Multi-stream Transcoding with VCU IP
I am trying to transcode 2 H264 encoded 4K@30fps videos at the same time with ZCU104 board.
For transcoding just one video I use the pipeline which has worked:
gst-launch-1.0 filesrc location="part1.mp4" ! qtdemux name=demux demux.video_0 ! h264parse ! video/x-h264, alignment=au ! omxh264dec low-latency=0 ! omxh265enc ! video/x-h265, alignment=au ! filesink location="output_1.h265"
To transcode two videos, I use the pipeline below:
gst-launch-1.0 filesrc location="part1.mp4" ! qtdemux name=demux demux.video_0 ! h264parse ! video/x-h264, alignment=au ! omxh264dec low-latency=0 ! omxh265enc ! video/x-h265, alignment=au ! filesink location="output_1.h265" & gst-launch-1.0 filesrc location="part2.mp4" ! qtdemux name=demux demux.video_0 ! h264parse ! video/x-h264, alignment=au ! omxh264dec low-latency=0 ! omxh265enc ! video/x-h265, alignment=au ! filesink location="output_2.h265"
But it hasnt worked.
I get these messages:
[1] 2633
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Redistribute latency...
!! The specified Level is too low and will be adjusted !!
[ 126.746805] al5e a0100000.al5e: swiotlb: coherent allocation failed, size=13058048
[ 126.754404] CPU: 0 PID: 2639 Comm: gst-launch-1.0 Tainted: G O 4.19.0-xilinx-v2019.1 #1
[ 126.763692] Hardware name: ZynqMP ZCU104 RevC (DT)
Redistribute latency...[ 126.768466] Call trace:
[ 126.772907] dump_backtrace+0x0/0x148
[ 126.776714] show_stack+0x14/0x20
[ 126.780013] dump_stack+0x90/0xb4
[ 126.783321] swiotlb_alloc+0x160/0x168
[ 126.787061] __dma_alloc+0xa8/0x1e0
[ 126.790548] al5_alloc_dma+0xa8/0x140 [allegro]
[ 126.795065] al5_bufpool_allocate+0xc8/0x170 [allegro]
[ 126.800195] al5e_user_create_channel+0x14c/0x340 [al5e]
[ 126.805496] al5e_ioctl+0x15c/0x4e0 [al5e]
[ 126.809578] do_vfs_ioctl+0xb8/0x8a0
[ 126.813143] ksys_ioctl+0x44/0x90
[ 126.816442] __arm64_sys_ioctl+0x1c/0x28
[ 126.820348] el0_svc_common+0x84/0xd8
[ 126.824002] el0_svc_handler+0x68/0x80
[ 126.827733] el0_svc+0x8/0xc
[ 126.830636] al5e a0100000.al5e: Failed internal buffers allocation, channel wasn't created
Failed to create Encoder:
/!\ ERROR:encoder: memory allocation failure (firmware or ctrlsw) (135)[ 126.849409] al5e a0100000.al5e: swiotlb: coherent allocation failed, size=13058048
[E] [TreatSetStateCommand]: OMX_ErrorInsufficientResources
ER[ 126.860549] CPU: 2 PID: 2640 Comm: gst-launch-1.0 Tainted: G O 4.19.0-xilinx-v2019.1 #1
ROR: from element /GstPipeline:pipeline0/GstOMXH265Enc-omxh265en[ 126.875368] Hardware name: ZynqMP ZCU104 RevC (DT)
c:omxh265enc-omxh265enc0: GStreamer encountered a general suppor[ 126.885697] Call trace:
ting library error.
Additional debug info:
../../git/omx/gstom[ 126.893692] dump_backtrace+0x0/0x148
xvideoenc.c(3424): gst_omx_video_enc_handle_frame (): /GstPipeli[ 126.902886] show_stack+0x14/0x20
ne:pipeline0/GstOMXH265Enc-omxh265enc:omxh265enc-omxh265enc0:
F[ 126.911740] dump_stack+0x90/0xb4
ailed to enable OMX encoder: Insufficient resources (0x80001000)[ 126.920595] swiotlb_alloc+0x160/0x168
ERROR: pipeline doesn't want to preroll.
Setting pipeline to [ 126.929881] __dma_alloc+0xa8/0x1e0
NULL ...
[ 126.938913] al5_alloc_dma+0xa8/0x140 [allegro]
[ 126.944291] al5_bufpool_allocate+0xc8/0x170 [allegro]
[ 126.949420] al5e_user_create_channel+0x14c/0x340 [al5e]
[ 126.954722] al5e_ioctl+0x15c/0x4e0 [al5e]
[ 126.958804] do_vfs_ioctl+0xb8/0x8a0
[ 126.962370] ksys_ioctl+0x44/0x90
[ 126.965668] __arm64_sys_ioctl+0x1c/0x28
[ 126.969574] el0_svc_common+0x84/0xd8
[ 126.973220] el0_svc_handler+0x68/0x80
[ 126.976951] el0_svc+0x8/0xc
[ 126.979850] al5e a0100000.al5e: Failed internal buffers allocation, channel wasn't created
ERROR: from element /GstPipeline:pipeline0/GstOMXH265Enc-omxh265enc:omxh265enc-omxh265enc0: GStreamer encountered a general supporting library error.
../../git/omx/gstomxvideoenc.c(3424): gst_omx_video_enc_handle_frame (): /GstPipeline:pipeline0/GstOMXH265Enc-omxh265enc:omxh265enc-omxh265enc0:
Failed to enable OMX encoder: Insufficient resources (0x80001000)
Setting pipeline to NULL ...
Freeing pipeline ...
Does anybody have an idea to solve this problem ? I am stuck :(
