liqiaojun
Make to compile the Petalinux software image, but "returned an error code (127) ;make[1]: *** [pkg_stagefs] Error 255"
I am trying ot make to compile the Petalinux software image( make in $PETALINUX/software/petalinux-dist) . Refer to the UG977 PetaLinux SDK Getting Started Guide.pdf
 However, when it gets to "[INFO ]  Expanding stagefs", there is be an error . How can i do it?
My petalinux was installed in Debian-6.0.6-amd64 OS Host (in VirtualBox on my win7).
Thanks in advance!
Here is my PetaLinux compilation progress output:
$PETALINUX/software/petalinux-dist$ make
[INFO ] Saving previous build.log
[INFO ] Building ucfront tool
[INFO ] Building kernel
[INFO ] Building kernel modules
[INFO ] Building include
[INFO ] Building rootfs
[INFO ]  Setting up stage config
[INFO ]  Setting up romfs config
[INFO ]  Updating for microblazeel-v830-bs-cmp-mh-div
[INFO ]  Updating package manager
[ERROR]  E: Sub-process /home/focs/petalinux-v2013.04-final-full/software/petalinux-dist/tools/packagemanager/bin/dpkg returned an error code (127)
[00:02] \ make[1]: *** [pkg_stagefs] Error 255
make: *** [subdirs] Error 1
luodaxin
I am intrested in this knowledge too. Can anyone solve this problem?
ecrlowe
I've got the same problem on Ubuntu 12.04 64 bit.
ecrlowe
This worked for me :
sudo apt-get install ia32-libs
htsvn
Page 17 of this document talks about all the dependent packages required for Petalinux installation
http://www.xilinx.com/support/documentation/sw_manuals/petalinux2013_04/ug976-petalinux-installation...
To install Xilinx Tools on Ubuntu, it is recommended to refer
http://www.wiki.xilinx.com/Install+Xilinx+Tools (ia32-libs was the first command}
--HS
bradbrown
I am seeing the same error.
Environment:
Host PC : CentOS-6.5-x86_64
Xilinx Tools: Vivado 2013.3
PetaLinux Release:  2013.10
Page 11 of The Petalinux Installation guide document shows the packages required for Petalinux installation in the 1st column.  I have installed all these packages except libstdc++-4.4.6-4.el6.i686.  The only version readily available was libstdc++-4.4.7-4.el6.i686.
http://www.xilinx.com/support/documentation/sw_manuals/petalinux2013_10/ug976-petalinux-installation.pdf
sudo yum install dos2unix iproute gawk gcc git gnutls-devel net-tools ncurses-devel tftp-server zlib-devel flex bison libstdc++-devel.i686 glibc.i686 libgcc.i686
Loaded plugins: fastestmirror, refresh-packagekit, security
Loading mirror speeds from cached hostfile
 * base: centos.mirror.lstn.net
 * extras: mirror.ubiquityservers.com
 * updates: centos.gravityfish.com
Setting up Install Process
Package dos2unix-3.1-37.el6.x86_64 already installed and latest version
Package iproute-2.6.32-31.el6.x86_64 already installed and latest version
Package gawk-3.1.7-10.el6.x86_64 already installed and latest version
Package gcc-4.4.7-4.el6.x86_64 already installed and latest version
Package git-1.7.1-3.el6_4.1.x86_64 already installed and latest version
Package gnutls-devel-2.8.5-10.el6_4.2.x86_64 already installed and latest version
Package net-tools-1.60-110.el6_2.x86_64 already installed and latest version
Package ncurses-devel-5.7-3.20090208.el6.x86_64 already installed and latest version
Package tftp-server-0.49-7.el6.x86_64 already installed and latest version
Package zlib-devel-1.2.3-29.el6.x86_64 already installed and latest version
Package flex-2.5.35-8.el6.x86_64 already installed and latest version
Package bison-2.4.1-5.el6.x86_64 already installed and latest version
Package libstdc++-devel-4.4.7-4.el6.i686 already installed and latest version
Package glibc-2.12-1.132.el6.i686 already installed and latest version
Package libgcc-4.4.7-4.el6.i686 already installed and latest version
Nothing to do
When I run petalinux-buiild from the project Xilinx-ZC702-2013.3 directory, I see the same error.
$ cd petalinux-v2013.10-final/
$ source settings.sh
PetaLinux environment set to '/home/logic/petalinux-v2013.10-final'
INFO: Checking free disk space
INFO: Checking installed tools
INFO: Checking installed development libraries
INFO: Checking network and other services
$ cd ../Xilinx-ZC702-2013.3/
$ petalinux-build
INFO: Checking component...
