Observer dsatyamu
No PetaLinux projects found in the BSP
INFO: Create project: project
ERROR: No PetaLinux projects found in the BSP /home/<USERNAME>/bsp_path!
This command creates a new PetaLinux Project or component
Usage:
  petalinux-create [options] <-t|--type <TYPE> <-n|--name <COMPONENT_NAME>
Required:
  -t, --type <TYPE>                     Available type:
                                          * project : PetaLinux project
                                          * apps    : Linux user application
                                          * modules : Linux user module
  -n, --name <COMPONENT_NAME>           specify a name for the component or
                                        project. It is OPTIONAL to create a
                                        PROJECT. If you specify source BSP when
                                        you create a project, you are not
                                        required to specify the name.
Options:
  -p, --project <PROJECT>               specify full path to a PetaLinux project
                                        this option is NOT USED for PROJECT CREATION.
                                        default is the working project.
  --force                               force overwriting an existing component
                                        directory.
  -h, --help                            show function usage
  --enable                              this option applies to all types except
                                        project.
                                        enable the created component
Options for project:
  --template <TEMPLATE>                 zynqMP|zynq|microblaze
                                        user needs specify which template to use.
  -s|--source <SOURCE>                  specify a PetaLinux BSP as a project
                                        source.
EXAMPLES:
Create project from PetaLinux Project BSP:
  $ petalinux-create -t project -s <PATH_TO_PETALINUX_PROJECT_BSP>
Create project from template:
  $ petalinux-create -t project -n <PROJECT> --template zynq
Can someone please tell me what do I need to do to proceed further?
I tried the methods given in these threads already:
https://forums.xilinx.com/t5/Embedded-Linux/No-PetaLinux-projects-found-in-the-BSP/m-p/416335#M7927
https://forums.xilinx.com/t5/Embedded-Linux/PetaLinux-2017-4-ZC706-BSP-No-projects-found-in-BSP/m-p/824426/highlight/true#M23798
Thanks and Regards
-Darshan
Re: No PetaLinux projects found in the BSP
So the command should be
petalinux-create -t project -s <bsp name>.bsp
what is your command, and error?
Which bsp are you using and what is the command you used to create the petalinux project?
Observer dsatyamu
petalinux-create -t project -s <path-to-bsp>
This is the step I am taking.
Please letme know if this is wrong?
Thanks and Regards
-Darshan
And what bsp are you using?
Observer dsatyamu
Hi Darshan,
Could you please copy the complete command followed by the errors you are seeing when you create the project using bsp?
Observer dsatyamu
Thanks I wasn't giving the bsp. I was just giving the full path. Now it works.
