03-31-2015 03:56 AM
We have built a custom board using the Micrel KSZ9021 ethernet phy. The board has been designed to run at 100M only so the ethernet clock in vivaldo was set to 25MHz.
I have enabled the phy in the kernel and device tree however during boot we continouly get messages saying:
macb e000b000.ps7-ethernet eth0: unable to generate target frequency: 25000000 Hz
I have checked and the output of cll_round_rate is 0Hz. This does not seem correct!
Is this because we are running our zynq off a 50MHz clock?
In the device tree I had to change the ps7_slcr ps-clk-frequency to 50000000.
Here is the ps7-ethernet section of the device tree.
ps7_ethernet_0: ps7-ethernet@e000b000 { phy-handle = <&phy0>; phy-mode = "rgmii-id"; mdio { phy0: phy@1 { compatible = "micrel,ksz9021"; device_type = "ethernet-phy"; reg = <1>; max-speed = <100>; } ; } ; } ;
Is there any other clocks I need to change?
03-31-2015 04:19 AM
The change of the oscillator should be enough. Check that clock hierarchy and frequencies match your expectations:
cat /sys/kernel/debug/clk/clk_summary
My first suspect for the zero frequency would be a misconfigured mux in the clock hierarchy.
03-31-2015 04:27 AM
Thanks for the quick reply. How do I set the mux?
Here is my clk_summary:
clock enable_cnt prepare_cnt rate accuracy -------------------------------------------------------------------------------- ps_clk 3 3 50000000 0 iopll_int 1 1 1000000000 0 iopll 7 7 1000000000 0 dbg_mux 1 1 1000000000 0 dbg_div 1 1 66666667 0 dbg_emio_mux 1 1 66666667 0 dbg_trc 1 1 66666667 0 can_mux 0 0 1000000000 0 can_div0 0 0 40000000 0 can_div1 0 0 8000000 0 can1_gate 0 0 8000000 0 can1 0 0 8000000 0 can0_gate 0 0 8000000 0 can0 0 0 8000000 0 gem1_mux 0 0 1000000000 0 gem1_div0 0 0 16666667 0 gem1_div1 0 0 16666667 0 gem1_emio_mux 0 0 16666667 0 gem1 0 0 16666667 0 gem0_mux 0 0 1000000000 0 gem0_div0 0 0 1000000000 0 gem0_div1 0 0 1000000000 0 spi0_mux 0 0 1000000000 0 spi0_div 0 0 166666667 0 spi1 0 0 166666667 0 spi0 0 0 166666667 0 uart0_mux 1 1 1000000000 0 uart0_div 1 1 100000000 0 uart1 0 0 100000000 0 uart0 1 1 100000000 0 sdio0_mux 1 1 1000000000 0 sdio0_div 1 1 125000000 0 sdio1 0 0 125000000 0 sdio0 1 1 125000000 0 pcap_mux 0 0 1000000000 0 pcap_div 0 0 200000000 0 pcap 0 0 200000000 0 lqspi_mux 0 0 1000000000 0 lqspi_div 0 0 200000000 0 lqspi 0 0 200000000 0 fclk3_mux 1 1 1000000000 0 fclk3_div0 1 1 50000000 0 fclk3_div1 1 1 50000000 0 fclk3 1 1 50000000 0 fclk2_mux 1 1 1000000000 0 fclk2_div0 1 1 50000000 0 fclk2_div1 1 1 50000000 0 fclk2 1 1 50000000 0 fclk1_mux 1 1 1000000000 0 fclk1_div0 1 1 50000000 0 fclk1_div1 1 1 50000000 0 fclk1 1 1 50000000 0 fclk0_mux 1 1 1000000000 0 fclk0_div0 1 1 100000000 0 fclk0_div1 1 1 100000000 0 fclk0 1 1 100000000 0 ddrpll_int 1 1 1050000000 0 ddrpll 3 3 1050000000 0 dci_div0 1 1 20192308 0 dci_div1 1 1 10096154 0 dci 1 1 10096154 0 ddr3x_div 1 1 525000000 0 ddr3x 1 1 525000000 0 ddr2x_div 1 1 350000000 0 ddr2x 1 1 350000000 0 armpll_int 1 1 1300000000 0 armpll 1 1 1300000000 0 smc_mux 0 0 1300000000 0 smc_div 0 0 21666667 0 smc 0 0 21666667 0 cpu_mux 1 1 1300000000 0 cpu_div 3 3 650000000 0 cpu_1x_div 1 1 108333333 0 cpu_1x 8 8 108333333 0 smc_aper 0 0 108333333 0 lqspi_aper 0 0 108333333 0 gpio_aper 1 1 108333333 0 uart1_aper 0 0 108333333 0 uart0_aper 1 1 108333333 0 i2c1_aper 0 0 108333333 0 i2c0_aper 0 0 108333333 0 can1_aper 0 0 108333333 0 can0_aper 0 0 108333333 0 spi1_aper 0 0 108333333 0 spi0_aper 0 0 108333333 0 sdio1_aper 0 0 108333333 0 sdio0_aper 1 1 108333333 0 gem1_aper 0 0 108333333 0 gem0_aper 2 2 108333333 0 usb1_aper 0 0 108333333 0 usb0_aper 2 2 108333333 0 dbg_apb 1 1 108333333 0 swdt 0 0 108333333 0 cpu_2x_div 1 1 216666666 0 cpu_2x 1 1 216666666 0 dma 1 1 216666666 0 cpu_3or2x_div 1 1 325000000 0 cpu_3or2x 2 2 325000000 0 cpu_6or4x 0 0 650000000 0 can1_mio_mux 0 0 0 0 can0_mio_mux 0 0 0 0 gem0_emio_mux 1 1 0 0 gem0 1 1 0 0
03-31-2015 04:31 AM
Looks like you selected an external clock via EMIO for the GEM. This is set in PCW in Vivado (somewhere around where you set the frequency as well).
You need to fix that, export the HW again and update the FSBL accordingly. (for a quick test it should work if you just manually set the mux correctly from the U-Boot command line.
03-31-2015 05:21 AM
Thanks that fixed the error message.
It now boots into Linux with no error messages however the ethernet does not work. It detects the link is up but I can not get a dhcp address and using a static ip address does not work.
Any idea what I can do to debug this?
