No Internet Connection will PetaLinux still work?
Hello, on my work connection I do not have an Internet connection are there instructions on how to get PetaLinux working? What other options do I have when there is no internet connection?
Thank you
Hi @joe306,
The compatible Ubuntu version for a petalinux is based on which version of the petalinux you are using.
You can refer to UG1144, it will clear all your queries.
In UG1144 chapter 2 is about the installation of petalinux.
The below link is petalinux 2019.2 UG.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug1144-petalinux-tools-reference-guide.pdf
Shubhangi
Hi @joe306
Refer to UG1144 ---> Local Mirror Servers
Reference Steps:
1. Download and unpack sstate-cache and downloads repo from xilinx.com
2. Source Mirrors
petalinux-config -> Yocto-settings -> Add pre-mirror URL. file:///<sstate path>/downloads
3. de-select petalinux-config -> Yocto Settings -> Enable Network sstate feeds
4. Select petalinux-config ---> Yocto Settings ---> [*] Enable BB NO NETWORK
5. Sstate Feeds
petalinux-config -> Yocto Settings -> Local sstate feeds settings and enter the full path of the sstate directory
Some issue records,
https://www.xilinx.com/support/answers/71240.html
https://www.xilinx.com/support/answers/71198.html
https://www.xilinx.com/support/answers/71381.html
Hope it helps~
Don't forget to "Accept as solution" or "Kudo" if it helps. Thanks!
Hello and thank you for responding to my message. I will give it a try. Joe
Hello, what version of Ubuntu should I use?
Hi @joe306,
Shubhangi
Thank you
