Missing /dev/media0 with hdmi rx driver
I've configured petalinux to use the hdmi rx subsystem and the driver "it's working", if I use the command:
cat /sys/devices/platform/amba_pl@0/a0010000.v_hdmi_rx_ss/hdmi_info
I get the following output:
  Stream Info
        Color Format:     RGB
        Color Depth:      8
        Pixels Per Clock: 4
        Mode:             Progressive
        Frame Rate:       30Hz
        Resolution:       4096x2160@30Hz
        Pixel Clock:      297000000
  Stream Timing
        HSYNC Timing: hav=4096, hfp=88, hsw=88(hsp=1), hbp=128, htot=4400
        VSYNC Timing: vav=2160, vfp=08, vsw=10(vsp=1), vbp=072, vtot=2250
Rx Info
Mode: HDMI
VIC : 100
Scrambled: 0
Audio
Format   : Unknown
Channels : 2
ACR CTS  : 0
ACR N    : 0
Link quality
Link quality channel 0 : excellent (0)
Link quality channel 1 : excellent (0)
Link quality channel 2 : excellent (0)
 So the hdmi it's working, but If I try with:
media-ctl -p -d /dev/media0
I get this error:
Failed to enumerate /dev/media0 (-2)
Checking in /dev/ I can't find media0 and video0.
I think it's a configuration problem, but I can't find what I'm missing.
Re: Missing /dev/media0 with hdmi rx driver
You have failing Media Device creation. Could you share your device-tree files?
This is the pl.dtsi
 * CAUTION: This file is automatically generated by Xilinx.
 * Version:
 * Today is: Thu Jul  4 07:34:54 2019
	amba_pl: amba_pl@0 {
		#address-cells = <2>;
		#size-cells = <2>;
		compatible = "simple-bus";
		ranges ;
		H26x_vcu: vcu@a0100000 {
			#clock-cells = <1>;
			#size-cells = <2>;
			clock-names = "pll_ref", "aclk", "vcu_core_enc", "vcu_core_dec", "vcu_mcu_enc", "vcu_mcu_dec";
			clocks = <&misc_clk_0>, <&zynqmp_clk 71>, <&H26x_vcu 1>, <&H26x_vcu 2>, <&H26x_vcu 3>, <&H26x_vcu 4>;
			compatible = "xlnx,vcu-1.2", "xlnx,vcu";
			interrupt-names = "vcu_host_interrupt";
			interrupt-parent = <&gic>;
			interrupts = <0 92 4>;
			ranges ;
			reg = <0x0 0xa0140000 0x0 0x1000>, <0x0 0xa0141000 0x0 0x1000>;
			reg-names = "vcu_slcr", "logicore";
			reset-gpios = <&gpio 79 0>;
			encoder: al5e@a0100000 {
				compatible = "al,al5e-1.2", "al,al5e";
				reg = <0x0 0xa0100000 0x0 0x10000>;
			decoder: al5d@a0120000 {
				compatible = "al,al5d-1.2", "al,al5d";
				reg = <0x0 0xa0120000 0x0 0x10000>;
		misc_clk_0: misc_clk_0 {
			#clock-cells = <0>;
			clock-frequency = <33000179>;
			compatible = "fixed-clock";
		HDMI_v_hdmi_rx_ss_0: v_hdmi_rx_ss@a0010000 {
			clock-names = "s_axi_cpu_aclk", "link_clk", "s_axis_audio_aclk", "video_clk", "s_axis_video_aclk";
			clocks = <&misc_clk_1>, <&misc_clk_2>, <&misc_clk_1>, <&misc_clk_3>, <&misc_clk_1>;
			compatible = "xlnx,v-hdmi-rx-ss-3.1", "xlnx,v-hdmi-rx-ss-3.1";
			interrupt-names = "irq";
			interrupts = <0 90 4>;
			reg = <0x0 0xa0010000 0x0 0x10000>;
			xlnx,edid-ram-size = <0x100>;
			xlnx,input-pixels-per-clock = <4>;
			xlnx,max-bits-per-component = <8>;
			hdmirx_ports: ports {
				#address-cells = <1>;
				#size-cells = <0>;
		misc_clk_1: misc_clk_1 {
			#clock-cells = <0>;
			clock-frequency = <148501562>;
		misc_clk_2: misc_clk_2 {
			#clock-cells = <0>;
			clock-frequency = <148500000>;
		misc_clk_3: misc_clk_3 {
			#clock-cells = <0>;
			clock-frequency = <297000000>;
		HDMI_vid_phy_controller_0: vid_phy_controller@a0030000 {
