Visitor atpjpta
Need 2015.4 Zybo .bsp file for PetaLinux Workshop
Hello!
I am trying to complete the petalinux workshops found here:
http://www.xilinx.com/support/university/vivado/vivado-workshops/Vivado-embedded-linux-zynq.html#
I've installed PetaLinux SDK 2015.4 and gotten to lab 2, at which point I run into a problem. The lab references a file called "ZYBO_petalinux_v2014_2.bsp" on page 2 (step 1-2-1) which does not work for 2015.4's petalinux-build command (used in step 2-1-1). Initially, the petalinux-build command issues a warning:
"WARNING: Your PetaLinux project was last modified by PetaLinux SDK version "2014.2",
WARNING: however, you are using PetaLinux SDK version "2015.4"."
It then asks if you would like to continue anyways. After saying yes, it attempts to build the image but immediately fails with the error message:
"INFO: Checking component...
ERROR: Cannot find XLNX__3___14 of linux-kernel
INFO: Generating make files and build linux
INFO: Generating make files for the subcomponents of linux
ERROR: Failed to get subcomponents for linux
ERROR: Failed to build linux! Failed to get makefiles for subcomponents of linux!"
How can I resolve this? Or, is there a "ZYBO_petalinux_v2015_4.bsp" available anywhere that I can use to complete these tutorials?
Thank you!
Re: Need 2015.4 Zybo .bsp file for PetaLinux Workshop
I am having the same exact problem. Is there no Zybo board support package ".bsp" for the 2015.4 toolchain?
Visitor jkoller
Where did the .bsp you have come from?  I've downloaded all files and do not have any lab2 folders, nor any sources for ZYBO_petalinux_*.bsp
Visitor jkoller
I found it in the LiveUSB .zip. I already have a linux install, so never went through that documentation.
Scholar sampatd
The problem is that PetaLinux 2015.4 expects 4.0 kernel whereas PetaLinux 2014.2 uses 3.14 version of kernel
To use 3.14 kernel with PetaLinux 2015.4 tool, check if the following AR helps:
http://www.xilinx.com/support/answers/55977.html
