Makefile not generated for custom application in PetaLinux v2017.4
I have two question regarding adding an application into Petalinux file system.
I created an application called receiver using SDK. And, ran the following command to create the application in PetaLinux.
$ petalinux-create -t apps --template install --name receiver --enable
1. Is it enough if I replace 'receiver' file under 'files' folder with 'receiver.elf'?
2. Makefile is not found under files folder. Is there a way to generate it?
Re: Makefile not generated for custom application in PetaLinux v2017.4
Hi @nardhini03,
Install template is only for copying configurations files, scripts and binaries.
If you need makefile then use template as c or c++.
Sandeep
Additional info:
Makefile is created for other templates like C and C++, it is not created for install.
Hi @nardhini03,
Sandeep
Hi @sandeepg,
Thanks for the reply. The build worked. The confusion on Makefile was due to the README file which mentioned about doing some modifications to the Makefile.
