Observer scy86dev
Network Configuration on MicroZed messed up...HELP!
My network configuration is messed up on my microzed. As of now this is what  ifconfig points out.
root@mz7010-fmccc-2018-2:/# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:0A:35:00:1E:53
          inet addr:192.168.0.10  Bcast:0.0.0.0  Mask:255.255.255.0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:27 Base address:0xb000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1%1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
I'm a newb on networking so can someone either show me or point to a well written tutorial that will help me set this up correctly on my MicroZed. Also do I need to configure anything on my host side cause I'll probably need a tutorial or instructions on that too.
~S
Re: Network Configuration on MicroZed messed up...HELP!
Hi @scy86dev
Are you looking for something like this: link
Edit: It looks however like you're not connected to a network, You can expect  some RX and TX activity. Did you setup the ipv4 address yourself?
I also found  this for you..
Deville
