MPSoC AXI DMA Proxy Kernel Module Fails to Load
Hello I am trying to use the DMA Proxy Driver from this post on Zynq UltraScale+.
https://forums.xilinx.com/t5/Embedded-Linux/BRAM-DMA-transfer-limitation/m-p/555953#M11603
I am able to build the kernel module and application into the kernel, but when I try to load the kernel module I get these failure messages.
root@dma_basic_project_linux:~# insmod /lib/modules/4.14.0-xilinx-v2018.2/extra/dma-proxy.ko
[   62.549578] dma_proxy: loading out-of-tree module taints kernel.
[   62.555836] dma_proxy module initialized
[   62.561254] Allocating uncached memory at 0x00000000
[   62.566160] dma dma1chan0: DMA allocation error
insmod: can't insert '/lib/modules/4.14.0-xilinx-v2018.2/extra/dma-proxy.ko': Operation not permitted
[   65.677875] dma_proxy module initialized
[   65.682213] sysfs: cannot create duplicate filename '/class/dma_proxy'
[   65.688681] ------------[ cut here ]------------
[   65.693263] WARNING: CPU: 1 PID: 2237 at /kernel-source//fs/sysfs/dir.c:31 sysfs_warn_dup+0x5c/0x78
[   65.702283] Modules linked in: dma_proxy(O+) uio_pdrv_genirq
[   65.707926] CPU: 1 PID: 2237 Comm: insmod Tainted: G           O    4.14.0-xilinx-v2018.2 #1
[   65.716344] Hardware name: xlnx,zynqmp (DT)
[   65.720508] task: ffffffc06c0a1200 task.stack: ffffff800bf00000
[   65.726412] PC is at sysfs_warn_dup+0x5c/0x78
[   65.730751] LR is at sysfs_warn_dup+0x5c/0x78
[   65.735090] pc : [<ffffff80082125ac>] lr : [<ffffff80082125ac>] pstate: 60000145
[   65.742470] sp : ffffff800bf03aa0
[   65.745766] x29: ffffff800bf03aa0 x28: ffffff800bf05000
[   65.751061] x27: ffffff8000a52100 x26: ffffff8000a51290
[   65.756356] x25: 0000000000000001 x24: ffffff8000a52438
[   65.761651] x23: ffffff8000a51028 x22: ffffffc06d90ca18
[   65.766946] x21: ffffffc06d836e80 x20: ffffffc06b5ce200
[   65.772241] x19: ffffffc06d3e1000 x18: 0000000000000010
[   65.777535] x17: 00000000004a59b0 x16: 0000000000000001
[   65.782830] x15: ffffffffffffffff x14: 0720072007200720
[   65.788125] x13: 0720072007200727 x12: 07790778076f0772
[   65.793420] x11: 0770075f0761076d x10: 0764072f07730773
[   65.798714] x9 : 0761076c0763072f x8 : 072707200765076d
[   65.804009] x7 : 0761076e0765076c x6 : 0000000000000168
[   65.809304] x5 : ffffff800849d410 x4 : 0000000000000000
[   65.814599] x3 : 0000000000000000 x2 : ffffffffffffffff
[   65.819894] x1 : ffffff8008dfce68 x0 : 000000000000003a
[   65.825189] Call trace:
[   65.827619] Exception stack(0xffffff800bf03960 to 0xffffff800bf03aa0)
[   65.834045] 3960: 000000000000003a ffffff8008dfce68 ffffffffffffffff 0000000000000000
[   65.841859] 3980: 0000000000000000 ffffff800849d410 0000000000000168 0761076e0765076c
[   65.849671] 39a0: 072707200765076d 0761076c0763072f 0764072f07730773 0770075f0761076d
[   65.857483] 39c0: 07790778076f0772 0720072007200727 0720072007200720 ffffffffffffffff
[   65.865294] 39e0: 0000000000000001 00000000004a59b0 0000000000000010 ffffffc06d3e1000
[   65.873107] 3a00: ffffffc06b5ce200 ffffffc06d836e80 ffffffc06d90ca18 ffffff8000a51028
[   65.880919] 3a20: ffffff8000a52438 0000000000000001 ffffff8000a51290 ffffff8000a52100
[   65.888731] 3a40: ffffff800bf05000 ffffff800bf03aa0 ffffff80082125ac ffffff800bf03aa0
[   65.896542] 3a60: ffffff80082125ac 0000000060000145 ffffffc06b5ce200 0000000000000073
[   65.904355] 3a80: 0000008000000000 0000000000000000 ffffff800bf03aa0 ffffff80082125ac
[   65.912166] [<ffffff80082125ac>] sysfs_warn_dup+0x5c/0x78
[   65.917546] [<ffffff80082126e4>] sysfs_create_dir_ns+0xac/0xb8
[   65.923364] [<ffffff8008a1871c>] kobject_add_internal+0x9c/0x2c8
