Mount filesystem from sd card
I have compiled linux uboot and rootfs by  method provided on below mentioned link.
http://www.wiki.xilinx.com/Build+Linux+for+Zynq-7000+AP+SoC+using+Buildroot
now issue i am facing is that my filesystem is RAMFS. i Want my filesystem to be on second partition of sd card.
and kernel should refer that filesystem while booting.
can anyone please tell how to achieve this?
Tags (3)
HI,
Make 2 partitions on your SD card :
1. FAT32 - "BOOT" >> boot.bin, image.ub, system.dtb, Image files
2. EXT4 - "ROOTFS" >> extracted rootfs.tar.gz in this .
Load kernel and device-tree:
ZynqMP> fatload mmc 0:1 0x3000000 uImage.ub
ZynqMP> fatload mmc 0:1 0x2A00000 system.dtb
ZynqMP> bootm 0x3000000 - 0x2A00000
Tell to the kernel where the rootfs is :
ZynqMP> setenv bootargs 'earlycon earlyprintk root=/dev/mmcblk0p1 rw rootfstype=ext4
Cheers,
Trigger
Hi, hello or what you want ...
 unpack rootfs.cpio.uboot from the project directory to the partition (you will need to issue the command with the root privileges).
Cheers,
Trigger
What version of the tools?
For newer versions, (2017.3/2017.4), use the tar.gz and unzip that onto your second partition. For older versions use the .cpio.
I have unpacked rootfs in second partition and its name is ROOTFS with type FAT16.
I dont know how to tell uboot to use rootfs which is on second partition.
HI,
Cheers,
Trigger
Not working last print on console is staring kernel.
Do i need to make changes in linux-menuconfig?
Hi @rahul_cg,
Refer UG1144 "Configuring SD Card ext filesystem Boot" section.
Sandeep
