mspalpsahan
Loading Ramdisk to fdc69000, end 07fffb38 ... data abort
I down't know why the CPU is resetting, I use the original files from ug1144 files. I hope you or anybody can help my.
best regards
Alpalsan sahan
U-Boot 2017.01 (Apr 17 2019 - 12:55:19 +0300)
Model: Zynq Zybo Z7 Development Board
Board: Xilinx Zynq
I2C: ready
DRAM: ECC disabled 1 GiB
MMC: sdhci@e0100000: 0 (SD)
Using default environment
In: serial
Out: serial
Err: serial
Net: ZYNQ GEM: e000b000, phyaddr 1, interface rgmii-id
SF: Detected s25fl128s_64k with page size 256 Bytes, erase size 64 KiB, total 16 MiB
Warning: ethernet@e000b000 using MAC address from ROM
eth0: ethernet@e000b000
U-BOOT for Zybo Z7
ethernet@e000b000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Device: sdhci@e0100000
Manufacturer ID: 2
OEM: 544d
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 28.9 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
175699084 bytes read in 14522 ms (11.5 MiB/s)
Using 'conf@system-top.dtb' configuration
Verifying Hash Integrity ... OK
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x10000104
Data Size: 4141576 Bytes = 3.9 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00008000
Entry Point: 0x00008000
Hash algo: sha1
Hash value: ee101cd85c9e1944c48b03932c53e7fcebd910ff
## Loading ramdisk from FIT Image at 10000000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: petalinux-user-image
Type: RAMDisk Image
Compression: gzip compressed
Data Start: 0x103f83c8
Data Size: 171535160 Bytes = 163.6 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: ed7f21878f106644088ca6674052f08c4199b8fc
Trying 'fdt@system-top.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x103f340c
Data Size: 20218 Bytes = 19.7 KiB
Architecture: ARM
Hash algo: sha1
Hash value: 3dc82d18e3b0fb19449b48cb2a8b4ddb906230d2
Booting using the fdt blob at 0x103f340c
Loading Kernel Image ... OK
pc : [<3ff8f578>] lr : [<3ff640b8>]
reloc pc : [<0403e578>] lr : [<040130b8>]
sp : 3f330a90 ip : 00000090 fp : 3ff51d4c
r10: 3ffb0fb4 r9 : 3f330ee8 r8 : 3ffb0f9c
r7 : 0a396b38 r6 : 08000000 r5 : 103f83c8 r4 : 3ffb0f98
r3 : 1274f3c7 r2 : efc07c38 r1 : fffc0000 r0 : fdc69000
Flags: nzCv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
resetting ...
watari
Hi @mspalpsahan
Because the loading address was wrong, Zynq went to wrong state.
So, linux kernel (Zynq) crashed due to wrong loading address issue.
Would you change loading address to avoid system reserved address (ex. 0xFxxxxxxx )?
Best regards,
mspalpsahan
hi
thank you very much for intersted.
yes i know. but how am i change to the loading address. please could you send information about issue.
thank you
Alpalsan sahan
watari
Hi @mspalpsahan
I suggest you to refer the following URL.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842374/U-Boot+Images
Or, modify .its file to change loading address.
Best regards,
mspalpsahan
hi
i did find  the .its file. but i was not find to load adress. this file follow
* U-Boot uImage source file with multiple kernels, ramdisks and FDT blobs
/dts-v1/;
description = "Various kernels, ramdisks and FDT blobs";
#address-cells = <1>;
images {
kernel-1 {
description = "vanilla-2.6.23";
data = /incbin/("./vmlinux.bin.gz");
type = "kernel";
arch = "ppc";
os = "linux";
compression = "gzip";
load = <00000000>;
entry = <00000000>;
hash-1 {
algo = "md5";
hash-2 {
algo = "sha1";
kernel-2 {
description = "2.6.23-denx";
data = /incbin/("./2.6.23-denx.bin.gz");
type = "kernel";
arch = "ppc";
os = "linux";
load = <00000000>;
entry = <00000000>;
hash-1 {
algo = "sha1";
kernel-3 {
description = "2.4.25-denx";
data = /incbin/("./2.4.25-denx.bin.gz");
type = "kernel";
arch = "ppc";
os = "linux";
load = <00000000>;
entry = <00000000>;
hash-1 {
algo = "md5";
ramdisk-1 {
description = "eldk-4.2-ramdisk";
data = /incbin/("./eldk-4.2-ramdisk");
type = "ramdisk";
arch = "ppc";
os = "linux";
load = <00000000>;
entry = <00000000>;
hash-1 {
algo = "sha1";
ramdisk-2 {
description = "eldk-3.1-ramdisk";
data = /incbin/("./eldk-3.1-ramdisk");
type = "ramdisk";
arch = "ppc";
os = "linux";
load = <00000000>;
entry = <00000000>;
hash-1 {
algo = "crc32";
fdt-1 {
description = "tqm5200-fdt";
data = /incbin/("./tqm5200.dtb");
type = "flat_dt";
arch = "ppc";
compression = "none";
hash-1 {
algo = "crc32";
fdt-2 {
description = "tqm5200s-fdt";
data = /incbin/("./tqm5200s.dtb");
type = "flat_dt";
arch = "ppc";
load = <00700000>;
hash-1 {
algo = "sha1";
configurations {
default = "config-1";
config-1 {
description = "tqm5200 vanilla-2.6.23 configuration";
kernel = "kernel-1";
ramdisk = "ramdisk-1";
fdt = "fdt-1";
config-2 {
description = "tqm5200s denx-2.6.23 configuration";
kernel = "kernel-2";
fdt = "fdt-2";
config-3 {
description = "tqm5200s denx-2.4.25 configuration";
kernel = "kernel-3";
ramdisk = "ramdisk-2";
watari
Hi @mspalpsahan
Did you use this its file when you build linux ?
Because load and entry address are same as 0, it seems wrong.
Would you make sure it and building kernel procedure ?
Best regards,
mspalpsahan
hi
thank you ver much for intersted.
i sure, kernel build. but i think it is not use this file
successfully configured u-boot
alp_xilinx@alpxilinx-VirtualBox:/opt/pkg/petalinux/2019.1/plate_linux$ petalinux-build
[INFO] building project
[INFO] sourcing bitbake
[INFO] generating user layers
INFO: bitbake petalinux-user-image
Loading cache: 100% |############################################| Time: 0:00:02
Loaded 3811 entries from dependency cache.
Parsing recipes: 100% |##########################################| Time: 0:00:12
Parsing of 2777 .bb files complete (2776 cached, 1 parsed). 3812 targets, 163 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |#######################################| Time: 0:00:20
Checking sstate mirror object availability: 100% |###############| Time: 0:01:11
Sstate summary: Wanted 218 Found 17 Missed 402 Current 1357 (7% match, 87% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: Tasks Summary: Attempted 5267 tasks of which 5259 didn't need to be rerun and all succeeded.
INFO: Copying Images from deploy to images
NOTE: Failed to copy built images to tftp dir: /tftpboot
[INFO] successfully built project
mspalpsahan
All hi
Pls can you help me about issue?
xiayanqian
