Participant gauss_work
My custom board failed to boot CPU1 when booting linux in SMP mode
Hi,All
I'm using Petalinux2015.2.
The linux kernel SMP option is default enabled!  From the linux booting log .I Found the CPU1 is not booting.
The log prints:
Setting up static identity map for 0x472998 - 0x4729f0
CPU1: failed to come online
Brought up 1 CPUs
SMP: Total of 1 processors activated (1594.16 BogoMIPS).
Any suggestions are appreciated!
Re: My custom board failed to boot CPU1 when booting linux in SMP mode
Sorry for my delayed response!
It's my mistake. I've used SDK to set up linux by JTAG.So the jtag can only  initialize a single CPU core.
When booting from Flash,all the 2 CPU cores can set up ok!
Thanks anyway!
Hi @gauss_work,
Zynq 7000 series ?
If yes try to add that to dts:
&intc {
   num_cpus = <2>;
   num_interrupts = <96>;
cheers,
Trigger
hi,@trigger
thanks for your advice,but with no luck,cpu1 can not be set up! I will try a higher edition of petalinux!
SPM init is depend on smp_secondary_init which calls interanlly arch/arm/mach-zynq/platsmp.c file
there it identifies secondary_init_cpus and provides to Board with set of sequential calls,
These function calls are completely Platform specfic and it should be up with zynq-linux kernel itself
If not check any patch is missed relate to platsmp.c file or corrspending mechanism
Thanks & Regards
Satish G
G Satish Kumar
Thanks anyway!
