No ethernet in Petalinux 2016.4
Running on a Zynq ZC702. When I boot Petalinux I get the following. I've highlighted what I think are the ethernet relevant lines, there may be more. I try to ping the loopback address and it fails.
I'm new to PetaLinux/Yocto.
This is my sytem-top.dts. For gem0 I've tried using phy register values of 0 ,1, and 7. I'm not really sure which it should be and how I should be able to tell, so any tips would be appreciated.
/dts-v1/;
/include/ "system-conf.dtsi"
    aliases {
    serial0 = "/amba/serial@e0001000";
    serial1 = "/amba/serial@e0000000";
    ethernet0 = "/amba/ethernet@e000b000";
    ethernet1 = "/amba/ethernet@e000c000";
    spi0 = "/amba_pl/axi_quad_spi@40000000";
    &gem0 {
      phy-handle = <&phy0>;
      mdio {
       #address-cells = <1>;
       #size-cells = <0>;
       phy0: phy@7 {
        compatible = "marvell,88e1116r";
        device_type = "ethernet-phy";
        reg = <7>;
... TIMEOUT !
ZYNQ GEM: e000c000, phyaddr -1, interface rgmii-id
mdio_register: non unique device name 'gem'
Hit any key to stop autoboot:  0
Device: sdhci@e0100000
Manufacturer ID: 28
OEM: 4245
Name:
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.5 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
105195520 bytes read in 8723 ms (11.5 MiB/s)
   Using 'conf@1' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel@0' kernel subimage
     Description:  Linux Kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x100000d4
     Data Size:    3560440 Bytes = 3.4 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00008000
     Entry Point:  0x00008000
     Hash algo:    sha1
     Hash value:   56be8a4850ae2406b268ee97aba0502610d0cff4
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk@0' ramdisk subimage
     Description:  ramdisk
     Type:         RAMDisk Image
     Data Start:   0x10369180
     Data Size:    101618320 Bytes = 96.9 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   3ba053c4dea160747b691d8eca86ee924ad562ef
   Trying 'fdt@0' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x103655c0
     Data Size:    15118 Bytes = 14.8 KiB
     Architecture: ARM
     Hash algo:    sha1
     Hash value:   4cd5f5d16aac985bad29b322053802c12a57ae0c
   Booting using the fdt blob at 0x103655c0
   Loading Kernel Image ... OK
   Loading Ramdisk to 01f16000, end 07fff290 ... OK
   Loading Device Tree to 01f0f000, end 01f15b0d ... OK
Starting kernel ...
Linux version 4.6.0-xilinx (instron@localhost.localdomain) (gcc version 5.2.1 20151005 (Linaro GCC 5.2-2015.11-2) ) #1 SMP PREEMPT Wed Jul 5 11:32:46 EDT 2017
Machine model: Ave2_peta
cma: Reserved 16 MiB at 0x3f000000
Memory policy: Data cache writealloc
percpu: Embedded 12 pages/cpu @ef7d3000 s19776 r8192 d21184 u49152
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260608
Kernel command line:
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 915136K/1048576K available (5276K kernel code, 204K rwdata, 1672K rodata, 1024K init, 218K bss, 117056K reserved, 16384K cma-reserved, 245760K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc07c93b8   (7941 kB)
      .init : 0xc0800000 - 0xc0900000   (1024 kB)
      .data : 0xc0900000 - 0xc0933360   ( 205 kB)
       .bss : 0xc0933360 - 0xc0969f24   ( 219 kB)
        Build-time adjustment of leaf fanout to 32.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
efuse mapped to f0800000
slcr mapped to f0802000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at f0802100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at f080a000, irq=17
console [tty0] enabled
Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Setting up static identity map for 0x100000 - 0x100058
Brought up 2 CPUs
SMP: Total of 2 processors activated (1333.33 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xf0880000
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
vgaarb: loaded
SCSI subsystem initialized
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Freeing initrd memory: 99240K (c1f16000 - c8000000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=28 max_order=18 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
bounce: pool size: 64 pages
io scheduler noop registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac:        DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xilinx-vdma 40004000.dma: unable to request IRQ 0
xilinx-vdma 40004000.dma: Xilinx AXI VDMA Engine Driver Probed!!
