liyafeng007
Microblaze linux boot hangs after "Freeing unused kernel memory"
 I am porting linux on Spartan3A DSP 1800 board
I use XMD to download the image
The kernel stop at :Freeing unused kernel memory: 933k freed
I used
make ARCH=microblaze xilinx_mmu_defconfig
and just changed "Physical address where Linux Kernel is" to 0x88000000 where the DDR base address is.
I have search the forum about the problem. A few post mentioned the same problem, but i still get no idea.
so, need  help.
This is the console output:
early_printk_console is enabled at 0x84000000
Ramdisk addr 0x00000003, Compiled-in FDT at 0xc02a3d68
Linux version 2.6.35 (lyf@lyf-desktop) (gcc version 4.1.2) #10 Mon Jan 10 17:04:
08 CST 2011
setup_cpuinfo: initialising
setup_cpuinfo: No PVR support. Using static CPU info from FDT
cache: wt_msr
setup_memory: max_mapnr: 0x8000
setup_memory: min_low_pfn: 0x88000
setup_memory: max_low_pfn: 0x90000
On node 0 totalpages: 32768
free_area_init_node: node 0, pgdat c033d2a4, node_mem_map c0439000
  Normal zone: 256 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 32512 pages, LIFO batch:7
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: console=ttyUL0 root=/dev/ram
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 125492k/131072k available
Hierarchical RCU implementation.
        RCU-based detection of stalled CPUs is disabled.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:32
xlnx,xps-intc-1.00.a #0 at 0xc8000000, num_irq=2, edge=0x1
xlnx,xps-timer-1.00.a #0 at 0xc8004000, irq=1
microblaze_timer_set_mode: shutdown
microblaze_timer_set_mode: periodic
Calibrating delay loop... 30.31 BogoMIPS (lpj=151552)
pid_max: default: 4096 minimum: 301
Mount-cache hash table entries: 512
bio: create slab <bio-0> at 0
XGpio: /plb@0/gpio@81400000: registered
XGpio: /plb@0/gpio@81420000: registered
XGpio: /plb@0/gpio@81440000: registered
Switching to clocksource microblaze_clocksource
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
GPIO pin is already allocated
Slow work thread pool: Starting up
Slow work thread pool: Ready
msgmni has been set to 245
io scheduler noop registered
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
84000000.serial: ttyUL0 at MMIO 0x84000000 (irq = 0) is a uartlite
console [ttyUL0] enabled
brd: module loaded
Xilinx SystemACE device driver, major=254
xilinx-xps-spi 82828000.xps-spi: no IRQ found
xilinx_emaclite 81000000.ethernet: Device Tree Probing
xilinx_emaclite 81000000.ethernet: no IRQ found
xilinx_emaclite: probe of 81000000.ethernet failed with error -1
i2c /dev entries driver
TCP cubic registered
Thanks!
liyafeng007
And the kernel config list
liyafeng007
And my dts file
liyafeng007
MHS file
