Microblaze and BlueCat GPL
I am trying to use the GPL version of BluCat linux.
After lots of efforts, I am able to see it in the OS list of EDK under Software Platform Setting.
Now when I am trying to compile and generate lib, I am getting the following error.
ERROR:MDT - linux_bc54 () - uname: invalid option -- o
   Try `uname --help' for more information.
       while executing
   "exec bash -c "uname -o""
       (procedure "fix_path_cygwin" line 2)
       invoked from within
   "fix_path_cygwin $target_dir"
       (procedure "::sw_linux_bc54_v1_00_a::linux_drc" line 27)
       invoked from within
   "::sw_linux_bc54_v1_00_a::linux_drc 60294256"
ERROR:MDT - Error while running DRC for processor microblaze_0...
make: *** [microblaze_0/lib/libxil.a] Error 2
Can anybody suggest what has gone wrong or may be I should upgrade to the new cygwin version.
I am using EDK 10.1 for my experiment.  I will be using the Spartan 3E 500 for my design, but I guess, that should not be a problem.
Visitor bluehorn
Re: Microblaze and BlueCat GPL
The error message you quote is about some Tcl script in EDK trying to run the command "uname -o".
On my system (Debian unstable), this gives the following output:
torsten@sharokan:~$ uname -o
GNU/Linux
According to the uname documentation (available usually via "info coreutils uname"), "-o" ask uname to print the name of the operating system. I am not sure if that option is a new one, I have never seen it in use before.
You may need to upgrade coreutils (my version is 6.10-6).
Visitor bluehorn
GNU/Linux
My problem is now solved after upgrading the coreutils.
