sbansal
MIO 53 as interrupt for I2c slave device MAX30102
Hi all,
I am trying to setup the device tree for MAX30102 I2c slave device. The i2c communications works OK but the interrupt pin of MAX30102 is connected to the GPIO MIO 53. I am want to be able to read this interrupt but I am unable to. It is a active low interrupt pin.
I tried to add this to my device tree but am unable to see it being detected in the cat /proc/interrupts.
Can anybody provide any insight?
here is my device tree :
        gpio0: gpio@e000a000 {
            compatible = "xlnx,zynq-gpio-1.0";
            #gpio-cells = <0x2>;
            clocks = <0x1 0x2a>;
            gpio-controller;
            interrupt-controller;
            #interrupt-cells = <0x2>;
            interrupt-parent = <0x3>;
            interrupts = <0x0 0x14 0x4>;
            reg = <0xe000a000 0x1000>;
            emio-gpio-width = <0x40>;
            gpio-mask-high = <0x0>;
            gpio-mask-low = <0x5600>;
            linux,phandle = <0x5>;
            phandle = <0x5>;
        i2c@e0004000 {
            compatible = "cdns,i2c-r1p10";
            status = "okay";
            clocks = <0x1 0x26>;
            interrupts = <0x0 0x19 0x4>;
            reg = <0xe0004000 0x1000>;
            #address-cells = <0x1>;
            #size-cells = <0x0>;
            clock-frequency = <0x61a80>;
            max30100@57 {
                       compatible = "maxim,max30102";
                       reg = <0x57>;
                       maxim,red-led-current-microamp = <7000>;
                       maxim,ir-led-current-microamp = <7000>;
                       interrupt-parent = <&gpio0>;
                       interrupts = <53 8>;
Thanks in advance.
sbansal
bumping it .. any comments
