ML605 Microblaze initramfs hanging
Hi, I am struggling to find out the reason why iniramfs hanging as this:
early_printk_console is enabled at 0x84000000
Ramdisk addr 0x00000003, Compiled-in FDT at 0xb00f8b68
Linux version 2.6.34-00671-g91e2c43-dirty (xying@magellan) (gcc version 4.1.2) #
24 Fri Jul 9 11:56:35 EST 2010
setup_cpuinfo: initialising
setup_cpuinfo: No PVR support. Using static CPU info from FDT
cache: wt_msr_noirq
setup_memory: max_mapnr: 0x10000
setup_memory: min_low_pfn: 0xb0000
setup_memory: max_low_pfn: 0xc0000
On node 0 totalpages: 65536
free_area_init_node: node 0, pgdat b015750c, node_mem_map b025c000
  Normal zone: 512 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 65024 pages, LIFO batch:15
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: console=ttyUL0 root=/dev/ram
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 257216k/262144k available
Hierarchical RCU implementation.
NR_IRQS:32
xlnx,xps-intc-1.00.a #0 at 0xc0000000, num_irq=3, edge=0x3
xlnx,xps-timer-1.00.a #0 at 0xc0004000, irq=1
Heartbeat GPIO at 0xc0008000
microblaze_timer_set_mode: shutdown
microblaze_timer_set_mode: periodic
Calibrating delay loop... 49.15 BogoMIPS (lpj=245760)
Mount-cache hash table entries: 512
XGpio: /plb@0/gpio@81460000: registered
XGpio: /plb@0/gpio@81440000: registered
XGpio: /plb@0/gpio@81420000: registered
XGpio: /plb@0/gpio@81400000: registered
Switching to clocksource microblaze_clocksource
Skipping unavailable RESET gpio -2 (reset)
GPIO pin is already allocated
msgmni has been set to 502
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
84000000.serial: ttyUL0 at MMIO 0x84000003 (irq = 0) is a uartlite
console [ttyUL0] enabled
Freeing unused kernel memory: 873k freed
I am using ML605 board and microblaze linux plus prebuilt initramfs_minimal.cpio.gz by xilinx.
I attached the zip file for  the .config for microblaze linux, .dts, .mhs files.
Could someone give me clue?
I've not seen the ram disk address displayed on the command line before. Are you building with initramfs support in the kernel? How are you booting the kernel? Xmd? I haven't looked at your config file yet, but I'll have a peek tomorrow.
Here is the line that I find strange, because 0x03 is the last byte of the reset memory address for the microblaze, AND it is not 32-bit aligned. Do you know where this address might be coming from?
I loaded kernel image from XMD. Yes. The kernel is built with initramfs support.
The strange bit is if I config the kernel without 'Set custom kernel base address'. It just hangs at beginning like this:
But if I set the custom kernel base address the same address as Physical address where Linux Kernel is (0xb0000000), then what I got is as mentioned in the initial question like this:
cache: wt_msr_noirq
NR_IRQS:32
It seems like you're not configuring the kernel right.
Have u reviewed http://xilinx.wikidot.com/microblaze-linux?
You shouldn't mess with 'Set custom kernel base address' as that may be your problem.
I do following the instruction as in http://xilinx.wikidot.com/microblaze-linux?
I haven't found anything wrong so far.