# Created by Base System Builder Wizard for Xilinx EDK 10.1.03 Build EDK_K_SP3.6
# Thu Dec 23 16:40:22 2010
# Target Board: Xilinx Spartan-3A DSP 1800A Starter Board Rev 1
# Family: spartan3adsp
# Device: xc3sd1800a
# Package: fg676
# Speed Grade: -4
# Processor: microblaze_0
# System clock frequency: 62.50 MHz
# On Chip Memory : 8 KB
# Total Off Chip Memory : 128 MB
# - DDR2_SDRAM = 128 MB
PARAMETER VERSION = 2.1.0
PORT fpga_0_RS232_Uart_1_RX_pin = fpga_0_RS232_Uart_1_RX, DIR = I
PORT fpga_0_RS232_Uart_1_TX_pin = fpga_0_RS232_Uart_1_TX, DIR = O
PORT fpga_0_LEDs_8Bit_GPIO_d_out_pin = fpga_0_LEDs_8Bit_GPIO_d_out, DIR = O, VEC = [0:7]
PORT fpga_0_Push_Buttons_GPIO_in_pin = fpga_0_Push_Buttons_GPIO_in, DIR = I, VEC = [0:3]
PORT fpga_0_DIP_Switches_8Bit_GPIO_in_pin = fpga_0_DIP_Switches_8Bit_GPIO_in, DIR = I, VEC = [0:7]
PORT fpga_0_Ethernet_MAC_PHY_rst_n_pin = fpga_0_Ethernet_MAC_PHY_rst_n, DIR = O
PORT fpga_0_Ethernet_MAC_PHY_crs_pin = fpga_0_Ethernet_MAC_PHY_crs, DIR = I
PORT fpga_0_Ethernet_MAC_PHY_col_pin = fpga_0_Ethernet_MAC_PHY_col, DIR = I
PORT fpga_0_Ethernet_MAC_PHY_tx_data_pin = fpga_0_Ethernet_MAC_PHY_tx_data, DIR = O, VEC = [3:0]
PORT fpga_0_Ethernet_MAC_PHY_tx_en_pin = fpga_0_Ethernet_MAC_PHY_tx_en, DIR = O
PORT fpga_0_Ethernet_MAC_PHY_tx_clk_pin = fpga_0_Ethernet_MAC_PHY_tx_clk, DIR = I
PORT fpga_0_Ethernet_MAC_PHY_rx_er_pin = fpga_0_Ethernet_MAC_PHY_rx_er, DIR = I
PORT fpga_0_Ethernet_MAC_PHY_rx_clk_pin = fpga_0_Ethernet_MAC_PHY_rx_clk, DIR = I
PORT fpga_0_Ethernet_MAC_PHY_dv_pin = fpga_0_Ethernet_MAC_PHY_dv, DIR = I
PORT fpga_0_Ethernet_MAC_PHY_rx_data_pin = fpga_0_Ethernet_MAC_PHY_rx_data, DIR = I, VEC = [3:0]
PORT fpga_0_DDR2_SDRAM_DDR2_ODT_pin = fpga_0_DDR2_SDRAM_DDR2_ODT, DIR = O
PORT fpga_0_DDR2_SDRAM_DDR2_Addr_pin = fpga_0_DDR2_SDRAM_DDR2_Addr, DIR = O, VEC = [12:0]
PORT fpga_0_DDR2_SDRAM_DDR2_BankAddr_pin = fpga_0_DDR2_SDRAM_DDR2_BankAddr, DIR = O, VEC = [1:0]
PORT fpga_0_DDR2_SDRAM_DDR2_CAS_n_pin = fpga_0_DDR2_SDRAM_DDR2_CAS_n, DIR = O
PORT fpga_0_DDR2_SDRAM_DDR2_CE_pin = fpga_0_DDR2_SDRAM_DDR2_CE, DIR = O
PORT fpga_0_DDR2_SDRAM_DDR2_CS_n_pin = fpga_0_DDR2_SDRAM_DDR2_CS_n, DIR = O
PORT fpga_0_DDR2_SDRAM_DDR2_RAS_n_pin = fpga_0_DDR2_SDRAM_DDR2_RAS_n, DIR = O
PORT fpga_0_DDR2_SDRAM_DDR2_WE_n_pin = fpga_0_DDR2_SDRAM_DDR2_WE_n, DIR = O
PORT fpga_0_DDR2_SDRAM_DDR2_Clk_pin = fpga_0_DDR2_SDRAM_DDR2_Clk, DIR = O, VEC = [1:0]
PORT fpga_0_DDR2_SDRAM_DDR2_Clk_n_pin = fpga_0_DDR2_SDRAM_DDR2_Clk_n, DIR = O, VEC = [1:0]
PORT fpga_0_DDR2_SDRAM_DDR2_DM_pin = fpga_0_DDR2_SDRAM_DDR2_DM, DIR = O, VEC = [3:0]
PORT fpga_0_DDR2_SDRAM_DDR2_DQS = fpga_0_DDR2_SDRAM_DDR2_DQS, DIR = IO, VEC = [3:0]
PORT fpga_0_DDR2_SDRAM_DDR2_DQS_n = fpga_0_DDR2_SDRAM_DDR2_DQS_n, DIR = IO, VEC = [3:0]
PORT fpga_0_DDR2_SDRAM_DDR2_DQ = fpga_0_DDR2_SDRAM_DDR2_DQ, DIR = IO, VEC = [31:0]
