Multiple Ethernet Setup using Zynq's Gem0 & Axi_ethernet(Dma)
Good day Everyone,
Was attempting to setup the above mention setup using Zynq-7000 on petalinux 2015.4. The design info and settings are on the attached below. I have connected all the interrupts and setup the necessary IPs needed for the axi_ethernet to work on the 1000-BaseX. The compile kernel was able to boot with GEM0 as the main ethernet (eth0) and axi_ethernet (eth1) being able to be probed. However kernel panic (picture as attached below) occues when i tried to set an ip addr for the axi_ethernet, why is that so? I am not good at debug kernel panic and might need some advise.
Any help is appreciated,
thanks alot!Addr_allocationAddr_allocationAxi_Dma SettingsAxi_Dma SettingsAxi_ethernet settingsAxi_ethernet settingsbd_intc_connection.pngbd3.pngpl.dtsipl.dtsisystem-top.dtssystem-top.dtsthe kernel panic =(the kernel panic =(
Hi @jqsam1
You can take xapp1082 as a reference
https://www.xilinx.com/support/documentation/application_notes/xapp1082-zynq-eth.pdf
Best Regards
Shabbir
Goodday,
i have tried refering to xapp1082 and the same error occurs.