[   65.929352] [<ffffff8008a1899c>] kset_register+0x54/0x98
[   65.934648] [<ffffff8008582ba4>] __class_register+0xbc/0x170
[   65.940288] [<ffffff8008582cac>] __class_create+0x54/0x80
[   65.945675] [<ffffff8000a50558>] create_channel+0x120/0x300 [dma_proxy]
[   65.952270] [<ffffff8000a55028>] dma_proxy_init+0x28/0x1000 [dma_proxy]
[   65.958865] [<ffffff8008083980>] do_one_initcall+0x38/0x128
[   65.964420] [<ffffff800810bcd0>] do_init_module+0x58/0x1b0
[   65.969887] [<ffffff800810ac44>] load_module+0x19fc/0x2150
[   65.975355] [<ffffff800810b490>] SyS_init_module+0xf8/0x178
[   65.980909] Exception stack(0xffffff800bf03ec0 to 0xffffff800bf04000)
[   65.987334] 3ec0: 000000003080a2e0 0000000000002f00 000000003080a260 000000003080a280
[   65.995147] 3ee0: 0000000000000000 0000007f93585580 0000007f93660700 0000007f93660700
[   66.002959] 3f00: 0000000000000069 0000000000003001 0101010101010101 0000000000000000
[   66.010771] 3f20: 0000000000000018 0000000000005b76 0000007f93448d98 0000007f9343bd00
[   66.018583] 3f40: 0000007f93500a80 00000000004a59b0 000000000000073f 0000007f93660720
[   66.026395] 3f60: 000000003080a2e0 000000003080a260 0000000000000002 0000007ff8e21198
[   66.034207] 3f80: 0000000000000049 0000000000000000 00000000004a5000 0000000000000000
[   66.042019] 3fa0: 0000000000000000 0000007ff8e21060 000000000040f368 0000007ff8e20f40
[   66.049831] 3fc0: 0000007f93500aa4 0000000080000000 000000003080a2e0 0000000000000069
[   66.057643] 3fe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   66.065455] [<ffffff80080837b0>] el0_svc_naked+0x24/0x28
[   66.070746] ---[ end trace c54ee1296e7b908c ]---
[   66.075371] kobject_add_internal failed for dma_proxy with -EEXIST, don't try to register things with the same name in the same directory.
[   66.087814] ------------[ cut here ]------------
[   66.092364] WARNING: CPU: 1 PID: 2237 at /kernel-source//lib/kobject.c:240 kobject_add_internal+0x194/0x2c8
[   66.102083] Modules linked in: dma_proxy(O+) uio_pdrv_genirq
[   66.107725] CPU: 1 PID: 2237 Comm: insmod Tainted: G        W  O    4.14.0-xilinx-v2018.2 #1
[   66.116145] Hardware name: xlnx,zynqmp (DT)
[   66.120309] task: ffffffc06c0a1200 task.stack: ffffff800bf00000
[   66.126213] PC is at kobject_add_internal+0x194/0x2c8
[   66.131247] LR is at kobject_add_internal+0x194/0x2c8
[   66.136280] pc : [<ffffff8008a18814>] lr : [<ffffff8008a18814>] pstate: 00000145
[   66.143659] sp : ffffff800bf03b00
[   66.146955] x29: ffffff800bf03b00 x28: ffffff800bf05000
[   66.152251] x27: ffffff8000a52100 x26: ffffff8000a51290
[   66.157545] x25: 0000000000000001 x24: ffffff8000a52438
[   66.162840] x23: ffffff8000a51028 x22: ffffffc06d90ca18
[   66.168135] x21: 00000000ffffffef x20: ffffffc06b5cef80
[   66.173430] x19: ffffffc06c11ba18 x18: 0000000000000010
[   66.178725] x17: 00000000004a59b0 x16: 0000000000000001
[   66.184020] x15: ffffffffffffffff x14: 0720072007200720
[   66.189315] x13: 0720072007200720 x12: 0720072007200720
[   66.194609] x11: 0720072007200720 x10: 072007200720072e
[   66.199904] x9 : 07790772076f0774 x8 : 0763076507720769
[   66.205199] x7 : 076407200765076d x6 : 00000000000001a7
[   66.210494] x5 : 0000000000000000 x4 : 0000000000000000
[   66.215788] x3 : 0000000000000000 x2 : ffffffc07fe93568
[   66.221083] x1 : 00000040770c4000 x0 : 000000000000007e
[   66.226378] Call trace:
[   66.228808] Exception stack(0xffffff800bf039c0 to 0xffffff800bf03b00)
[   66.235235] 39c0: 000000000000007e 00000040770c4000 ffffffc07fe93568 0000000000000000
[   66.243048] 39e0: 0000000000000000 0000000000000000 00000000000001a7 076407200765076d
