Observer rgallic_incjet
Locally included header not found
How do I get Petalinux to find a new header file added to the application directory?
I added a new header file, same directory as the source file.
Petalinux will not build, states the header file does not exist.
Petalinux 2016.02
Re: Locally included header not found
Try adding below command in Application Make file instead adding it as a source file.
Let's consider that test is the applicationa and header file is in test/include then
try adding EXTRA_CFLAGS=-I <path of include file>
Best Regards
Kranthi
