eloff
No ethernet connectivity with Petalinux 2015.2.1 on Zync zc706
After upgrading from Petalinux 2014.4 to 2015.2.1 there is no ethernet connectivity.
There are some ethernet related changes in the update, for example the driver has changed to macb.
I have the following in my system-top.dts:
&gem0 {
	status = "okay";
	phy-mode = "rgmii-id";
	phy-handle = <&ethernet_phy>;
	ethernet_phy: ethernet-phy@7 {
		compatible="marvell,88e1116r";
		device_type="ethernet-phy";
		reg = <7>;
// zynq-7000.dtsi
gem0: ethernet@e000b000 { compatible = "cdns,gem"; reg = <0xe000b000 0x1000>; status = "disabled"; interrupts = <0 22 4>; clocks = <&clkc 30>, <&clkc 30>, <&clkc 13>; clock-names = "pclk", "hclk", "tx_clk"; #address-cells = <1>; #size-cells = <0>; };
Linux is able to find the eth0 interface and I can configure it with static ip. However, it is not possible to ping, in either direction.
LED0 on the board blinks when trying to ping from PC. There is no activity when trying to ping from petalinux.
Any idea how to get the ethernet working?
Related links:
http://www.xilinx.com/support/answers/65282.html (PetaLinux 2015.2 - Device Tree Does Not Load The Proper Drivers for USB or Ethernet, should be solved in 2015.2.1)
http://www.xilinx.com/support/answers/61117.html (PetaLinux - My System Device Tree DTS Does Not Include Ethernet PHY Information)
https://forums.xilinx.com/t5/Embedded-Linux/xemacps-e000b000-ps7-ethernet-eth0-no-PHY-setup/td-p/499018 (xemacps e000b000.ps7-ethernet: eth0: no PHY setup)
eloff
It turned out that, for some reason, mdio was not enabled for eth0 in my system.hdf. So there was no connection to the actual pins, oops. The FPGA developer fixed this and now ethernet connectivity works again.
fanat9
Try to set Phy reg to 0.
phy0: phy@0 {
	#size-cells = <0>;
	compatible = "marvell,88e1116r";
	device_type = "ethernet-phy";
	reg = <0>;
linnj
I've not tried it myself but here's how I'd go about figuring it out.  I tend to look at the device tree for the release on github that is used for the Linux kernel independent of Petalinux.
https://github.com/Xilinx/linux-xlnx/blob/xilinx-v2015.2.03/arch/arm/boot/dts/zynq-zc706.dts
This is what is shows for they phy (it pasted in wierd).
I can't see why you would want to change the PHY address, but maybe I'm missing sommething there. That should be hard wired on the board and should never change.
John
  &gem0 {
  status = "okay";
  reg = <7>;
linnj
http://www.xilinx.com/support/answers/65504.html
And I forgot about this answer record also.
eloff