			clock-names = "mgtrefclk1_pad_p_in", "mgtrefclk1_pad_n_in", "vid_phy_rx_axi4s_aclk", "vid_phy_sb_aclk", "vid_phy_axi4lite_aclk", "drpclk";
			clocks = <&misc_clk_4>, <&misc_clk_4>, <&misc_clk_2>, <&misc_clk_1>, <&misc_clk_1>, <&misc_clk_1>;
			compatible = "xlnx,vid-phy-controller-2.2", "xlnx,vid-phy-controller-2.1";
			interrupts = <0 91 4>;
			reg = <0x0 0xa0030000 0x0 0x10000>;
			xlnx,hdmi-fast-switch = <1>;
			xlnx,nidru = <0>;
			xlnx,nidru-refclk-sel = <5>;
			xlnx,rx-no-of-channels = <3>;
			xlnx,rx-pll-selection = <0>;
			xlnx,rx-protocol = <1>;
			xlnx,rx-refclk-sel = <1>;
			xlnx,transceiver-type = <5>;
			xlnx,transceiver-width = <4>;
			xlnx,tx-buffer-bypass = <1>;
			xlnx,tx-no-of-channels = <3>;
			xlnx,tx-pll-selection = <6>;
			xlnx,tx-protocol = <3>;
			xlnx,tx-refclk-sel = <0>;
			vphy_lane0: vphy_lane@0 {
				#phy-cells = <4>;
			vphy_lane1: vphy_lane@1 {
				#phy-cells = <4>;
			vphy_lane2: vphy_lane@2 {
				#phy-cells = <4>;
			vphy_lane3: vphy_lane@3 {
				#phy-cells = <4>;
		misc_clk_4: misc_clk_4 {
			#clock-cells = <0>;
			clock-frequency = <100000000>;
		psu_ctrl_ipi: PERIPHERAL@ff380000 {
			compatible = "xlnx,PERIPHERAL-1.0";
			reg = <0x0 0xff380000 0x0 0x80000>;
		psu_message_buffers: PERIPHERAL@ff990000 {
			reg = <0x0 0xff990000 0x0 0x10000>;
		stream_ddr: v_frmbuf_wr@a0020000 {
			#dma-cells = <1>;
			clock-names = "ap_clk";
			clocks = <&zynqmp_clk 71>;
			compatible = "xlnx,v-frmbuf-wr-2.1", "xlnx,axi-frmbuf-wr-v2.1";
			interrupt-names = "interrupt";
			interrupts = <0 89 4>;
			reg = <0x0 0xa0020000 0x0 0x10000>;
			reset-gpios = <&gpio 78 1>;
			xlnx,dma-addr-width = <32>;
			xlnx,dma-align = <32>;
			xlnx,max-height = <2160>;
			xlnx,max-width = <4096>;
			xlnx,pixels-per-clock = <4>;
			xlnx,s-axi-ctrl-addr-width = <0x7>;
			xlnx,s-axi-ctrl-data-width = <0x20>;
			xlnx,vid-formats = "yuyv", "nv12", "nv16";
			xlnx,video-width = <8>;
		v_tpg: v_tpg@a0000000 {
			clocks = <&misc_clk_1>;
			compatible = "xlnx,v-tpg-8.0", "xlnx,v-tpg-7.0";
			reg = <0x0 0xa0000000 0x0 0x10000>;
			xlnx,ppc = <4>;
			xlnx,s-axi-ctrl-addr-width = <8>;
			xlnx,s-axi-ctrl-data-width = <32>;
And this is my system-user.dtsi (in this file I've added the phys and phy-names)
	reserved-memory {
		#size-cells = <2>;
		ranges;
		reserved: buffer@0 {
			compatible = "shared-dma-pool";
			reusable;
			reg = <0x0 0x0E000000 0x0 0x1F400000>;
	reserved-video-driver@0 {
		compatible = "xlnx,reserved-memory";
		memory-region = <&reserved>;
&HDMI_v_hdmi_rx_ss_0{
	status = "okay";
	phy-names = "hdmi-phy0", "hdmi-phy1", "hdmi-phy2";
	phys = <&vphy_lane0 0 1 1 0>, <&vphy_lane1 0 1 1 0>, <&vphy_lane2 0 1 1 0>;
	ports {
		#size-cells = <0>;
		port@0 {
			reg = <0>;
			hdmi_rxss_out: endpoint {
				remote-endpoint = <&v_tpg>;
&v_tpg {
	status = "okay";
	compatible = "xlnx,v-tpg-8.0", "xlnx,v-tpg-5.0";
	ports {
		#size-cells = <0>;
		port@0 {
			reg = <0>;
			xlnx,video-format = <0>;
			tpg_out: endpoint {
				remote-endpoint = <&stream_ddr>;
It looks like you are missing the Xilinx V4L2 driver device tree entry. Please see; https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841767/Xilinx+V4L2+driver
Also make sure the DT reflects your video pipeline correctly; Video Phy -> hdmi_rx_ss -> tpg -> ddr3 ?
