10-27-2010 08:40 AM
Hi Everyone,
The following is the log of the linux kernel,
I have tested the following kernels:
-- Linux 2.6.34 from Xilinx git tree git.xilinx.com
-- again 2.6.34 from monstr.eu
-- Linux 2.6.36 main line kernel
And the following set of development tools :
-- EDK 11.5
-- EDK 12.1
-- EDK 12.3
In all of the cases the same thing as the following is happening and I can not understand what is the source of this problem.
In addition I am really getting disappointed from running Linux on Microblaze at all, because every day, that I decide to change the EDK version or the Linux version I will encounter strange bugs and problems that can be solved only by the main developers of the kernel themselves.
Do they have written the Linux kernel to be used by just themselves?
here is the log :
<5>Linux version 2.6.36 (sadri@SADRI) (gcc version 4.1.2
20070214 (Xilinx 11.1 Build EDK_L.14 29 Sep 2010)) #2 Wed Oct 27
18:37:57 EDT 2010
<6>setup_cpuinfo: initialising
<6>setup_cpuinfo: Using full CPU PVR support
<6>cache: wt_msr_noirq
<6>setup_memory: max_mapnr: 0x4000
<6>setup_memory: min_low_pfn: 0x44000
<6>setup_memory: max_low_pfn: 0x48000
<7>On node 0 totalpages: 16384
<7>free_area_init_node: node 0, pgdat c02c453c, node_mem_map c030c000
<7> Normal zone: 128 pages used for memmap
<7> Normal zone: 0 pages reserved
<7> Normal zone: 16256 pages, LIFO batch:3
<4>Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
<5>Kernel command line: console=ttyUL0,115200
<6>PID hash table entries: 256 (order: -2, 1024 bytes)
<6>Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
<6>Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
<6>Memory: 61780k/65536k available
<6>Hierarchical RCU implementation.
<6> RCU-based detection of stalled CPUs is disabled.
<6> Verbose stalled-CPUs detection is disabled.
<6>NR_IRQS:32
<6>xlnx,xps-intc-1.00.a #0 at 0xc4000000, num_irq=3, edge=0x7
<6>xlnx,xps-timer-1.00.a #0 at 0xc4004000, irq=0
<6>microblaze_timer_set_mode: shutdown
<6>microblaze_timer_set_mode: periodic
<6>Calibrating delay loop... 28.16 BogoMIPS (lpj=140800)
<6>pid_max: default: 4096 minimum: 301
<4>Mount-cache hash table entries: 512
<4>------------[ cut here ]------------
<4>WARNING: at fs/sysfs/dir.c:448 sysfs_add_one+0x84/0x98()
<4>sysfs: cannot create duplicate filename 'À�À"�'
<4>Modules linked in:
<6>Kernel Stack:
<6>c3825e08: c000f260 0001ffff
<6>c3825e10: 00000000 00000009 c3830f28 c3825e70 c024def4 c000f328 c023c188 c024def4
<6>c3825e30: 000001c0 c00c0d64 0001ffff c02dec24 ffffffef c3831000 c380e4a0 c3825ebc
<6>c3825e50: 00000000 c00c0d5c 00000001 c3825efc 00000000 00000000 ffffffef 00000000
<6>c3825e70: c024df20 c3825e88 c00c18ac c015955c c00816d0 c024df20 c38011e0 c38022f0
<6>c3825e90: 0000000b c380e4a0 00000000 fffffff4 c00c1aec c026c53b 00000000 127a3982
<6>c3825eb0: 00000000 c38011e0 00000000 c02bc6a8 00000000 00000000 c3830f28 c02bc6a8
<6>c3825ed0: 00000000 00000000 00000000 00000000 c0151de8 00000000 c0151f50 c3820040
<6>c3825ef0: c0151d9c c00701a4 00000000 c3811000 fffffffe c3830f28 00000000 c026c618
<6>c3825f10: c0151f0c 00000000 c01520b4 c3830f20 c0151f04 c380b760 c380b760 c3830f20
<6>c3825f30: 00000000 00000000 c026c618 00000000 c0152138 c381fbc0 c381fbc8 c0025304
<6>c3825f50: c02dbde0 c026c534 00000000 c3830f20 c02d3a0c c3825f60 c026c534 00000000
<6>c3825f70: c3830f60 00000000 00000000 c02dbde0 00000000 00000000 00000000 c02d4220
<6>c3825f90: 00000000 00000000 00000000 00000000 c02dbde0 00000000 c02c61a0 c02dc258
<6>c3825fb0: 00000000 00000000 00000000 00000000 c02dc258 c000203c 00000000 00000000
<6>c3825fd0: 00000000 00000000 00000000 00000000 00000000 00000000 c0002030 000045aa
<6>c3825ff0: 00000000 00000000 00000000 00000001
<6>
<6>
<6>Call Trace:
<4>[<c0004084>] microblaze_unwind+0x70/0x8c
<4>[<c0003d48>] show_stack+0x104/0x164
<4>[<c0003db0>] dump_stack+0x8/0x20
<4>[<c000f25c>] warn_slowpath_common+0x7c/0xb8
<4>[<c000f324>] warn_slowpath_fmt+0x28/0x40
<4>[<c00c0d58>] sysfs_add_one+0x78/0x98
<4>[<c00c18a8>] create_dir+0x7c/0x100
<4>[<c00c1ae8>] sysfs_create_dir+0x88/0x1cc
<4>[<c0151de4>] kobject_add_internal+0xc8/0x1d0
<4>[<c0151f08>] kset_register+0x1c/0x38
<4>[<c0152134>] kset_create_and_add+0x6c/0xcc
<4>[<c02d3a08>] devices_init+0x18/0x108
<4>[<c02d421c>] driver_init+0x8/0x68
<4>[<c02c619c>] kernel_init+0x98/0x1d4
<4>[<c0002038>] kernel_thread_helper+0x8/0x20
<6>
<4>---[ end trace 139ce121c98e96c9 ]---
<3>kobject_add_internal
failed for À�À"� with -EEXIST, don't try to register things with the
same name in the same directory.
