08-22-2018 01:55 PM
I'm trying to bring up a NVMe M.2 drive on a custom board:
# lspci 00:00.0 Class 0604: 10ee:d011
Relevant boot output in dmesg:
[ 0.400658] nwl-pcie fd0e0000.pcie: Link is DOWN [ 0.405119] OF: PCI: host bridge /amba/pcie@fd0e0000 ranges: [ 0.410736] OF: PCI: MEM 0xe0000000..0xefffffff -> 0xe0000000 [ 0.416593] OF: PCI: MEM 0x600000000..0x7ffffffff -> 0x600000000 [ 0.422845] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00 [ 0.428877] pci_bus 0000:00: root bus resource [bus 00-ff] [ 0.434323] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff] [ 0.441156] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff p ref] [ 0.448610] pci 0000:00:00.0: [10ee:d011] type 01 class 0x060400 [ 0.448664] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot [ 0.448833] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
There's a active low reset line to the SSD that is high. The clock frequency in Vivado and the device tree look correct.
I'm not really sure what the best next steps are.
08-23-2018 06:55 AM - edited 08-23-2018 06:56 AM
Also worth noting we started with 2017.4 before moving to 2018.2. As a result I've been using `zynqmp-clk.dtsi` as opposed to `zynqmp-clk-ccf.dtsi` in our device tree. Switching to the CCF caused a bunch of drivers to fail to find their respective clocks (e.g. serial, ethernet, emmc). I've added the following to our device tree at least temporarily and continued to use `zynqmp-clk.dtsi`.
&pcie { status = "okay"; clocks = <&clk125>; clocks-names = "pcie_ref"; };
12-05-2018 08:35 AM
Any progress on this? Thanks!