So in this case I need to create an entry for the hdmi inside the system-user file. If I'm correct, I have to add a entry with a port (as input) and remote-endpoint to HDMI_v_hdmi_rx_ss_0 or I have to create the entire pipeline?
&amba_pl {
	axi_video_cap {
		compatible = "xlnx,axi-video";
		ports {
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				direction = "input";
				vcap_in0: endpoint {
					remote-endpoint = <&HDMI_v_hdmi_rx_ss_0>;
The video pipeline is Video phy -> hdmi_rx_ss -> tpg -> frm_wr -> ddr3.
You should add an entry for the 'vcap' to the system-user.dtsi. However I am not sure about the 'compatible = "xlnx,axi-video"' part from the web page.
Below is hdmi dtsi file of  zcu104-rv-ss trd design. In this example 'scaler' is connected to the wr_framebuffer at PL.
Best Regards.
Mustafa
#include <dt-bindings/media/xilinx-vip.h>
&amba {
	hdmi_rxss: hdmi_rxss@a1000000 {
		compatible = "xlnx,v-hdmi-rx-ss-3.1";
		reg = <0x0 0xa1000000 0x0 0x10000>;
		reg-names = "hdmi-rxss";
		interrupts = <2 2>;
		interrupt-parent = <&axi_intc>;
		interrupt-names = "hdmirx";
		clocks = <&axi_lite_clk>, <&axi_stream_clk>;
		clock-names = "axi-lite", "video";
		xlnx,input-pixels-per-clock = <2>;
		ports {
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				xlnx,video-format = <XVIP_VF_RBG>;
					remote-endpoint = <&scaler_2_in>;
	scaler_2: scaler@b0100000 {
		compatible = "xlnx,v-vpss-scaler";
		reg = <0x0 0xb0100000 0x0 0x40000>;
		clocks = <&axi_stream_clk>;
		xlnx,num-hori-taps = <8>;
		xlnx,num-vert-taps = <8>;
		xlnx,pix-per-clk = <2>;
		reset-gpios = <&gpio 87 1>;
		xlnx,max-width = <3840>;
		ports {
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				scaler_2_in: endpoint {
					remote-endpoint = <&hdmi_rxss_out>;
			port@1 {
				reg = <1>;
				xlnx,video-format = <XVIP_VF_YUV_422>;
				scaler_2_out: endpoint {
					remote-endpoint = <&vcap_hdmi_in>;
	fb_wr_hdmirx: fb_wr@b0070000 {
		compatible = "xlnx,axi-frmbuf-wr-v2.1";
		reg = <0x0 0xb0070000 0x0 0x10000>;
		#dma-cells = <1>;
		interrupts = <1 2>;
#ifdef DESIGN_BASE_TRD
		xlnx,vid-formats = "yuyv", "uyvy", "y8";
#endif
#ifdef DESIGN_RV_SS
		xlnx,vid-formats = "yuyv", "uyvy", "y8", "rgb888";
#endif
		reset-gpios = <&gpio 88 1>;
		xlnx,pixels-per-clock = <2>;
	vcap_hdmi {
		compatible = "xlnx,video";
		dmas = <&fb_wr_hdmirx 0>;
		dma-names = "port0";
		ports {
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				vcap_hdmi_in: endpoint {
					remote-endpoint = <&scaler_2_out>;
what was your final solution? what solved your issue?
