Visitor akzare
Network problem with Linux version 2.6.29-rc5
Hi everybody,
I am trying to boot up our designed hardware platform (PICSY) based on Virtex 4 FX20 with the open source Linux project from Xilinx. For your information, I am using 2.6.28-rc6 and 2.6.29-rc5 versions from GIT. In XPS project I have used xlnx,xps-ethernetlite-2.00.b, but inside the virtex405-ml405.dts, I changed the compatible = "xlnx,xps-ethernetlite-2.00.b"; to compatible = "xlnx,xps-ethernetlite-2.00.a"; (because of lack of device driver in Kernel). As far as I use
version 2.6.28-rc6, everything is cool and whenever I ping it, packet loss is 0%!
 zImage starting: loaded at 0x00400000 (sp: 0x006d8eb0)
 Allocating 0x30961d bytes for kernel ...
 gunzipping (0x00000000 <- 0x0040c000:0x005675aa)...done 0x2e9e44 bytes
 Attached initrd image at 0x00568000-0x006d7f20
 initrd head: 0x1f8b0808
 Linux/PowerPC load: console=ttyUL0 root=/dev/ram rw
 Finalizing device tree... flat tree at 0x6e5300
 Using Xilinx Virtex machine description
Linux version 2.6.28-rc6 (mmetzner@ariadne) (gcc version 4.2.2) #14 PREEMPT Fri Feb 6 12:03:37 CET 2009
Found initrd at 0xc0568000:0xc06d7f20
Zone PFN ranges:
  DMA      0x00000000 -> 0x00008000
  Normal   0x00008000 -> 0x00008000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0: 0x00000000 -> 0x00008000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: console=ttyUL0 root=/dev/ram rw
Xilinx intc at 0x81800000 mapped to 0xfdfff000
PID hash table entries: 512 (order: 9, 2048 bytes)
clocksource: timebase mult[d55555] shift[22] registered
Console: colour dummy device 80x25
console [ttyUL0] enabled
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 125180k/131072k available (2824k kernel code, 5736k reserved, 132k data, 125k bss, 148k init)
Calibrating delay loop... 598.01 BogoMIPS (lpj=1196032)
Mount-cache hash table entries: 512
net_namespace: 636 bytes
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 1471k freed
msgmni has been set to 247
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered
Serial: 8250/16550 driver4 ports, IRQ sharing disabled
84000000.serial: ttyUL0 at MMIO 0x84000003 (irq = 16) is a uartlite
brd: module loaded
loop: module loaded
nbd: registered device at major 43
xilinx_emaclite 81000000.ethernet: Device Tree Probing 'ethernet'
xilinx_emaclite 81000000.ethernet: MAC address is now  2: 0: 0: 0: 0: 0
xilinx_emaclite 81000000.ethernet: using fifo mode.
xilinx_emaclite 81000000.ethernet: Xilinx EMACLite at 0x81000000 mapped to 0xC9020000, irq=17
Linux video capture interface: v2.00
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
TCP cubic registered
RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem).
Freeing unused kernel memory: 148k init
### Application running ...
root:~> ifconfig -a eth0 141.89.52.137 netmask 255.255.255.0 up
root:~> route add default gw 141.89.52.254
root:~> ping 141.89.52.43
PING 141.89.52.43 (141.89.52.43): 56 data bytes
64 bytes from 141.89.52.43: icmp_seq=0 ttl=64 time=561.0 ms
64 bytes from 141.89.52.43: icmp_seq=1 ttl=64 time=0.8 ms
64 bytes from 141.89.52.43: icmp_seq=2 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=3 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=4 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=5 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=6 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=7 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=8 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=9 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=10 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=11 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=12 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=13 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=14 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=15 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=16 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=17 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=18 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=19 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=20 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=21 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=22 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=23 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=24 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=25 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=26 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=27 ttl=64 time=0.7 ms
^C
--- 141.89.52.43 ping statistics ---
28 packets transmitted, 28 packets received, 0% packet loss
round-trip min/avg/max = 0.7/20.7/561.0 ms
root:~>
Unfortunately, when I use  2.6.29-rc5 version, the network is not stable and normally I face huge amount of packet loss.