INFO: Generating make files and build linux
INFO: Generating make files for the subcomponents of linux
INFO: Building linux
[INFO ] pre-build linux/rootfs/fwupgrade
[INFO ] pre-build linux/rootfs/peekpoke
[INFO ] pre-build linux/rootfs/uWeb
[INFO ] build linux/kernel
[INFO ] update linux/u-boot source
[INFO ] generate linux/u-boot configuration files
[INFO ] build linux/u-boot
[INFO ] Setting up rootfs config
[INFO ] Updating for armv7a-vfp-neon
[ERROR] E: Sub-process /home/logic/petalinux-v2013.10-final/tools/packagemanager/bin/dpkg returned an error code (127)
[ERROR] make[2]: *** [pkg_stagefs] Error 255
[ERROR] make[1]: *** [sub_build_component_/none/packages-repo/single/plnx-repo] Error 2
ERROR: Failed to build linux
bradbrown
Found more information on this issue in build/build.log.
[ALL  ] /home/logic/petalinux-v2013.10-final/tools/packagemanager/bin/dpkg: error while loading shared libraries: libselinux.so.1: cannot open shared object file: No such file or directory
 Ran 'yum list libselinux' to see what was installed and notice that libselinux.i686 was not yet installed.
$ yum list libselinux
 * base: dallas.tx.mirror.xygenhosting.com
Installed Packages
libselinux.x86_64              2.0.94-5.3.el6_4.1              @base/$releasever
Available Packages
libselinux.i686                2.0.94-5.3.el6_4.1              base
Installed libselinux.i686
$ sudo yum install libselinux.i686
 After installing the libselinux.i686 package I was able to successfully build Petalinux 2013.10.
tomasz.janicki.tj
Hi all,
For refernce only (since it is an old thread, but the thread's name is right)
What might help everyone:
cd /path/to/your/petalinux/
in my case:
cd /opt/Xilinx/PetaLinux/petalinux-v2014.4-final
find . -not -name "*.c" -not -name "*.h"  -not -name "*.txt" -not -iname "*readme*" -not -iname "*doc*" -not -iname "*.s" -not -iname "*.o" -not -name "*.sh" -not -iname "makefile" -exec file {} \; | grep ELF | cut -d":" -f1 | xargs ldd > /home/tj/all_dep.txt
(the above will take some time, 5 minutes for me runnig on 6 cores @ 2.6GHz with 8GB RAM, )
(if someone has a super machine then the whole -not -name "<pattern>"  is not required
LOOK @ THE TERMINAL OUTPUT AS WELL
then one can ie.
cat all_dep.txt | grep "not found" > all_dep_not_found.txt
imagine there is no
glib2.xxx
one can then
dpkg -S libglib2.xxx
this shows what package to install  (imagine it will be libglib2.0.0)
and the trick is to install :i386  (or perhaps i686 )
sudo apt-get install libglib2.0.0:i386
one can then write yet another script to install all "not found"s   provided that they are in repos
P.S.
PetaLinux seems to be functional, but still I have some unmet deps.
how odd ...
I am wondering if all that not founds, are actually the problem when I try to add
ncurses-tools
via
petlinux-config -c rootfs
I get the same error as if not having ia32-libs
have anyone tried adding ncureses-tools  and had the same error?
I mean offcourse
it happens (according to build.log) when ncurses-tools are being compiled
wihtout ncurses-tools the restof compilation goes OK
it might be some package incompatibilkites as well since I added averything but ncurses-tools  from ncurses chocie in peta-linux -c rootfs
Anyone having the same issue?
With Regards
T
tomasz.janicki.tj
I forgot to mention
before rushing into apt-get it all
What I did I checked if  for istance if
libapt-pkg.so.4.10 => not found
find . -iname "*libapt-pkg*"
or simply
find . -iname "libapt-pkg.so.4.10"
becouse petlinux seems to have some of its own libs and packages
so from the prevous post we have a file all_dep_not_found.txt:
cat all_dep_not_found.txt | cut -d"=" -f1 " tr -d " \t" > all_dep_not_found_no_spaces.txt
xargs -a all_dep_not_found_no_spaces.txt -I {} find /opt/Xilinx/PetaLinux/petalinux-v2014.4-final -name {} > all_dep_found.txt
cat all_dep_found.txt | rev | cut -d"/" -f1 | rev > all_dep_found_just_libs.txt
cp all_dep_not_found_no_spaces.txt combine_compare_list.txt
cat all_dep_found_just_libs.txt >> combine_compare_list.txt
sort combine_compare_list.txt | uniq -u
tada!  a list of missing libs
With Regards
T