[   66.250860] 3a00: 0763076507720769 07790772076f0774 072007200720072e 0720072007200720
[   66.258672] 3a20: 0720072007200720 0720072007200720 0720072007200720 ffffffffffffffff
[   66.266484] 3a40: 0000000000000001 00000000004a59b0 0000000000000010 ffffffc06c11ba18
[   66.274296] 3a60: ffffffc06b5cef80 00000000ffffffef ffffffc06d90ca18 ffffff8000a51028
[   66.282108] 3a80: ffffff8000a52438 0000000000000001 ffffff8000a51290 ffffff8000a52100
[   66.289920] 3aa0: ffffff800bf05000 ffffff800bf03b00 ffffff8008a18814 ffffff800bf03b00
[   66.297732] 3ac0: ffffff8008a18814 0000000000000145 ffffffc06b5ce200 0000000000000000
[   66.305544] 3ae0: 0000008000000000 ffffff800849d410 ffffff800bf03b00 ffffff8008a18814
[   66.313357] [<ffffff8008a18814>] kobject_add_internal+0x194/0x2c8
[   66.319430] [<ffffff8008a1899c>] kset_register+0x54/0x98
[   66.324726] [<ffffff8008582ba4>] __class_register+0xbc/0x170
[   66.330368] [<ffffff8008582cac>] __class_create+0x54/0x80
[   66.335752] [<ffffff8000a50558>] create_channel+0x120/0x300 [dma_proxy]
[   66.342349] [<ffffff8000a55028>] dma_proxy_init+0x28/0x1000 [dma_proxy]
[   66.348943] [<ffffff8008083980>] do_one_initcall+0x38/0x128
[   66.354498] [<ffffff800810bcd0>] do_init_module+0x58/0x1b0
[   66.359966] [<ffffff800810ac44>] load_module+0x19fc/0x2150
[   66.365435] [<ffffff800810b490>] SyS_init_module+0xf8/0x178
[   66.370988] Exception stack(0xffffff800bf03ec0 to 0xffffff800bf04000)
[   66.377413] 3ec0: 000000003080a2e0 0000000000002f00 000000003080a260 000000003080a280
[   66.385226] 3ee0: 0000000000000000 0000007f93585580 0000007f93660700 0000007f93660700
[   66.393038] 3f00: 0000000000000069 0000000000003001 0101010101010101 0000000000000000
[   66.400850] 3f20: 0000000000000018 0000000000005b76 0000007f93448d98 0000007f9343bd00
[   66.408662] 3f40: 0000007f93500a80 00000000004a59b0 000000000000073f 0000007f93660720
[   66.416474] 3f60: 000000003080a2e0 000000003080a260 0000000000000002 0000007ff8e21198
[   66.424286] 3f80: 0000000000000049 0000000000000000 00000000004a5000 0000000000000000
[   66.432098] 3fa0: 0000000000000000 0000007ff8e21060 000000000040f368 0000007ff8e20f40
[   66.439910] 3fc0: 0000007f93500aa4 0000000080000000 000000003080a2e0 0000000000000069
[   66.447722] 3fe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   66.455534] [<ffffff80080837b0>] el0_svc_naked+0x24/0x28
[   66.460825] ---[ end trace c54ee1296e7b908d ]---
[   66.465444] dma dma1chan1: unable to create the device
[   66.470563] Unable to handle kernel NULL pointer dereference at virtual address 000001fd
[   66.478629] Mem abort info:
[   66.481403]   Exception class = DABT (current EL), IL = 32 bits
[   66.487307]   SET = 0, FnV = 0
[   66.490342]   EA = 0, S1PTW = 0
[   66.493467] Data abort info:
[   66.496331]   ISV = 0, ISS = 0x00000006
[   66.500151]   CM = 0, WnR = 0
[   66.503097] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc06cd87000
[   66.509615] [00000000000001fd] *pgd=000000006c0a5003, *pud=000000006c0a5003, *pmd=0000000000000000
[   66.518556] Internal error: Oops: 96000006 [#1] SMP
[   66.523408] Modules linked in: dma_proxy(O+) uio_pdrv_genirq
[   66.529052] CPU: 1 PID: 2237 Comm: insmod Tainted: G        W  O    4.14.0-xilinx-v2018.2 #1
[   66.537472] Hardware name: xlnx,zynqmp (DT)
[   66.541636] task: ffffffc06c0a1200 task.stack: ffffff800bf00000
[   66.547544] PC is at create_channel+0x1ec/0x300 [dma_proxy]
[   66.553098] LR is at create_channel+0x1a8/0x300 [dma_proxy]
[   66.558649] pc : [<ffffff8000a50624>] lr : [<ffffff8000a505e0>] pstate: 60000145