 zImage starting: loaded at 0x00400000 (sp: 0x006e1eb0)
 Allocating 0x319901 bytes for kernel ...
 gunzipping (0x00000000 <- 0x0040c000:0x00570580)...done 0x2fdd48 bytes
 Attached initrd image at 0x00571000-0x006e0f20
 Finalizing device tree... flat tree at 0x6ee300
Linux version 2.6.29-rc5 (akzare@orest) (gcc version 4.2.2) #9 PREEMPT Thu Mar 12 19:11:18 CET 2009
Found initrd at 0xc0571000:0xc06e0f20
Zone PFN ranges:
MMU: Allocated 1088 bytes of context maps for 255 contexts
Memory: 125124k/131072k available (2900k kernel code, 5800k reserved, 136k data, 110k bss, 148k init)
net_namespace: 880 bytes
bio: create slab <bio-0> at 0
TCP reno registered
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
brd: module loaded
loop: module loaded
eth0 (): not using net_device_ops yet
VFS: Mounted root (ext2 filesystem) on device 1:0.
64 bytes from 141.89.52.43: icmp_seq=37 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=38 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=39 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=41 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=42 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=43 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=44 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=46 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=48 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=50 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=52 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=79 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=81 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=83 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=85 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=87 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=89 ttl=64 time=0.7 ms
64 bytes from 141.89.52.43: icmp_seq=91 ttl=64 time=0.7 ms
^C
92 packets transmitted, 18 packets received, 80% packet loss
round-trip min/avg/max = 0.7/0.7/0.7 ms
root:~>
I discovered the only difference in the boot up log is "eth0 (): not using net_device_ops yet".  As I took a look at internet, maybe it is because the linux network section uses net_device_ops, and it only works with network drivers that publish their device operations trough net_device_ops.
I would be grateful, if somebody gives me nice and perfect hints to get rid of this bothering problem. I have stoped several days cause of this huge packet loss.
Cheers,
Ali
Re: Network problem with Linux version 2.6.29-rc5
Hi Ali,
For now I would say use the old version until this is looked into more.
We don't really support EMAC lite thru the Git tree as our standard testing is with the LL TEMAC.  I realize it's confusing for it to be in the tree when we don't support it well.
I have watch for this as I do some Emac Lite work but it's definitely not main stream as there's not too much demand.
It sounds like something changed in the kernel as I don't think the driver has changed.
John
Has'nt this been solved yet? I have encountered this problem too. I need ethernetlite because I don't have enough space. Should I go back to2.6.28?
And what if I need 2.6.29 for xps_ll_temac FIFO mode in another project?
Message Edited by sajjadi on 05-04-2009 12:34 AM
2.6.29 has some network issues, I would say to stay at 2.6.28 for EmacLite for now.
When we update the tree to 2.6.30 the problems should be fixed as they are not our problems, but problems in the mainline tree.
John
Participant qvbsx
Hello,Ali
how do you make it to configure your IP addr,?
