hbachmann
NAND Flash: U-Boot is using on-die ECC instead of HW-ECC
we've a custom board using NAND Flash 'Micron MT29F8G08ADADAH4', which is not in the approved list shown in UG908
but the nearly similar MT29F8G08AB is in the list.
I have problems in U-Boot to read correct data from our NAND Flash when it's been written in Linux and vice versa.
We're using PetaLinux and Vivado 2019.1 and ZynqMP.
It seems that U-Boot is using per default on-die ECC and the Kernel HW-ECC.
How can I bring U-Boot to use HW-ECC? In the arasan_nfc.c driver I cannot see any devicetree readings.
I've tried to hard code HW-ECC (by disabling the call to function 'arasan_check_ondie(mtd)' in 'arasan_nand_init()'), but the read errors occours even more...
Here's the relevant part of my devicetree files:
zynqmp.dtsi:
		nand0: nand@ff100000 {
			compatible = "arasan,nfc-v3p10";
			status = "disabled";
			reg = <0x0 0xff100000 0x0 0x1000>;
			clock-names = "clk_sys", "clk_flash";
			interrupt-parent = <&gic>;
			interrupts = <0 14 4>;
			#address-cells = <1>;
			#size-cells = <0>;
			#stream-id-cells = <1>;
			iommus = <&smmu 0x872>;
			power-domains = <&zynqmp_firmware 44>;
pcw.dtsi:
&nand0 {
	status = "okay";
system-conf.dtsi:
&nand0 {
	#size-cells = <1>;
zynqmp-clk-ccf.dtsi:
&nand0 {
	clocks = <&zynqmp_clk 60>, <&zynqmp_clk 31>;
system-user.dtsi:
&nand0 {
	nand@0 {
		reg = <0>;
		nand-ecc-mode = "hw";
		nand-bus-width = <0x8>;
		nand-on-flash-bbt = "true";
		nand-ecc-algo = "bch";
		nand-ecc-strength = <4>;
		nand-ecc-step-size = <528>;
		nand-ecc-maximize = "true";
		nand-is-boot-medium = "true";
		partitions {
			compatible = "fixed-partitions";
			#size-cells = <1>;
			partition@0 {
				label = "BOOT1";
				reg = <0x0 0x00500000>;
			partition@1 {
				label = "TEST1";
				reg = <0x00A00000 ...
Thanks for any help!
hbachmann
does nobody write/read to/from NAND from running U-Boot/Linux?
Also everybody using UBIFS with NAND should have a problem with 2019.1 (especially writing a ubi image in U-Boot and 'ubiattach' from linux)
Helmut
ottob
Arasan NAND driver is not maintained very well. It worked OK wit Micron (On-Die) chips in 2017.3, but then in 2018.2 it was broken. Not sure if they fixed it for 2019.1. I've spent/wasted lots of time on this, see my other posts in here. Basically we opted to use On-Die ECC in both U-boot and the Kernel. Using MIcron MT29F4G08
hbachmann
Thanks OttoB to your suggestions!
shabbirk
Hi @ottob @hbachmann
We need to use the same ECC for both the u-boot and kernel. It could be either on-die or HW ECC.
From your device tree, it look you have enabled “hw” ECC in case of Linux. You can try changing it to have nand-ecc-mode = "on-die";
In u-boot, the driver reads parameters from NAND device. If the device supports on-die ECC, it is then enabled in the driver too.
I would recommend enabling on-die ecc in linux and see if that helps.
Best Regards
Shabbir
hbachmann
Thanks Shabbir for your answer,
to change the devicetree to
has no influence on arasan linux driver in 2019.1.
I agree that u-boot and linux should use the same ECC mechanism.
Helmut
flind@mit.edu
We have an identical device on a custom Zynq 7000 board. Were you ever able to solve this issue?
Frank
ottob
Hi Frank !
Here is the patch. I've learned one thing through the months spent on this - Avoid raw flash w/ On-Die ECC like the plague if you want to use it with Xilinx devices. eMMC seems to be the way everyone is going
MIT ! Interesting, you working on anything exciting ?
/Otto
flind@mit.edu
Thanks very much! We are building a couple of cubesats at the moment.
ottob
Just to clarify - The solution was to run on-Die ECC on both u-boot and in Linux