PORT fpga_0_DDR2_SDRAM_DDR2_DQS_Div_I_pin = fpga_0_DDR2_SDRAM_DDR2_DQS_Div_I, DIR = I
PORT fpga_0_DDR2_SDRAM_DDR2_DQS_Div_O_pin = fpga_0_DDR2_SDRAM_DDR2_DQS_Div_O, DIR = O
PORT fpga_0_SPI_FLASH_MISO_pin = fpga_0_SPI_FLASH_MISO, DIR = IO
PORT fpga_0_SPI_FLASH_MOSI_pin = fpga_0_SPI_FLASH_MOSI, DIR = IO
PORT fpga_0_SPI_FLASH_SCK_pin = fpga_0_SPI_FLASH_SCK, DIR = IO
PORT fpga_0_SPI_FLASH_SS_pin = fpga_0_SPI_FLASH_SS, DIR = IO, VEC = [0:4]
PORT sys_clk_pin = dcm_clk_s, DIR = I, SIGIS = CLK, CLK_FREQ = 125000000
PORT sys_rst_pin = sys_rst_s, DIR = I, RST_POLARITY = 0, SIGIS = RST
BEGIN microblaze
PARAMETER INSTANCE = microblaze_0
PARAMETER HW_VER = 7.10.d
PARAMETER C_DEBUG_ENABLED = 1
PARAMETER C_FAMILY = spartan3adsp
PARAMETER C_INSTANCE = microblaze_0
PARAMETER C_USE_MMU = 3
PARAMETER C_MMU_TLB_ACCESS = 2
PARAMETER C_MMU_ZONES = 2
PARAMETER C_USE_ICACHE = 1
PARAMETER C_ICACHE_BASEADDR = 0x88000000
PARAMETER C_ICACHE_HIGHADDR = 0x88FFFFFF
PARAMETER C_USE_DCACHE = 1
PARAMETER C_DCACHE_BASEADDR = 0x88000000
PARAMETER C_DCACHE_HIGHADDR = 0x88FFFFFF
BUS_INTERFACE DPLB = mb_plb
BUS_INTERFACE IPLB = mb_plb
BUS_INTERFACE DEBUG = microblaze_0_dbg
BUS_INTERFACE DXCL = microblaze_0_DXCL
BUS_INTERFACE IXCL = microblaze_0_IXCL
BUS_INTERFACE DLMB = dlmb
BUS_INTERFACE ILMB = ilmb
PORT MB_RESET = mb_reset
PORT INTERRUPT = microblaze_0_INTERRUPT_0
END
BEGIN plb_v46
PARAMETER INSTANCE = mb_plb
PARAMETER HW_VER = 1.03.a
PORT PLB_Clk = sys_clk_s
PORT SYS_Rst = sys_bus_reset
PORT Bus_Error_Det = mb_plb_Bus_Error_Det
END
BEGIN lmb_v10
PARAMETER INSTANCE = ilmb
PARAMETER HW_VER = 1.00.a
PORT LMB_Clk = sys_clk_s
END
BEGIN lmb_v10
PARAMETER INSTANCE = dlmb
END
BEGIN lmb_bram_if_cntlr
PARAMETER INSTANCE = dlmb_cntlr
PARAMETER HW_VER = 2.10.a
PARAMETER C_BASEADDR = 0x00000000
PARAMETER C_HIGHADDR = 0x00001fff
BUS_INTERFACE SLMB = dlmb
BUS_INTERFACE BRAM_PORT = dlmb_port
END
PARAMETER INSTANCE = ilmb_cntlr
BUS_INTERFACE SLMB = ilmb
BUS_INTERFACE BRAM_PORT = ilmb_port
END
BEGIN bram_block
PARAMETER INSTANCE = lmb_bram
BUS_INTERFACE PORTA = ilmb_port
BUS_INTERFACE PORTB = dlmb_port
END
BEGIN xps_uartlite
PARAMETER INSTANCE = RS232_Uart_1
PARAMETER C_BAUDRATE = 9600
PARAMETER C_DATA_BITS = 8
PARAMETER C_ODD_PARITY = 0
PARAMETER C_USE_PARITY = 0
PARAMETER C_SPLB_CLK_FREQ_HZ = 62500000
PARAMETER C_BASEADDR = 0x84000000
PARAMETER C_HIGHADDR = 0x8400ffff
BUS_INTERFACE SPLB = mb_plb
PORT RX = fpga_0_RS232_Uart_1_RX
PORT TX = fpga_0_RS232_Uart_1_TX
PORT Interrupt = RS232_Uart_1_Interrupt
END
BEGIN xps_gpio
PARAMETER INSTANCE = LEDs_8Bit
PARAMETER C_GPIO_WIDTH = 8
PARAMETER C_IS_DUAL = 0
PARAMETER C_IS_BIDIR = 0
PARAMETER C_ALL_INPUTS = 0
PARAMETER C_BASEADDR = 0x81420000
PARAMETER C_HIGHADDR = 0x8142ffff
PORT GPIO_d_out = fpga_0_LEDs_8Bit_GPIO_d_out
END
BEGIN xps_gpio
PARAMETER INSTANCE = Push_Buttons
