Observer manikumar086
Microblaze linux kernel with JFFS2 FIle system
Anyone who tried or know how to build a linux kernel with JFFS2 File system for Microblaze processor, can you please reply how to do it?
- Kumar
Visitor raymondr99
Re: Microblaze linux kernel with JFFS2 FIle system
Hi Kumar,
Here is a brief list of steps to help you out.  It has been a while for me, so use it as a starting point.
Configuring the kernel for JFFS2 support.
  File systems->Miscellaneous filesystems->Journaling Flash File System v2 (JFFS2) support enabled.
  Device Drivers->Memory Technology Deivce support->Direct char device access to MTD devices enabled
  Device Drivers->Memory Technology Deivce support->Caching block device access to MTD devices enabled
If using SPI flash,
 Device Drivers->Memory Technology Deivce support->Self-contained MTD device drivers-> Support most SPI Flash chips
Remember, the <Help> field is your friend on these config pages.
You'll probably need to compile some utility apps to initilizing your flash.
http://elinux.org/CompilingMTDUtils
Hope that helps,
Raymond
