mportola
MTU in Zynq
I am trying to set the MTU in my ZC706 using ioctl, but I have an upper bound of 1500. If I try bigger, I get an error.
Is it a hardware limitation?
Michele
mportola
I found a better framing for the question: are Jumbo frames supported?
Michele
dkasmin
UG585 (v1.2) August 8, 2012, page 379- on the top "Jumbo frames are not supported"
mybear
I have  the same problem with you. Are you solved it? Can you give me some help?
Thank you !
vanmierlo
Mentor
Mentor
But if you really do need jumbo frames, you could try to instantiate a Gigabit Ethernet Controller in the FPGA and use that instead.