<6>Kernel Stack:
<6>c3825ef4: c0151e88 00000000 00000000
<6>c3825f00: fffffffe c3830f28 00000000 c3825f18 c0151f0c c0267ba0 c0267ce8 c38011e0
<6>c3825f20: 0000000f 00000000 00000003 c3830f20 00000000 00000000 c026c618 00000000
<6>c3825f40: c0152138 c381fbc0 c381fbc8 c0025304 c02dbde0 c026c534 00000000 c3830f20
<6>c3825f60: c02d3a0c c3825f60 c026c534 00000000 c3830f60 00000000 00000000 c02dbde0
<6>c3825f80: 00000000 00000000 00000000 c02d4220 00000000 00000000 00000000 00000000
<6>c3825fa0: c02dbde0 00000000 c02c61a0 c02dc258 00000000 00000000 00000000 00000000
<6>c3825fc0: c02dc258 c000203c 00000000 00000000 00000000 00000000 00000000 00000000
<6>c3825fe0: 00000000 00000000 c0002030 000045aa 00000000 00000000 00000000 00000001
<6>
<6>
<6>Call Trace:
<4>[<c0151e84>] kobject_add_internal+0x168/0x1d0
<6>
<4>sysfs: cannot create duplicate filename 'bus'
<6>Kernel Stack:
<6>c3825e70: c024df20 c3825e88 c00c18ac c015955c c0002038 c024df20 c38011e0 000003e0
<6>c3825e90: 00000000 c380e4a0 00000000 fffffff4 c00c1aec c026c833 c0003d4c 00000000
<6>c3825eb0: 00000000 00000000 00000000 c02bc6a8 00000000 00000000 c3830f28 c02bc6a8
<6>c3825ed0: 00000000 00000000 00000000 00000000 c0151de8 00000000 c0151f50 c3830f28
<6>c3825ef0: c0151d9c c0151e88 00000000 00000000 fffffffe c3830f28 00000000 c026c8cc
<6>c3825f10: c0151f0c 00000000 c01520b4 c3830f20 c0151f04 00000000 00000003 c3830f20
<6>c3825f30: 00000000 00000000 c026c8cc 00000000 c0152138 c381fbc0 c381fbc8 c0025304
<6>c3825f50: c02dbde0 c026c830 00000000 c3830f20 c02d3b60 c3825f60 c026c830 00000000
<6>c3825f70: c3830f60 0001ffff c02dec24 c02dbde0 00000000 00000000 00000000 c02d422c
<6>
<6>
<6>Call Trace:
<4>[<c02d3b5c>] buses_init+0x18/0x48
<4>[<c02d4228>] driver_init+0x14/0x68
<6>
<4>---[ end trace 139ce121c98e96ca ]---
failed for bus with -EEXIST, don't try to register things with the same
<6>Kernel Stack:
<6>c3825f20: 0000000f 00000000 00000003 c3830f20 00000000 00000000 c026c8cc 00000000
<6>c3825f40: c0152138 c381fbc0 c381fbc8 c0025304 c02dbde0 c026c830 00000000 c3830f20
<6>c3825f60: c02d3b60 c3825f60 c026c830 00000000 c3830f60 0001ffff c02dec24 c02dbde0
<6>c3825f80: 00000000 00000000 00000000 c02d422c 00000000 00000000 00000000 00000000
<6>
<6>
<6>Call Trace:
<6>
<4>sysfs: cannot create duplicate filename 'class'
<6>Kernel Stack:
<6>c3825e90: 00000000 c380e4a0 00000000 fffffff4 c00c1aec c026caa1 c0003d4c 00000000
<6>c3825ef0: c0151d9c c0151e88 00000000 00000000 fffffffe c3830f28 00000000 00000000
<6>c3825f30: 00000000 00000000 00000000 00000000 c0152138 c381fbc0 c381fbc8 c0025304
<6>c3825f50: c02dbde0 c026ca9c 00000000 c3830f20 c02d3ba4 c3825f60 c026ca9c 00000000
<6>c3825f70: c3830f60 0001ffff c02dec24 c02dbde0 00000000 00000000 00000000 c02d4238
<6>
<6>
<6>Call Trace:
<4>[<c02d3ba0>] classes_init+0x14/0x44
<4>[<c02d4234>] driver_init+0x20/0x68
