Visitor tiebingzhang
ML507 System ACE Linux Driver initialization fails
Dear all, I have a ML507 board running Linux 2.6.31, and am trying to use the Compact Flash card as a storage device for the embedded Linux. The compact flash can be used to burn the bits-stream and kernel images fine. After enabling the system ace device in the FPGA design and in the linux kernel, when the kernel boot I get this error message: xsysace 83600000.sysace: ace_of_probe(cadfba80, d1159bf4) xsysace 83600000.sysace: ace_alloc(cadfba90) xsysace 83600000.sysace: ace_setup(ace=0xc905ac00) xsysace 83600000.sysace: physaddr=0x83600000 irq=20 xsysace 83600000.sysace: error: invalid version xsysace 83600000.sysace: xsysace: error initializing device at 0x83600000 xsysace 83600000.sysace: could not initialize device, err=-12 xsysace: probe of 83600000.sysace failed with error -12 (DEBUG is enabled in the driver) It looks like that driver is not able to talk to the System ACE controller at all (could not even get the VERSION number of the controller). You help is greatly appreciated in getting this to work.
Re: ML507 System ACE Linux Driver initialization fails
Guys, Thanks for your help. Our problem is solved. The problem: The FPGA pin assignment was wrong so it appeared that the hardware was not there, just as we have suspected!!
Thanks again for your help.
Can you please post the relevant sections of your DTS and MHS files? I haven't heard of any problems with this and just recently built a design for the ML507 using the SystemACE controller, so I'm not aware of any underlying problems.
Also, is this a PPC design or a MicroBlaze design?
Cheers,
Rob
This is the DTS file section: xps_sysace_0: sysace@83600000 { compatible = "xlnx,xps-sysace-1.01.a", "xlnx,xps-sysace-1.00.a"; interrupt-parent = <&xps_intc_0>; interrupts = < 5 2 >; reg = < 0x83600000 0x10000 >; xlnx,family = "virtex5"; xlnx,mem-width = <0x10>; } ; I am the software guy working on this. Not sure what the other file is. Thanks.
Better formatted DTS file:
Oh, it is a PowerPC design.
The other file is the hardware specification file. I want to check if the SystemACE IP is configured correctly. You should be able to get the file from the hardware designer - it's a plain text file organized similarly to the DTS file.
Below is the related section. The full file is attached in this post.
BEGIN xps_sysace
 PARAMETER INSTANCE = xps_sysace_0
 PARAMETER HW_VER = 1.01.a
 PARAMETER C_BASEADDR = 0x83600000
 PARAMETER C_HIGHADDR = 0x8360ffff
 BUS_INTERFACE SPLB = plb_v46_0
 PORT SysACE_MPA = fpga_0_SysACE_CompactFlash_SysACE_MPA
 PORT SysACE_CLK = fpga_0_SysACE_CompactFlash_SysACE_CLK
 PORT SysACE_MPIRQ = fpga_0_SysACE_CompactFlash_SysACE_MPIRQ
 PORT SysACE_CEN = fpga_0_SysACE_CompactFlash_SysACE_CEN
 PORT SysACE_OEN = fpga_0_SysACE_CompactFlash_SysACE_OEN
 PORT SysACE_WEN = fpga_0_SysACE_CompactFlash_SysACE_WEN
 PORT SysACE_IRQ = SysACE_CompactFlash_SysACE_IRQ
 PORT SysACE_MPD = fpga_0_SysACE_CompactFlash_SysACE_MPD
END
PORT fpga_0_SysACE_CompactFlash_SysACE_MPA_pin = fpga_0_SysACE_CompactFlash_SysACE_MPA, DIR = O, VEC = [6:0]
 PORT fpga_0_SysACE_CompactFlash_SysACE_CLK_pin = fpga_0_SysACE_CompactFlash_SysACE_CLK, DIR = I
 PORT fpga_0_SysACE_CompactFlash_SysACE_MPIRQ_pin = fpga_0_SysACE_CompactFlash_SysACE_MPIRQ, DIR = I
 PORT fpga_0_SysACE_CompactFlash_SysACE_CEN_pin = fpga_0_SysACE_CompactFlash_SysACE_CEN, DIR = O
 PORT fpga_0_SysACE_CompactFlash_SysACE_OEN_pin = fpga_0_SysACE_CompactFlash_SysACE_OEN, DIR = O
 PORT fpga_0_SysACE_CompactFlash_SysACE_WEN_pin = fpga_0_SysACE_CompactFlash_SysACE_WEN, DIR = O
 PORT fpga_0_SysACE_CompactFlash_SysACE_MPD_pin = fpga_0_SysACE_CompactFlash_SysACE_MPD, DIR = IO, VEC = [15:0]
Hi ,
We are running our nightly linux regression test and the sysace driver is working fine for virtex5 (PPC). we are using 13.1 edk tools and 2.6.37 kernel. Prior to 13.1 it was also tested with 12.2 edk.
I donot see why its not working at your end.Can you also share your linux config file.
Madhubala
We use ELDK 4.2 and 2.6.31. Yesterday the hardware engineer and I together reviewed the Xilinux project file and compare it with the "examples" provided by Xilinx. The system-ace section looks the same.
Attached please find the kernel config file. I don't think this is the issue since we've also tried directly run the systemace test example from Xilinx and it could not talk to the system ace controller either.
Thanks for helping me with this.
