Observer rgallic_incjet
Location of DTB
Can anybody tell me where the DTB file is embedded, linux 3.6, Petalinux 2013.04?
Is it in the FSBL or is it embedded in the Linux image?
Re: Location of DTB
FSBL never knows anything about DTB file and hence it doesnt have DTB embedded in it.
image.ub, which is the linux kernel image created after petalinux-build has 3 components: Kernel, DTB and rootfs embedded into it.
If you want individual DTB file, then you must find a file with name system.dtb in your petalinux project directory (find . -name system.dtb)
Best REgards
Shabbir
Re: Location of DTB
OK, so this means it doesn't matter what version of boot.bin I use other than being certain the bitstream file is correct. The DTB is embedded into the image.ub file?
Re: Location of DTB
The version matter because BIN contains - FSBL of the version(if any updates available), bitstream (of the same version), PMUFW etc.
Yes DTB is present in image.ub.
Praveen
Re: Location of DTB
Yes, image.ub is a FIT image which has Kernel Image (zImage), Rootfs (RAMDISK) and DTB (system.dtb).
Debraj
