Microblaze Linux support for AXI PCIe RC is missing?
Is where Linux driver available for LogiCORE IP AXI Bridge for PCI Root Complex (PCI host/PCI bridge)?
Datasheet DS820 says this core is supported by Linux, but in fact, its RC functionality can't be used in embdded Linux due to lack of the driver. Old PCI host bridge driver found in both mainline kernel and git.xilinx.com kernel doesn't seems to have any support for AXI PCIe RC.
Are any ready to use solutions exiests for this?
Thank you.
Re: Microblaze Linux support for AXI PCIe RC is missing?
Sure, we're discussing that now and yes I think we can. We will mark it as a development driver and not released so there would not be any support from Xilinx on it yet.
Work is still going on for PCIe to make it work properly in a software system. We are debating about putting it into the tree as a development (not released) driver.
Thanks for the reply, John. That's good news.
Is it possible to get this (incomplete) driver now?
It should be better anyway than reinventing the wheel by myself from the scratch.
Thanks!
Good! But how to get it?
Should I wait for it to appear in linux-xlnx.git, or its going to be available as separate download?
Thank you very much!
Now I can see the AXI PCIe RC driver for Microblaze in master-next of linux-xlnx.git.
Big thanks for the opportunity to have early access to this code!
Great! Let us know how it goes. The device tree generator repo was updated to help generate a device tree. Please remember this is not a released driver and I need to document that on the wiki. Thanks.
I'v tried it and, in short words, it works.
I'v got a minor headache with adding this code to mainline 3.4.4 kernel used in my project, but finally it worked. I'm getting some difficulties with MSI's and the ranges property generated by new device tree generator looks like a hack and angers kernel dts compiler, but in general that driver is good enough to use.
A question left: is it possible to use (emulate?) PCI IO resource with AXI PCIe RC? All bridge's AXIBAR's are of memory type by their nature and I'v failed to mimic one them as IO window - both with my own driver and with this one.
I asked the IP team about this and it sounds like you cannot do what you're asking.  I'm no expert on this so I don't have any insight myself.  Sorry.
No problems, for me the IO resource is not mandatory.
Thanks John for your help and for making AXI PCIe RC driver available!
   we have been facing problems with Axi pcie driver in our system as enumeration fails. Endpoint do gets detected  but device id and vendor id are same  for root-complex and endpoint.  I am using kernel version 3.8.0 from xilinx git. Have u done any change in driver source to make it usable.
