MicroZed .elf: not found
I'm attempting to run the Xilinx SDK Hello Word example on a MicroZed (7Z020), using SDK  2017.4 on Windows 10.
MicroZed is running the as delivered Linux OS:
zynq> uname -a
Linux 192.168.1.10 3.8.0-xilinx #2 SMP PREEMPT Thu Jun 13 10:25:52 PDT 2013 armv7l GNU/Linux
I followed the How to create Linux applications video https://www.xilinx.com/video/hardware/how-to-create-linux-applications.html and get as far as launching the executable but then get an error at the Eclipse console:
zynq> /tmp/Test_app.elf
-sh: /tmp/Test_app.elf: not found
Running from a Linux shell produces the same result:
zynq> ls -la
total 33
drwxrwxrwt 2 root root 60 Jan 1 02:45 .
drwxr-xr-x 18 root root 1024 Jan 1 02:03 ..
-rwxr-xr-x 1 root root 32008 Jan 1 02:38 Test_app.elf
zynq> ./Test_app.elf
-/bin/ash: ./Test_app.elf: not found
Toolchain is 'Xilinx ARM v7 GNU/Linux Toolchain' with tools:
ARM v7 Linux gcc assembler
ARM v7 Linux gcc compiler
ARM v7 Linux g++ compiler
ARM v7 Linux archiver
ARM v7 Linux gcc linker
ARM v7 Linux g++ linker
readelf shows:
readelf.exe -h Test_app.elf
ELF Header:
Magic: 7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00
Class: ELF32
Data: 2's complement, little endian
Version: 1 (current)
OS/ABI: UNIX - System V
ABI Version: 0
Type: EXEC (Executable file)
Machine: ARM
Version: 0x1
Entry point address: 0x102f4
Start of program headers: 52 (bytes into file)
Start of section headers: 30528 (bytes into file)
Flags: 0x5000400, Version5 EABI, hard-float ABI
Size of this header: 52 (bytes)
Size of program headers: 32 (bytes)
Number of program headers: 8
Size of section headers: 40 (bytes)
Number of section headers: 37
Section header string table index: 34
The only possible issue I see is that build commands are 'arm-linux-gnueabihf-gcc' when I was expecting 'arm-linux-gnueabi-gcc'.
I tried switching to 'Xilinx ARM GNU/Linux Toolchain', but then get build errors ''arm-xilinx-linux-gnueabi-gcc' is not recognized as an internal or external command'.
Do I need to select a different Linux toolchain or change some other configuration?
@kbeardmore  You can always install build essentials, boot your device, copy your code there and compile inside the device itself.
If it is a small binary that is probably the recommended way.
That said, what happens when you do an `ldd Test_app.elf` ?
I faced the same problem. Using the right Linux kernel (image.ub) fixed the problem. I suggest you to use the pre-built kernel images generated in PetLinux project to boot the board.
Steps:
1. Download the Microzed Petalinux BSP from this link
2. Create PetaLinux project following the Petalinux reference guide (ug1164)
3. Navigate the <petalinux_project_dir> / pre-built / linux / images
4. Copy BOOT.bin, <your_application>.elf, and image.ub to SD card
5. Boot from SD card and login as root (password: root)
6. Mount SD card as: mount /dev/mmvblk0p1 /mnt
7. cd to /mnt and execute <your_application>.elf