<6>
<4>---[ end trace 139ce121c98e96cb ]---
failed for class with -EEXIST, don't try to register things with the
<6>Kernel Stack:
<6>c3825f20: 0000000f 00000000 00000003 c3830f20 00000000 00000000 00000000 00000000
<6>c3825f40: c0152138 c381fbc0 c381fbc8 c0025304 c02dbde0 c026ca9c 00000000 c3830f20
<6>c3825f60: c02d3ba4 c3825f60 c026ca9c 00000000 c3830f60 0001ffff c02dec24 c02dbde0
<6>c3825f80: 00000000 00000000 00000000 c02d4238 00000000 00000000 00000000 00000000
<6>
<6>
<6>Call Trace:
<6>
<4>sysfs: cannot create duplicate filename 'firmware'
<6>Kernel Stack:
<6>c3825de4: c000f260 0001ffff 00000000
<6>c3825df0: 00000009 c3830f20 c3825e4c c024def4 c000f328 c023c188 c024def4 000001c0
<6>c3825e10: c00c0d64 0001ffff c02dec24 ffffffef c3831000 c380e4a0 c3825e98 00000000
<6>c3825e30: c00c0d5c 00000001 c3825ed8 00000000 00000000 ffffffef 00000000 c024df20
<6>c3825e50: c3825e64 c00c18ac c015955c c0267ba0 c024df20 c38011e0 000003e0 00000000
<6>c3825e70: c380e4a0 00000000 fffffff4 c00c1aec c0267cbd c3825f00 00000040 04000aff
<6>c3825e90: ffffffff 00000000 c02bc6a8 00000000 00000000 c3830f20 c02bc6a8 00000000
<6>c3825eb0: 00000000 00000000 00000000 c0151de8 00000000 c0151f50 c023a548 c0151d9c
<6>c3825ed0: ffffffff 00000000 0001ffff fffffffe c3830f20 00000000 00000000 c015201c
<6>c3825ef0: 00000000 c0151fd8 00000000 00000000 c0151a78 c3830f28 00000000 c3830f20
<6>c3825f10: 00000000 00000000 00000000 c01524d4 c0151b14 00000000 00000003 c3830f20
<6>c3825f30: 00000000 c02dbde0 c3830f20 c026cc80 00000000 c0152550 c381fbc8 c0025304
<6>c3825f50: c02dbde0 00000000 00000000 00000000 c3825f74 c02d41e8 c026ca9c 00000000
<6>c3825f70: c0267cbc c026cc80 0001ffff c02dec24 c02dbde0 00000000 00000000 c02d4244
<6>
<6>
<6>Call Trace:
<4>[<c0152018>] kobject_add_varg+0x60/0x74
<4>[<c01524d0>] kobject_add+0x30/0x74
<4>[<c015254c>] kobject_create_and_add+0x38/0x98
<4>[<c02d41e4>] firmware_init+0x10/0x40
<4>[<c02d4240>] driver_init+0x2c/0x68
<6>
<4>---[ end trace 139ce121c98e96cc ]---
failed for firmware with -EEXIST, don't try to register things with the
<6>Kernel Stack:
<6>c3825ed0: c0151e88 00000000 00000000 fffffffe c3830f20 00000000 c3825ef4 c015201c
<6>c3825ef0: c0267ba0 c0267ce8 c38011e0 0000000f 00000000 00000003 00000000 c3830f20
<6>
<6>
<6>Call Trace:
<6>
<4>kobject_create_and_add: kobject_add error: -17
<4>sysfs: cannot create duplicate filename 'platform'
<6>Kernel Stack:
<6>c3825d98: c000f260 0001ffff
<6>c3825da0: 00000000 00000009 c02bfdd0 c3825e00 c024def4 c000f328 c023c188 c024def4
<6>c3825dc0: 000001c0 c00c0d64 0001ffff c02dec24 ffffffef c3831000 c380e4a0 c3825e4c
<6>c3825de0: 00000000 c00c0d5c 00000001 c3825e8c 00000000 00000000 ffffffef 00000000
<6>c3825e00: c024df20 c3825e18 c00c18ac 30303030 c0002038 c024df20 c38011e0 000003e0
<6>c3825e20: 00000000 c380e4a0 00000000 fffffff4 c00c1aec c015955c c3825f70 c3825f74
