Visitor miner_tom
New to Petalinux. Where are opencv.c source files?
I have downloaded the petalinux sources and the associated petalinux installer and the SDK. Things seem to be working fine.
I was looking for opencv files since I know that opencv version 1 is in the distribution. And I do find lots of files related to opencv but not the c source files.
./tools/hsm/data/embeddedsw/ThirdParty/opencv
./tools/hsm/data/embeddedsw/ThirdParty/opencv/aarch32/include/opencv
./tools/hsm/data/embeddedsw/ThirdParty/opencv/aarch64/include/opencv
./components/yocto/source/microblaze_full/layers/meta-petalinux/recipes-support/opencv
./components/yocto/source/microblaze_full/layers/meta-openembedded/meta-oe/recipes-support/opencv
./components/yocto/source/microblaze_full/layers/meta-openembedded/meta-oe/recipes-support/opencv/opencv
./components/yocto/source/aarch64/layers/meta-petalinux/recipes-support/opencv
./components/yocto/source/aarch64/layers/meta-openembedded/meta-oe/recipes-support/opencv
./components/yocto/source/aarch64/layers/meta-openembedded/meta-oe/recipes-support/opencv/opencv
./components/yocto/source/microblaze_lite/layers/meta-petalinux/recipes-support/opencv
./components/yocto/source/microblaze_lite/layers/meta-openembedded/meta-oe/recipes-support/opencv
./components/yocto/source/microblaze_lite/layers/meta-openembedded/meta-oe/recipes-support/opencv/opencv
./components/yocto/source/arm/layers/meta-petalinux/recipes-support/opencv
./components/yocto/source/arm/layers/meta-openembedded/meta-oe/recipes-support/opencv
./components/yocto/source/arm/layers/meta-openembedded/meta-oe/recipes-support/opencv/opencv
I'm really looking to update the distribution from opencv_1 to opencv_2, but I would expect to have to, at a start, substitute and compile the new sources into the distribution. What do I miss?
Thank You
Tom
Tags (3)
Re: New to Petalinux. Where are opencv.c source files?
Hi Tom
You will not find the sources instead you will find github links which gets fetched while building petalinux
/meta-openembedded/meta-oe/recipes-support/opencv/opencv_3.4.3.bb
You can find SRC_URI that actaually points to github links of opencv source
Hi Tom
Visitor miner_tom
Great! Thank you.
Tom