[   66.566028] sp : ffffff800bf03bc0
[   66.569324] x29: ffffff800bf03bc0 x28: ffffff800bf05000
[   66.574620] x27: ffffff8000a52100 x26: ffffff8000a51290
[   66.579914] x25: 0000000000000001 x24: ffffff8000a52438
[   66.585209] x23: ffffff8000a51028 x22: ffffffffffffffef
[   66.590504] x21: ffffffffffffffed x20: 0000000000000000
[   66.595799] x19: ffffff8000a52410 x18: 0000000000000010
[   66.601094] x17: 00000000004a59b0 x16: 0000000000000001
[   66.606389] x15: ffffffffffffffff x14: 0720072007200720
[   66.611683] x13: 0720072007200720 x12: 0720072007200720
[   66.616978] x11: 0720072007200720 x10: 0720072007200720
[   66.622273] x9 : 0720072007200765 x8 : 0763076907760765
[   66.627568] x7 : 0764072007650768 x6 : 00000000000001e4
[   66.632862] x5 : 00000000000000f3 x4 : ffffffbf0177ecc7
[   66.638157] x3 : ffffffbf0177ecc8 x2 : 000000000f200001
[   66.643452] x1 : 0000000000000024 x0 : 0000000000000000
[   66.648748] Process insmod (pid: 2237, stack limit = 0xffffff800bf00000)
[   66.655431] Call trace:
[   66.657861] Exception stack(0xffffff800bf03a80 to 0xffffff800bf03bc0)
[   66.664287] 3a80: 0000000000000000 0000000000000024 000000000f200001 ffffffbf0177ecc8
[   66.672101] 3aa0: ffffffbf0177ecc7 00000000000000f3 00000000000001e4 0764072007650768
[   66.679913] 3ac0: 0763076907760765 0720072007200765 0720072007200720 0720072007200720
[   66.687724] 3ae0: 0720072007200720 0720072007200720 0720072007200720 ffffffffffffffff
[   66.695536] 3b00: 0000000000000001 00000000004a59b0 0000000000000010 ffffff8000a52410
[   66.703348] 3b20: 0000000000000000 ffffffffffffffed ffffffffffffffef ffffff8000a51028
[   66.711160] 3b40: ffffff8000a52438 0000000000000001 ffffff8000a51290 ffffff8000a52100
[   66.718973] 3b60: ffffff800bf05000 ffffff800bf03bc0 ffffff8000a505e0 ffffff800bf03bc0
[   66.726785] 3b80: ffffff8000a50624 0000000060000145 000000000f200001 ffffff8000a52438
[   66.734597] 3ba0: 0000008000000000 ffffff8000a505e0 ffffff800bf03bc0 ffffff8000a50624
[   66.742412] [<ffffff8000a50624>] create_channel+0x1ec/0x300 [dma_proxy]
[   66.749007] [<ffffff8000a55028>] dma_proxy_init+0x28/0x1000 [dma_proxy]
[   66.755601] [<ffffff8008083980>] do_one_initcall+0x38/0x128
[   66.761156] [<ffffff800810bcd0>] do_init_module+0x58/0x1b0
[   66.766624] [<ffffff800810ac44>] load_module+0x19fc/0x2150
[   66.772093] [<ffffff800810b490>] SyS_init_module+0xf8/0x178
[   66.777646] Exception stack(0xffffff800bf03ec0 to 0xffffff800bf04000)
[   66.784071] 3ec0: 000000003080a2e0 0000000000002f00 000000003080a260 000000003080a280
[   66.791885] 3ee0: 0000000000000000 0000007f93585580 0000007f93660700 0000007f93660700
[   66.799696] 3f00: 0000000000000069 0000000000003001 0101010101010101 0000000000000000
[   66.807508] 3f20: 0000000000000018 0000000000005b76 0000007f93448d98 0000007f9343bd00
[   66.815320] 3f40: 0000007f93500a80 00000000004a59b0 000000000000073f 0000007f93660720
[   66.823132] 3f60: 000000003080a2e0 000000003080a260 0000000000000002 0000007ff8e21198
[   66.830944] 3f80: 0000000000000049 0000000000000000 00000000004a5000 0000000000000000
[   66.838756] 3fa0: 0000000000000000 0000007ff8e21060 000000000040f368 0000007ff8e20f40
[   66.846568] 3fc0: 0000007f93500aa4 0000000080000000 000000003080a2e0 0000000000000069
[   66.854380] 3fe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   66.862192] [<ffffff80080837b0>] el0_svc_naked+0x24/0x28
[   66.867486] Code: 95da2ba1 1400001b f9400a75 b4000075 (f9410aa0)
My guess is that it is failing on dmam_alloc_coherent. I will try setting CACHED_BUFFERS and use kzalloc, but I have not clue why it is failing.
