Nand and SDIO issue
I am working on custom zynq board, I am facing an issue when I am working with Nand Flash(Micron MT29F16G08ABABAWP) and Wi-fi(Blue giga) connected to SDIO controller. Both are working perfectly fine independently, but when I do a nand boot I get an error which prints
"mmc0: Timeout waiting for hardware interrupt", for sometime and later on it prints
"mmc0: new high speed SDIO card at address 0001".
Post the above message when I try to insert my wi-fi module then it prints the following messages
mmc0: Timeout waiting for hardware interrupt.
unifi0: retryable SDIO error reading F0 0x5
unifi0: Failed to read from UniFi (addr 0x5) after 3 tries
unifi0: SDIO error reading SDIO_INT_PENDING
unifi0: unifi_bh: state=2 T, clock=1000kHz, interrupt=0 host=1, power_save=enabled
unifi0: retryable SDIO error writing 11 to F0 0xF0
As our Nand Flash is 2GB and has a OOB of 224, I made necessary changes to the code
driver/mtd/nand/nand_base.c and the changes are
static struct nand_ecclayout nand_oob_224 = {
    .eccbytes = 104,
    .eccpos = {  2,   3,   4,   5,   6,   7,   8,
        9,  10,  11,  12,  13,  14,
        18,  19,  20,  21,  22,  23,  24,
        25,  26,  27,  28,  29,  30,
        34,  35,  36,  37,  38,  39,  40,
        41,  42,  43,  44,  45,  46,
        50,  51,  52,  53,  54,  55,  56,
        57,  58,  59,  60,  61,  62,
        66,  67,  68,  69,  70,  71,  72,
        73,  74,  75,  76,  77,  78,
        82,  83,  84,  85,  86,  87,  88,
        89,  90,  91,  92,  93,  94,
        98,  99, 100, 101, 102, 103, 104,
        105, 106, 107, 108, 109, 110,
        114, 115, 116, 117, 118, 119, 120,
        121, 122, 123, 124, 125, 126
    .oobfree = {
        {.offset = 15, .length = 3},
        {.offset = 31, .length = 3},
        {.offset = 47, .length = 3},
        {.offset = 63, .length = 3},
        {.offset = 79, .length = 3},
        {.offset = 95, .length = 3},
        {.offset = 111, .length = 3},
        {.offset = 127, .length = 97}
and the following line in the function nand_scan_tail
case 224:
         chip->ecc.layout = &nand_oob_224;
         break;
Can anyone help me with this.
Vivek
Re: Nand and SDIO issue
We have to fake out the card detect since it is also NAND CS, for this I have made changes to the sdhci_zynq_probe of
sdhci-of-xilinxps.c and the change is
u8 reg;
reg = sdhci_readb(host, SDHCI_HOST_CONTROL);
reg |= 0xC0;
sdhci_writeb(host, reg, SDHCI_HOST_CONTROL);
Vivek
