Missing GPIO sequence order in Linux
Hi, I have a device tree generated for the Vivado 2018.1 and the AXI GPIO sequence is not coming in the right order in the Linux. The GPIO address value and naming in the device tree is in sequence according to the AXI GPIO name and address assigned in the Vivado . But unfortunately in Linux I am not getting in the sequence. Thanks and Regards Akshay
AKSHAY
Hi Akshay
Can you please share more details on the issue. You mean petalinux is generating wrong pl.dtsi entries for gpio?
Best Regards
Shabbir
Hi Akshay
Best Regards
Shabbir
Hi akshay.bhat@iwavesystems,
This is resolved by giving the names of the GPIOs in Alphabetical order, then the sequence will be same on the Linux side.
Please let me know if the issue is not resolved.
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
