rjlu
No device tree found after petalinux-config with petalinux 2017.2
Now I try to update from 2015.4 to 2017.2, but the two version are quite different and has to learn from scratch. At the first step, a new project is created, and then using petalinux-config --get-hw-description=/home/ma/dt_test/dt_test.sdk to import hardware definition exported by vivado 2017.2. Then no device tree is found under ./component/plnx_workspace, the directory is empty!!
No error is watched during the process. If issuing petalinux-config -c device tree, or petalinux-build, then device tree and fsbl subdirectroy can be seen under ./component/plnx_workspace.
Is there any thing wrong or is it the new feature of petalinux 2017.2??
ma@ma:~/Z7_project/z7dttest$ petalinux-config --get-hw-description=/home/ma/dt_test/dt_test.sdkINFO: Getting hardware description...
INFO: Rename dttest_wrapper.hdf to system.hdf
[INFO] generating Kconfig for project
[INFO] menuconfig project
/home/ma/Z7_project/z7dttest/build/misc/config/Kconfig.syshw:30:warning: defaults for choice values not supported
/home/ma/Z7_project/z7dttest/build/misc/config/Kconfig:574:warning: config symbol defined without type
configuration written to /home/ma/Z7_project/z7dttest/project-spec/configs/config
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
[INFO] sourcing bitbake
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
~/Z7_project/z7dttest/build/misc/plnx-generated ~/Z7_project/z7dttest
[INFO] generating machine configuration
[INFO] generating bbappends for project . This may take time !
[INFO] generating u-boot configuration files
[INFO] generating kernel configuration files
[INFO] generating kconfig for Rootfs
Generate rootfs kconfig
[INFO] oldconfig rootfs
[INFO] generating petalinux-user-image.bb
shabbirk
This is expected in 2017.2, as in this version, the files which are created in components/plnx_workspace/ are autogenerated, unlike 2015.* versions
Best Regards
Shabbir