PARAMETER C_GPIO_WIDTH = 4
PARAMETER C_ALL_INPUTS = 1
PARAMETER C_BASEADDR = 0x81440000
PARAMETER C_HIGHADDR = 0x8144ffff
PORT GPIO_in = fpga_0_Push_Buttons_GPIO_in
END
BEGIN xps_gpio
PARAMETER INSTANCE = DIP_Switches_8Bit
PARAMETER C_BASEADDR = 0x81400000
PARAMETER C_HIGHADDR = 0x8140ffff
PORT GPIO_in = fpga_0_DIP_Switches_8Bit_GPIO_in
END
BEGIN xps_ethernetlite
PARAMETER INSTANCE = Ethernet_MAC
PARAMETER HW_VER = 2.00.b
PARAMETER C_SPLB_CLK_PERIOD_PS = 16000
PARAMETER C_BASEADDR = 0x81000000
PARAMETER C_HIGHADDR = 0x8100ffff
PORT PHY_rst_n = fpga_0_Ethernet_MAC_PHY_rst_n
PORT PHY_crs = fpga_0_Ethernet_MAC_PHY_crs
PORT PHY_col = fpga_0_Ethernet_MAC_PHY_col
PORT PHY_tx_data = fpga_0_Ethernet_MAC_PHY_tx_data
PORT PHY_tx_en = fpga_0_Ethernet_MAC_PHY_tx_en
PORT PHY_tx_clk = fpga_0_Ethernet_MAC_PHY_tx_clk
PORT PHY_rx_er = fpga_0_Ethernet_MAC_PHY_rx_er
PORT PHY_rx_clk = fpga_0_Ethernet_MAC_PHY_rx_clk
PORT PHY_dv = fpga_0_Ethernet_MAC_PHY_dv
PORT PHY_rx_data = fpga_0_Ethernet_MAC_PHY_rx_data
PORT IP2INTC_Irpt = Ethernet_MAC_IP2INTC_Irpt
END
BEGIN mpmc
PARAMETER INSTANCE = DDR2_SDRAM
PARAMETER HW_VER = 4.03.a
PARAMETER C_MEM_PARTNO = MT47H32M16-5E
PARAMETER C_MEM_DATA_WIDTH = 32
PARAMETER C_MEM_CLK_WIDTH = 2
PARAMETER C_MPMC_CLK0_PERIOD_PS = 8000
PARAMETER C_PIM1_BASETYPE = 1
PARAMETER C_PIM2_BASETYPE = 1
PARAMETER C_NUM_PORTS = 3
PARAMETER C_MPMC_BASEADDR = 0x88000000
PARAMETER C_MPMC_HIGHADDR = 0x8fffffff
BUS_INTERFACE SPLB0 = mb_plb
BUS_INTERFACE XCL2 = microblaze_0_DXCL
BUS_INTERFACE XCL1 = microblaze_0_IXCL
PORT DDR2_ODT = fpga_0_DDR2_SDRAM_DDR2_ODT
PORT DDR2_Addr = fpga_0_DDR2_SDRAM_DDR2_Addr
PORT DDR2_BankAddr = fpga_0_DDR2_SDRAM_DDR2_BankAddr
PORT DDR2_CAS_n = fpga_0_DDR2_SDRAM_DDR2_CAS_n
PORT DDR2_CE = fpga_0_DDR2_SDRAM_DDR2_CE
PORT DDR2_CS_n = fpga_0_DDR2_SDRAM_DDR2_CS_n
PORT DDR2_RAS_n = fpga_0_DDR2_SDRAM_DDR2_RAS_n
PORT DDR2_WE_n = fpga_0_DDR2_SDRAM_DDR2_WE_n
PORT DDR2_Clk = fpga_0_DDR2_SDRAM_DDR2_Clk
PORT DDR2_Clk_n = fpga_0_DDR2_SDRAM_DDR2_Clk_n
PORT DDR2_DM = fpga_0_DDR2_SDRAM_DDR2_DM
PORT DDR2_DQS = fpga_0_DDR2_SDRAM_DDR2_DQS
PORT DDR2_DQS_n = fpga_0_DDR2_SDRAM_DDR2_DQS_n
PORT DDR2_DQ = fpga_0_DDR2_SDRAM_DDR2_DQ
PORT DDR2_DQS_Div_I = fpga_0_DDR2_SDRAM_DDR2_DQS_Div_I
PORT DDR2_DQS_Div_O = fpga_0_DDR2_SDRAM_DDR2_DQS_Div_O
PORT MPMC_Clk0 = DDR2_SDRAM_mpmc_clk_s
PORT MPMC_Clk90 = DDR2_SDRAM_mpmc_clk_90_s
PORT MPMC_Rst = sys_periph_reset
END
BEGIN xps_spi
PARAMETER INSTANCE = SPI_FLASH
PARAMETER C_FIFO_EXIST = 1
PARAMETER C_SCK_RATIO = 64
PARAMETER C_NUM_SS_BITS = 5
PARAMETER C_BASEADDR = 0x82828000
PARAMETER C_HIGHADDR = 0x8282807f
PORT SPISEL = net_vcc
PORT MISO = fpga_0_SPI_FLASH_MISO
PORT MOSI = fpga_0_SPI_FLASH_MOSI
PORT SCK = fpga_0_SPI_FLASH_SCK
PORT SS = fpga_0_SPI_FLASH_SS
PORT IP2INTC_Irpt = SPI_FLASH_IP2INTC_Irpt