On boot however, it looks like the driver is probed successfully.
[    1.613193] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    1.613578] xilinx-vdma a0000000.dma: Xilinx AXI DMA Engine Driver Probed!!
[    1.613864] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.614009] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.614150] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.614301] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.614445] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.614592] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.614736] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.614881] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.615091] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    1.615235] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    1.615377] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    1.615520] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    1.615664] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    1.615840] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    1.615985] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    1.616126] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
Just for reference, here is my pl.dtsi
 * CAUTION: This file is automatically generated by Xilinx.
 * Version:
 * Today is: Wed Feb  6 08:57:01 2019
	amba_pl: amba_pl@0 {
		#address-cells = <2>;
		#size-cells = <2>;
		compatible = "simple-bus";
		ranges ;
		axi_dma_0: dma@a0000000 {
			#dma-cells = <1>;
			clock-names = "s_axi_lite_aclk", "m_axi_sg_aclk", "m_axi_mm2s_aclk", "m_axi_s2mm_aclk";
			clocks = <&clk 71>, <&clk 71>, <&clk 71>, <&misc_clk_0>;
			compatible = "xlnx,axi-dma-1.00.a";
			interrupt-names = "mm2s_introut", "s2mm_introut";
			interrupt-parent = <&gic>;
			interrupts = <0 89 4 0 90 4>;
			reg = <0x0 0xa0000000 0x0 0x1000>;
			xlnx,addrwidth = <0x28>;
			xlnx,sg-length-width = <0xe>;
			dma-channel@a0000000 {
				compatible = "xlnx,axi-dma-mm2s-channel";
				dma-channels = <0x1>;
				interrupts = <0 89 4>;
				xlnx,datawidth = <0x20>;
				xlnx,device-id = <0x0>;
				xlnx,include-dre ;
			dma-channel@a0000030 {
				compatible = "xlnx,axi-dma-s2mm-channel";
				interrupts = <0 90 4>;
				xlnx,include-dre ;
		psu_ctrl_ipi: PERIPHERAL@ff380000 {
			compatible = "xlnx,PERIPHERAL-1.0";
			reg = <0x0 0xff380000 0x0 0x80000>;
		psu_message_buffers: PERIPHERAL@ff990000 {
			reg = <0x0 0xff990000 0x0 0x10000>;
		misc_clk_0: misc_clk_0 {
			#clock-cells = <0>;
			clock-frequency = <100000002>;
			compatible = "fixed-clock";
Not sure what the misc_clk is doing there, but it seems to map to 100MHz clk "pl_clk0" on hardware design.
If anyone has experienced these issues with dmam_alloc_coherent on UltraScale+, I would appreciate any advice.
Re: MPSoC AXI DMA Proxy Kernel Module Fails to Load
I was able to get the DMA to work using this tutorial.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842418/Linux+DMA+From+User+Space
I did not use High Address under Address Fragmentation in MPSoC setup menu. Everything else is the same.
With a little debugging, it looks like dmam_alloc_coherent is failing.
int can_perform_dma;
can_perform_dma = dma_set_coherent_mask(pchannel_p->proxy_device_p, 0xFFFFFFFF);
printk(KERN_INFO "Card DMA capability: %d\n", can_perform_dma);
pchannel_p->interface_p = (struct dma_proxy_channel_interface *)
dmam_alloc_coherent(pchannel_p->proxy_device_p,
sizeof(struct dma_proxy_channel_interface), &pchannel_p->interface_phys_addr, GFP_KERNEL);
printk(KERN_INFO "Allocating uncached memory at 0x%08X\n", (unsigned int)pchannel_p->interface_p);
dma_set_coherent_mask is faililng, which of course makes dmam_alloc_coherent fail. I changed the hardware designs to ensure that all interfaces from PS had data widths of 32.
