Network Interface file Petalinux 2017.1
Hi!
In my application I need to set Ethernet IP address, so how to change interface file in /etc/network/ ?
In Petalinux 2016.4 it was possible to do it by putting an init-ifupdown folder (with bbappend and interface files in it) in recipes-core, but now I have that warning during petalinux-build:
WARNING: The init-ifupdown:do_fetch sig is computed to be 9671e7c4bf8d4e1a44c5a67f6fc60442, but the sig is locked to 9a10549c7af85144d164d9728e8fe23f in SIGGEN_LOCKEDSIGS_t-cortexa9hf-neon
After, checking, I see that interface file is still the default one in the embedded linux.
File wich can be find in Petalinux 2017.1 install director:
(install path petalinux-v2017.1-final)/components/yocto/source/arm/layers/core/meta/recipes-core/init-ifupdown/init-ifupdown-1.0/interfaces
Re: Network Interface file Petalinux 2017.1
hi,
   you may setting the wrong ethernet phy address,try set it to 0 at your devicetree.(other part of the devicetree may different from your‘s,it's just an example)
eg:
                phy@0 {
                compatible = "marvell,88e1510";
                device_type = "ethernet-phy";
                reg = <0x0>;   // phy addr
                marvell,reg-init = <0x3 0x10 0xff00 0x1e 0x3 0x11 0xfff0 0xa>;
BRs,
In fact Network do not work at all in my configuration with a Zynq MMP board (with petalinux 2016.4, i don't have that issue).
There's a wrong address for the Phy and it can not be detected by the Ethernet MAC.
The messages at the beginning of the u-boot process show the issue
If someone from Xilinx have an idea.
Thank you.
hi,
eg:
                phy@0 {
BRs,
Thanks again.
