Multiple phy on mdio uboot problem
Hi, i succesfully run kernel with multiple phy on mdio (4 in my case), using the recommendation of the macb wiki page ethernet is working (even if i can't put all the interfaces in the same subnet don't know why)
I can't ping in uboot anyway, but i can read the mdio registers of all the phy.
What should i do?
In the device tree, the mdio is inside the ethernet controller that is connected to the mdio lines.
i haven't applied any patches, Vivado 2019.2
Re: Multiple phy on mdio uboot problem
after struggling i found this AR# 72620 and now i can use 1 eth port, the others don't work
there is still need for a patch?
Actually the device tree looks like this and it works in linux but not in u boot
&gem0 {
phy-handle = <&phy0>;
mdio {
	#address-cells = <1>;
	#size-cells = <0>;
		phy0:phy@0 {
			device_type = "ethernet-phy";
			reg = <0>;
		phy1:phy@1 {
			reg = <1>;
		phy2:phy@2 {
			reg = <2>;
		phy3:phy@3 {
			reg = <3>;
phy0 {
        reg = <0x0>;
phy1 {
        reg = <0x1>;
phy2 {
        reg = <0x2>;
phy3 {
        reg = <0x3>;
&gem1 {
phy-handle = <&phy1>;
&gem2 {
phy-handle = <&phy2>;
&gem3 {
phy-handle = <&phy3>;
What should i do to integrate/modificate to have 1 ethernet in u boot?
Is there a patch available to the uboot-xilinx-v2019.1 or uboot-xilinx-v2019.2 to support an Ethernet PHY connected on GEM3 (SGMII3) while MDIO for this PHY is connected with GEM1?
&gem1 {
 phy-mode = "sgmii";
 status = "okay";
 xlnx,ptp-enet-clock = <0x0>;
 phys = <&lane3 PHY_TYPE_SGMII 3 1 125000000>;
 is-internal-pcspma;
 mdio {
  phy9: phy@9 {
   reg = <0x9>;
&gem3 {
 phy-mode = "sgmii";
 status = "okay";
 local-mac-address = [0a ff 00 00 00 99];
 phy-handle = <&phy9>;
 is-internal-pcspma;
 xlnx,has-mdio = <0x0>;
Above works from Linux Kernel but It seems uboot expects MDIO on the same GEM and the data path?
ZynqMP> mdio list
eth0:
eth1:
9 - Generic PHY <--> ethernet@ff0e0000
ZynqMP>
I appreciate a response for this problem.