END
BEGIN clock_generator
PARAMETER INSTANCE = clock_generator_0
PARAMETER HW_VER = 2.01.a
PARAMETER C_EXT_RESET_HIGH = 1
PARAMETER C_CLKIN_FREQ = 125000000
PARAMETER C_CLKOUT0_FREQ = 62500000
PARAMETER C_CLKOUT0_BUF = TRUE
PARAMETER C_CLKOUT0_PHASE = 0
PARAMETER C_CLKOUT0_GROUP = NONE
PARAMETER C_CLKOUT1_FREQ = 125000000
PARAMETER C_CLKOUT1_BUF = TRUE
PARAMETER C_CLKOUT1_PHASE = 0
PARAMETER C_CLKOUT1_GROUP = DCM0
PARAMETER C_CLKOUT2_FREQ = 125000000
PARAMETER C_CLKOUT2_BUF = TRUE
PARAMETER C_CLKOUT2_PHASE = 90
PARAMETER C_CLKOUT2_GROUP = DCM0
PORT CLKOUT0 = sys_clk_s
PORT CLKOUT1 = DDR2_SDRAM_mpmc_clk_s
PORT CLKOUT2 = DDR2_SDRAM_mpmc_clk_90_s
PORT CLKIN = dcm_clk_s
PORT LOCKED = Dcm_all_locked
PORT RST = net_gnd
END
BEGIN mdm
PARAMETER INSTANCE = debug_module
PARAMETER HW_VER = 1.00.d
PARAMETER C_MB_DBG_PORTS = 1
PARAMETER C_USE_UART = 1
PARAMETER C_UART_WIDTH = 8
PARAMETER C_BASEADDR = 0x84400000
PARAMETER C_HIGHADDR = 0x8440ffff
BUS_INTERFACE MBDEBUG_0 = microblaze_0_dbg
PORT Debug_SYS_Rst = Debug_SYS_Rst
END
BEGIN proc_sys_reset
PARAMETER INSTANCE = proc_sys_reset_0
PARAMETER HW_VER = 2.00.a
PARAMETER C_EXT_RESET_HIGH = 0
PORT Slowest_sync_clk = sys_clk_s
PORT Dcm_locked = Dcm_all_locked
PORT Ext_Reset_In = sys_rst_s
PORT MB_Reset = mb_reset
PORT Bus_Struct_Reset = sys_bus_reset
PORT MB_Debug_Sys_Rst = Debug_SYS_Rst
PORT Peripheral_Reset = sys_periph_reset
END
BEGIN xps_intc
PARAMETER INSTANCE = xps_intc_0
PARAMETER C_BASEADDR = 0x86208000
PARAMETER C_HIGHADDR = 0x86209fff
PORT Intr = xps_timer_0_Interrupt&RS232_Uart_1_Interrupt
PORT Irq = microblaze_0_INTERRUPT_0
END
BEGIN xps_timer
PARAMETER INSTANCE = xps_timer_0
PARAMETER C_BASEADDR = 0x83c00000
PARAMETER C_HIGHADDR = 0x83c0ffff
PORT Interrupt = xps_timer_0_Interrupt
END
liyafeng007
It seems the kernel stop at init process in main.c
static void run_init_process(char *init_filename)
    argv_init[0] = init_filename;
    kernel_execve(init_filename, argv_init, envp_init);
but how to sovle the problem?
Thanks!
liyafeng007
Now it can boot to file system.
In microblaze configuration ,an option for MMU
Enable Access to Memory Management Special Registers should set to full
I think this option should be added in xilinx wikidot.com, It's not mentioned there.
It's helpfull for beginer.
linnj
I'm sort of confused, where are you saying you made this change, to the kernel config or the h/w project?
Our defconfigs turn on the MMU for the kernel configuration and for the h/w project the wiki says ...
  • The MMU in virtual mode and 2 memory protection zones
    I'm trying to figure out what needs to be clearer.
    liyafeng007
    Hi John
    I made this change in h/w project of MB configuration.
    I changed C_MMU_TLB_ACCESS from 2 to 3 in MHS file.
    Best Regards.
