fletzerm
Matching hardware for Device Tree file
Dear Xilinx Team,
the master-next branch of the linux-xlnx git repository contains zynq-zc702-drm-v4l2.dts.
It is an interesting configuration and I also looked at the drm drivers. I would like to use similar configuration to set up my system, but don't know how the components have to be connected together.
Please can you provide a block diagram or config file so I can reproduce your work.
Martin
ckohn
Martin,
we're working on a reference design that will showcase the V4L2 and DRM drivers. Unfortunately, I don't have a release date yet and things are still very much work in progress.
Chris
ckohn
Martin,
Chris
fletzerm
No problem,
I got the framebuffer device already working.
I'm looking forward to work with the finished reference design.
Best regards,
Martin
yinlinlijuan
Can you give some advice about your framebuffer device ?
I also want to develop some QT application which need framebuffer too.
Chen
lcameron
fletzerm
You can use kernel version with tag "xilinx-v2013.4". This version contains arch/arm/configs/xilinx_zynq_drm_defconfig and arch/arm/boot/dts/zynq-zc702-drm-v4l2.dts. The devicetree describes, how you have to configure the hardware.
If you have problems, I can send you my hardware design.
yinlinlijuan
Thank you very much.
You are so nice that you can share us your design.
Thanks again. This is my email :  420263674@qq.com
Chen.
jothiadithya
Is the reference design available now?
Jothi
balkris
check UG925 with Vivado 2014.2
http://www.xilinx.com/support/documentation/boards_and_kits/zc702_zvik/2014_2/ug925-zynq-zc702-base-trd.pdf
Thanks and Regards
Balkrishan
balkris
you can get design files here
http://www.wiki.xilinx.com/Zc702+Base+TRD
Thanks and Regards
Balkrishan