<6>c3825e40: c0267cdc c38011e0 c026c5a8 c02bc6a8 00000000 00000000 c02bfdd0 c02bc6a8
<6>c3825e60: 00000000 00000000 00000000 c02bfdd0 c0151de8 04000aff ffffffff 00000009
<6>c3825e80: c0151d9c c3825f24 c026c5a8 00000000 fffffffe c02bfdd0 00000000 00000000
<6>c3825ea0: c015201c c023a548 c0151fd8 00000000 c0267cc0 c0151998 00000035 00000000
<6>c3825ec0: c02bfdd0 00000000 00000000 00000000 c01524d4 c02bf658 c02bfdd0 c0173790
<6>c3825ee0: c3830f20 00000000 c02bfdc8 c02bfdc8 c02bfdc8 ffffffea c0173fd8 c0173fa8
<6>c3825f00: 00000000 c0151a78 00000000 c3830f20 00000000 c3825f28 c0174518 00000000
<6>c3825f20: c026c5a8 00000000 04000aff ffffffff c02dec24 00000000 00000000 c3830f20
<6>c3825f40: c02dbde0 c02dbde0 c02bfdc8 00000000 00000000 00000000 00000000 00000000
<6>c3825f60: 00000000 00000000 c02d3f70 c0267d00 ffffffef 00003df2 0001ffff c02dec24
<6>c3825f80: c02dbde0 00000000 c02d4250 c02d4244 00000000 00000000 00000000 00000000
<6>c3825fa0: c02dbde0 c02dbde0 c02c61a0 c02dc258 00000000 00000000 00000000 00000000
<6>
<6>
<6>Call Trace:
<4>[<c0173fd4>] device_add+0x98/0x5c8
<4>[<c0174514>] device_register+0x10/0x2c
<4>[<c02d3f6c>] platform_bus_init+0x18/0x78
<4>[<c02d424c>] driver_init+0x38/0x68
<6>
<4>---[ end trace 139ce121c98e96cd ]---
failed for platform with -EEXIST, don't try to register things with the
<6>Kernel Stack:
<6>c3825e84: c0151e88 c026c5a8 00000000
<6>c3825e90: fffffffe c02bfdd0 00000000 c3825ea8 c015201c c0267ba0 c0267ce8 c38011e0
<6>c3825eb0: 0000000f 00000000 00000003 00000000 c02bfdd0 00000000 00000000 00000000
<6>c3825ed0: c01524d4 c02bf658 c02bfdd0 c0173790 c3830f20 00000000 c02bfdc8 c02bfdc8
<6>c3825ef0: c02bfdc8 ffffffea c0173fd8 c0173fa8 00000000 c0151a78 00000000 c3830f20
<6>c3825f10: 00000000 c3825f28 c0174518 00000000 c026c5a8 00000000 04000aff ffffffff
<6>c3825f30: c02dec24 00000000 00000000 c3830f20 c02dbde0 c02dbde0 c02bfdc8 00000000
<6>c3825f50: 00000000 00000000 00000000 00000000 00000000 00000000 c02d3f70 c0267d00
<6>c3825f70: ffffffef 00003df2 0001ffff c02dec24 c02dbde0 00000000 c02d4250 c02d4244
<6>c3825f90: 00000000 00000000 00000000 00000000 c02dbde0 c02dbde0 c02c61a0 c02dc258
<6>
<6>
<6>Call Trace:
<6>
<4>Oops: kernel access of bad area, sig: 11
<6> Registers dump: mode=47825E20
<6> r1=00000000, r2=00000000, r3=00000073, r4=C3830F2C
<6> r5=C0267D18, r6=0000002F, r7=00000000, r8=C3830F28
<6> r9=0000006D, r10=00000004, r11=00000002, r12=FFFFFFFB
<6> r13=00000000, r14=00000170, r15=C0151D00, r16=FFFFFFEF
<6> r17=C015955C, r18=00000010, r19=00000024, r20=00000000
<6> r21=00000000, r22=C3830F28, r23=00000008, r24=00000000
<6> r25=00000000, r26=00000000, r27=00000000, r28=00000000
<6> r29=00000000, r30=00000000, r31=C3820D60, rPC=C0152844
<6> msr=000046A2, ear=00000024, esr=00000872, fsr=C38011E0
<0>Kernel panic - not syncing: Attempted to kill init!
