DMA driver doesn't work anymore ...
I didn't touch device-tree node:
* 2 IRQ are set :
[   38.320648] dmadriver: loading out-of-tree module taints kernel.
[   38.327579] MTDRV_init
[   38.331327] MTDRV_probe
[   38.333774] MTDRV_construct_device 0 ef287d08
[   38.338098]   xil_init
[   38.360442] dma io map f30e2030
[   38.363505] Pool capacity : 2048 SLD nodes.
[   38.367729] xil_init : Create thread
[   38.371319] Register IRQ : 47
[   38.371329] mtdrv thread running ...
[   38.389158]   xil_init
[   38.391444] alloc_init_attrs
[   38.411485] dma io map f30e4030
[   38.414566] Pool capacity : 31744 SLD nodes.
[   38.419158] xil_init : Create thread
[   38.422743] Register IRQ : 48
[   38.422751] mtdrv thread running ...
Confirmed on /proc/interrupts:
 47:          0          0     GIC-0  61 Edge      XIL_IRQ_DMA
 48:          0          0     GIC-0  62 Edge      XIL_IRQ_DMA
And device-tree configuration:
		mydriver0: mydriver0@0x40400030
			compatible = "CUST,bob";
			interrupt-parent= <&intc>;
			interrupts = <0 30 1>;
			reg = <0x40400030 0x1C>;
		mydriver: mydriver@0x40400030
			interrupts = <0 29 1>;
But IRQ never rising ...
Any idea or suggestion ? I have tried all i know but no success yet... :(
Cheers,
Trigger
Re: Linux-xlnx IRQ management ( Kernel 4.6 to 4.9)
Can you regenerate the DT using the devicetree generator. How the interrupt numbers are handled has changed
Voyager
Voyager
Thank you for responding.
We don't generate the .dts because of it's a custom driver. This driver has worked with kernel 4.6 but not with 4.9 ... :(
I can't explain the reason why... any idea ??
because i'm stuck : I have to choose a 4.9 kernel with full USB driver working (but not our old driver)  or a kernel 4.6 with bugging USB and our driver ...
Cheers,
Trigger
