08-13-2010 05:22 PM
Hi community; I'm working with the Spartan 3E Starter Kit and I2C, under microblaze the I2C core works fine with a simple code to read an ADC but when I tried to use the I2C under ucLinux (same HW, and petalinux 0.4 distro, edk 10.1) I get the an error message, I select during the kernel setup process " device drivers -- I2C --I2C support -- I2C Alg -- Xlinx I2C " , also during the uclinux start up , the I2C can not get a irq assigned ( its assigned on HW with low priority ).
Some transcripts...
Startup msg.
uclinux[mtd]: set ROMfs to be root filesystem index=0
i2c /dev entries driver
xilinx_iic xilinx_iic.0: could not allocate interrupt 3.
xilinx_iic: probe of xilinx_iic.0 failed with error -22
TCP cubic registered
Using C program on uclinux
Can not access driver (/dev/i2c-0)!
and..
# ls /dev/i2c-
/dev/i2c-0 /dev/i2c-2 /dev/i2c-4 /dev/i2c-6
/dev/i2c-1 /dev/i2c-3 /dev/i2c-5 /dev/i2c-7
# cat /dev/i2c-0
cat: /dev/i2c-0: No such device
idem for all.....
Some HW
BEGIN xps_iic
PARAMETER INSTANCE = I2C
PARAMETER HW_VER = 2.00.a
PARAMETER C_CLK_FREQ = 50000000
PARAMETER C_BASEADDR = 0x81600000
PARAMETER C_HIGHADDR = 0x8160ffff
BUS_INTERFACE SPLB = mb_plb
PORT Scl = I2C_Scl
PORT Sda = I2C_Sda
PORT IIC2INTC_Irpt = I2C_IIC2INTC_Irpt
END
....Int_c.....
PORT Intr = I2C_IIC2INTC_Irpt&RS232_DCE_Interrupt&Ethernet_MAC_IP2INTC_Irpt&xps_timer_1_Interrupt
BEGIN DRIVER
PARAMETER DRIVER_NAME = iic
PARAMETER DRIVER_VER = 1.13.b
PARAMETER HW_INSTANCE = I2C
END
Any Idea will be very, very appreciated.
Thanks in advance.
08-23-2010 04:10 AM
Dear Sir,
I tried to investigate your problem, and to make the same conditions as yours in my system in order to see if the error messages you mentioned here will happen.
my base system is similir to yours and i am using petalinux 0.4 for this specific test.
I have enabled all of the required i2c drivers in my petalinux kernel, and I have inserted them into the kernel.
Here is my kernel boot log ( the section that you are interested in)
erase region 0: offset=0x0,size=0x20000,blocks=256
RedBoot partition parsing not available
i2c-core: driver [dev_driver] registered
i2c_adapter i2c-0: adapter [xilinx_iic.0] registered
i2c-dev: adapter [xilinx_iic.0] registered as minor 0
xilinx_iic.0 #0 at 0x90000000 mapped to 0xC4004000, irq=3
so as you see there is no such error,
now when the kernel comes up, here is the outcome of the cat /dev/i2c-0 command:
/dev # cat i2c-0
i2c-dev: i2c-0 reading 4096 bytes.
i2c_adapter i2c-0: master_xfer[0] R, addr=0x00, len=4096
xilinx_iic.0 #0: Unexpected error 1078.
/dev #
as you see the driver is working, about error 1078, i dont know what it is but i guess it is related to some required pre-configurations that i have not done in my system. ( it is not directly related to driver )
some portions of my MHS file
BEGIN xps_intc
PARAMETER INSTANCE = xps_intc_0
PARAMETER C_BASEADDR = 0x81800000
PARAMETER C_HIGHADDR = 0x8180ffff
PORT Intr = xps_iic_0_IIC2INTC_Irpt&RS232_DCE_Interrupt&Ethernet_MAC_IP2INTC_Irpt&xps_timer_0_Interrupt
PORT Irq = microblaze_0_Interrupt
END
BEGIN xps_iic
PARAMETER INSTANCE = xps_iic_0
PARAMETER HW_VER = 2.01.a
PARAMETER C_BASEADDR = 0x90000000
PARAMETER C_HIGHADDR = 0x90001FFF
PORT IIC2INTC_Irpt = xps_iic_0_IIC2INTC_Irpt
END
My kernel .config file
# I2C support
CONFIG_I2C=y
CONFIG_I2C_CHARDEV=y
# I2C Algorithms
# CONFIG_I2C_ALGOBIT is not set
# CONFIG_I2C_ALGOPCF is not set
# CONFIG_I2C_ALGOPCA is not set
CONFIG_XILINX_IIC=y
hope helped,
Mohammad Sadegh Sadri
08-24-2010 03:46 PM
Thanks for your reply and your time, after seen your logs and files (almost the same configuration that me) I start to review the kernel configuration, the I2C and was the same. Then I find under "Platform options -- Definitions of INTC_0 " the maximum number of interrupts, after increase NUM_INTR_INPUTS range to 4, the kernel was able to assign an Irq to the I2C, and the software starts to work, just fine!.
Thanks again for you time and answer.
