Voyager
Voyager
NAND Support after updating from 2016.3 to 2017.4
Hi all,
After updating linux-xlnx from 4.6(tag v2016.3) to 4.9 (tag v2017.4) i'm able to access to UBIFS part even if I formate all the part...
flash_erase /dev/mtd5 0 0
ubiformat /dev/mtd5 -O 2048
ubiattach /dev/ubi_ctrl -m 5 -O 2048
Erasing 128 Kibyte @ 31e0000 -- 98 % complete flash_erase: Skipping bad block at 03200000
flash_erase: Skipping bad block at 03220000
flash_erase: Skipping bad block at 03240000
flash_erase: Skipping bad block at 03260000
Erasing 128 Kibyte @ 3260000 -- 100 % complete
ubiformat: mtd5 (nand), size 52953088 bytes (50.5 MiB), 404 eraseblocks of 131072 bytes (128.0 KiB), min. I/O size 2048 bytes
libscan: scanning eraseblock 403 -- 100 % complete
ubiformat: 400 eraseblocks are supposedly empty
ubiformat: 4 bad eraseblocks found, numbers: 400, 401, 402, 403
ubiformat: formatting eraseblock 362 -- 89 % comubi0: attaching mtd0
ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 0:0, read only 64 bytes, retry
ubiformaubi0 warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 0:0, read only 64 bytes, retry
ubiformat: formaubi0 warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 0:0, read only 64 bytes, retry
ubiformat: formatting erubi0 error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 0:0, read 64 bytes
ubiformat: formatting eraseblockCPU: 0 PID: 1912 Comm: ubiattach Not tainted 4.9.0-xilinx #2
Hardware name: Xilinx Zynq Platform
[<c010e394>] (unwind_backtrace) from [<c010a5b0>] (show_stack+0x10/0x14)
[<c010a5b0>] (show_stack) from [<c02de9ec>] (dump_stack+0x80/0x9c)
[<c02de9ec>] (dump_stack) from [<c03f61ec>] (ubi_io_read+0x1d8/0x2ac)
[<c03f61ec>] (ubi_io_read) from [<c03f64e0>] (ubi_io_read_ec_hdr+0x68/0x1d4)
[<c03f64e0>] (ubi_io_read_ec_hdr) from [<c03fab14>] (ubi_attach+0x17c/0x1130)
[<c03fab14>] (ubi_attach) from [<c03f0fc4>] (ubi_attach_mtd_dev+0x600/0xac8)
[<c03f0fc4>] (ubi_attach_mtd_dev) from [<c03f2544>] (ctrl_cdev_ioctl+0x178/0x1f4)
[<c03f2544>] (ctrl_cdev_ioctl) from [<c01ddc4c>] (vfs_ioctl+0x18/0x3c)
[<c01ddc4c>] (vfs_ioctl) from [<c01de50c>] (do_vfs_ioctl+0x778/0x8cc)
[<c01de50c>] (do_vfs_ioctl) from [<c01de694>] (SyS_ioctl+0x34/0x5c)
[<c01de694>] (SyS_ioctl) from [<c0106d40>] (ret_fast_syscall+0x0/0x3c)
Some info to help:
root@pti1549 ~ # uname -a
Linux pti1547-dev 4.9.0-xilinx #2 SMP PREEMPT Thu May 3 17:07:44 CEST 2018 armv7l GNU/Linux
nand: device found, Manufacturer ID: 0x01, Chip ID: 0xda
nand: AMD/Spansion S34ML02G1
nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
nand_bbt: ECC error in BBT at 0x00000ffe0000
nand_bbt: ECC error in BBT at 0x00000ffc0000
Scanning device for bad blocks
Bad block table written to 0x00000ffe0000, version 0x01
Bad block table written to 0x00000ffc0000, version 0x01
6 ofpart partitions found on MTD device pl35x-nand
Creating 6 MTD partitions on "pl35x-nand":
root@pti1549 ~ # mtdinfo /dev/mtd5
mtd5
Type:                           nand
Eraseblock size:                131072 bytes, 128.0 KiB
Amount of eraseblocks:          404 (52953088 bytes, 50.5 MiB)
Minimum input/output unit size: 2048 bytes
Sub-page size:                  512 bytes
OOB size:                       64 bytes
Character device major/minor:   90:10
Bad blocks are allowed:         true
Device is writable:             true
root@pti1549 ~ # mtd_debug info /dev/mtd5
mtd.type = MTD_NANDFLASH
mtd.flags = MTD_CAP_NANDFLASH
mtd.size = 52953088 (50M)
mtd.erasesize = 131072 (128K)
mtd.writesize = 2048 (2K)
mtd.oobsize = 64
regions = 0
Any advice ?
Cheers,
Trigger
Voyager
Voyager
Re: NAND Support after updating from 2016.3 to 2017.4
Hi all,
Without Xilinx answer let's go for dirty pach:
# Clone repo
git clone https://github.com/Xilinx/linux-xlnx.git
cd linux-xlnx
# Set cross compil and arch
export ARCH=arm
export CROSS_COMPILE=arm-linux-gnueabi-
# Config
make xilinx_zynq_defconfig
# NAND / MTD / UBI
make menuconfig
# Fix troubles
git checkout xilinx-v2016.3 drivers/mtd/mtdchar.c
git checkout xilinx-v2016.3 drivers/mtd/mtdconcat.c
git checkout xilinx-v2016.3 drivers/mtd/mtdcore.c
git checkout xilinx-v2016.3 drivers/mtd/mtdpart.c
git checkout xilinx-v2016.3 drivers/mtd/nand/nand_base.c
git checkout xilinx-v2016.3 drivers/mtd/nand/nand_ids.c
git checkout xilinx-v2016.3 drivers/mtd/nand/nand_timings.c
git checkout xilinx-v2016.3 drivers/mtd/nand/pl35x_nand.c
git checkout xilinx-v2016.3 include/linux/mtd/mtd.h
git checkout xilinx-v2016.3 include/linux/mtd/nand.h
git checkout xilinx-v2016.3 include/linux/of_mtd.h
# build
make -j5 ARCH=arm UIMAGE_LOADADDR=0x8000 uImage
I's dirty but it works,
Trigger