when I try to configure my IP by using the command:
#ifconfig -a eth0 141.89.52.137 netmask 255.255.255.0 up
then ,it turn out to be:
ifconfig: SIOCSIFADDR: No such device
the following are the booting pro:
Using Xilinx Virtex440 machine description
root@localhost.localdomain) (gcc version 4.2.2) #16 PR
EEMPT Fri Apr 3 21:51:22 CST 2009
Zone PFN ranges:
  DMA      0x00000000 -> 0x00010000
  Normal   0x00010000 -> 0x00010000
    0: 0x00000000 -> 0x00010000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: console=ttyS0 root=/dev/xsa2 rw init=/sbin/init
PID hash table entries: 1024 (order: 10,
00:00:33:692 sec: 5
       32 kB
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) No HW ID - assumi
00:00:
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
FLASH: 32 MB
00:00:33:693 sec: 5ing
Memory: 256128k/262144k available (3264k kernel code, 5856k reserved, 128k data,
00:00:33:694 sec: 5
MAC add
00:00:33:69
 134k bss, 168k init)
00:
00:00:33:694 sec: 5
Out:   s
00:00:33:695 s
net_namespace: 880 bytes00:00:33:695 sec: 5ddr 1
00:00:33:696 fatal
PCI: Probing PCI hardwares: Connecti
io scheduler cfq registered (default)es: 1024 (order: 10, 4096 bytes)ho ar
era
83e00000.serial: ttyS0 at MMIO 0x83e01003 (irq = 16) is a 16550Afilesystem
console [ttyS0] enabled
Con
brd: module loadeddevice 80x25load -
loop: module loadedom a dos
xsysace 83600000.sysace: Xilinx SystemACE revision 1.0.12flinfo  - print FLASH memory information
xsysace 83600000.sysace: capacity: 1000944 sectorsilable (3264k kernel code, 5856k reserved, 128k da
 xsa: xsa1 xsa2
Xilinx SystemACE device driver, major=254
getidcr - Get a register value
TCP cubic registereds: 512
NET: Registered protocol family 17cks
net_namespace:
RPC: Registered udp transport module.o
PCI: Probing PCI hardwarery display
kjournald starting.  Commit interval 5 seconds slab <bio-0> at 0header information for appli
EXT3-fs warning: mounting unchecked fs, running e2fsck is
recommendedb@0/gpio@81460000: registered
EXT3 FS on xsa2, internal journal@0/gpio@81400000:
Starting system...
mounting /proc:
done.
brining up loopback interface:
done.
Mounting /tmp:
done.
Starting syslogd:
done.
Starting klogd:
done.
Starting inetd:
done.
Seting env
done
Start dbus-daemon
unix:path=/opt/crosslib/dbus4ppc/var/run/dbus/system_bus_socket,guid=8671cb49436
fc99ba695ce4900000005
791
done
Starting shell
# ifconfig -a eth0 141.89.52.137 netmask 255.255.255.0 up
so,Is anything missing in my system and what is wrong?
--Bingle
It looks like you don't have the driver in your kernel configuration or you don't have the device in the device tree for the system to find at boot.  You should see console messages indicating it found the device and initialized the driver like you see early in this thread.
-- John
I downloaded the snapshot tagged 2.6.28, but it didn't include xilinx net drivers. What snapshot should I use?
Sorry for the slow response here.  You need the tag xilinx_v2.6.28 to get our stuff also.
-- John
Thanks john
In the meanwhile I managed to get my linux up and running using 2.6.28 -rc5 and buildroot. Everything seemed to work fine in the kernel, till I ran some applications.
I can ping the board and vice versa. Also I have used tftp and run a simple client program to connect to my pc.
But when I want to connect to the board as a server, ARPs aren't answered. I have tested it with telnet (running telnetd) and another application of mine. Don't know if this is to be asked here or not, but I'm really confused!
S. M. Sajjadi
I found the error. In fact arp wasn't working at all. Pings I had tested where done after a ping from the board. The problem was reported here and solved.
Thanks and sorry.
Visitor milindur
-- John
Where can I find this tag? On git.xilinx.com I do not see this.
What is the status of emaclite in 2.6.29? I am trying to build a XUPV2P system with Linux 2.6.29, the emaclite device is found, but I am unable to ping (to/from the board) or mount a nfs-rootfs.
Thanks in advance,
Christian
The tag is in the git tree such that you can reset the tree to that tag or pull based on that tag.  Using tags is pretty simple in git but I don't do it a lot so i usually don't remember and have to look it up.
My fault, now I see I forgot to push the tags public, they are not there, sorry for that.
I would not use 2.6.29, but I would use 2.6.28.  I saw a network issue with Emaclite in 2.6.29 that was related to brokenness in the kernel, not the driver.
-- John
I wasn't very clear, I now pushed the tags public.
-- John
Visitor milindur
-- John
Thank you very much for pushing the tags and your advice regarding 2.6.28, we will try this.
Christian
