Scholar mrbietola
Multiple phy on mdio uboot problem
Hi, i succesfully run kernel with multiple phy on mdio (4 in my case), using the recommendation of the macb wiki page ethernet is working (even if i can't put all the interfaces in the same subnet don't know why)
I can't ping in uboot anyway, but i can read the mdio registers of all the phy.
What should i do?
In the device tree, the mdio is inside the ethernet controller that is connected to the mdio lines.
i haven't applied any patches, Vivado 2019.2
Scholar mrbietola
Re: Multiple phy on mdio uboot problem
after struggling i found this AR# 72620 and now i can use 1 eth port, the others don't work
Scholar mrbietola
there is still need for a patch?
Scholar mrbietola
Actually the device tree looks like this and it works in linux but not in u boot
&gem0 {
phy-handle = <&phy0>;
mdio {
	#address-cells = <1>;
	#size-cells = <0>;
		phy0:phy@0 {
			device_type = "ethernet-phy";
			reg = <0>;
		phy1:phy@1 {
			reg = <1>;
		phy2:phy@2 {
			reg = <2>;
		phy3:phy@3 {
			reg = <3>;
phy0 {
        reg = <0x0>;
phy1 {
        reg = <0x1>;
phy2 {
        reg = <0x2>;
phy3 {
        reg = <0x3>;
&gem1 {
phy-handle = <&phy1>;
&gem2 {
phy-handle = <&phy2>;
&gem3 {
phy-handle = <&phy3>;
What should i do to integrate/modificate to have 1 ethernet in u boot?
Scholar mrbietola