e0000000.serial: ttyPS1 at MMIO 0xe0000000 (irq = 144, base_baud = 3125000) is a xuartps
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 145, base_baud = 3125000) is a xuartps
console [ttyPS0] enabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to f0872000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
m25p80 spi0.0: SPI transfer timed out
m25p80 spi0.0: error -110 reading 9f
m25p80: probe of spi0.0 failed with error -110
CAN device driver interface
gpiod_set_value: invalid GPIO
libphy: MACB_mii_bus: probed
mdio_bus e000b000.etherne:07: mdio_device_register
macb e000b000.ethernet eth0: no PHY found
macb e000c000.ethernet: invalid hw address, using random
macb e000c000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000c000 irq 148 (4e:70:fc:bd:6a:b2)
Generic PHY e000c000.etherne:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=e000c000.etherne:00, irq=-1)
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
cdns-i2c e0005000.i2c: 400 kHz mmio e0005000 irq 141
EDAC MC: ECC not enabled
Xilinx Zynq CpuIdle Driver started
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using DMA
ledtrig-cpu: registered to indicate activity on CPUs
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
hctosys: unable to open rtc device (rtc0)
mmc0: new high speed SDHC card at address b368
ALSA device list:
  No soundcards found.
mmcblk0: mmc0:b368       7.46 GiB
 mmcblk0: p1
Freeing unused kernel memory: 1024K (c0800000 - c0900000)
INIT: version 2.88 booting
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
random: dd urandom read with 2 bits of entropy available
Wed Jul  5 23:38:02 UTC 2017
Starting internet superserver: inetd.
INIT: Entering runlevel: 5
Configuring network interfaces... IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
done.
Starting system message bus: dbus.
Starting Dropbear SSH server: Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDHeIMKMjXCTid8wUlu1Xvq+BiHXxJvuehfXj3olOuSZA8+a2sY2bsj5saNZk0mKWhM6KsvTgqHj/FdmIItnyj1Mab5VOY2zrkzXt9RXFL3YvE8TYitIcNn+FJr2UBi7mBdW2yCgfXHQS5A2GoVRq6gKUFI/DLzEAOsCiwubP7X3aGXmsriBQ58M2dC4Mn3IqiBa3IRNchIuBppoYghHvc1rZZvBDLETTmRmu9J/cYjVzyyJNm2VeUsJrJk4dc2AbS6SljhQLX3C06rLSIkpf6TenXkzdSq9Fai2KulIjFbA5myVr9vJkBHbsjbNGrqaO6McINKsTufOTFeO3xPfhCL root@plnx_arm
Fingerprint: md5 7e:19:7e:10:95:a0:a2:e1:14:d4:42:18:c3:24:45:79
dropbear.
Starting syslogd/klogd: done
PetaLinux 2016.4 plnx_arm /dev/ttyPS0
plnx_arm login:
Re: No ethernet in Petalinux 2016.4
Thank you for the reply. I tried your suggestion but got the same result. In addition to my custom board which I am attempting to get working I have a Zynq eval board. I used the prebuilt Xilinx image for that board and verified that the ethernet does work. The board uses a Marvel Phy, same as my custom board. I copied the settings from the downloaded system-top.dts and things got better.
My new system-top.dts, I added the &gem1 disabled setting. I can see that the Marvel PHY driver is being used which is good, but I still get the eth0: link is not ready message, and it looks like my irq=-1. Thanks for any help.
/dts-v1/;
    aliases {
&gem0 {
    ps7_ethernet_0_mdio: mdio {
        #size-cells = <0>;
        phy0: phy@7 {
            reg = <7>;
&gem1{
 status = "disabled";
........ TIMEOUT !
Manufacturer ID: 28
OEM: 4245
Name:
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.5 GiB
Bus Width: 4-bit
reading image.ub
105325344 bytes read in 8735 ms (11.5 MiB/s)
     Type:         Kernel Image
     Architecture: ARM
     OS:           Linux
     Hash algo:    sha1
     Type:         RAMDisk Image
     Data Start:   0x10369164
     Data Size:    101748171 Bytes = 97 MiB
     Architecture: ARM
     OS:           Linux
     Hash algo:    sha1
     Hash value:   05312b41d2df49915514531e9b861f40cdad99d0
     Data Size:    15090 Bytes = 14.7 KiB
     Architecture: ARM
     Hash algo:    sha1
     Hash value:   6b6ee17ef43c8ecc0452dcc491b6cfae572828b4
   Loading Ramdisk to 01ef7000, end 07fffdcb ... OK
   Loading Device Tree to 01ef0000, end 01ef6af1 ... OK
Starting kernel ...
Memory: 915012K/1048576K available (5276K kernel code, 204K rwdata, 1672K rodata, 1024K init, 218K bss, 117180K reserved, 16384K cma-reserved, 245760K highmem)
Zynq clock init
Brought up 2 CPUs
vgaarb: loaded
EDAC MC: Ver: 3.0.0
Freeing initrd memory: 99364K (c1ef7000 - c8000000)
brd: module loaded
loop: module loaded
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 147 (00:0a:35:00:1e:53)
Marvell 88E1116R e000b000.etherne:07: attached PHY driver [Marvell 88E1116R] (mii_bus:phy_addr=e000b000.etherne:07, irq=-1)
ALSA device list:
INIT: mmcblk0: mmc0:b368       7.46 GiB
 mmcblk0: p1
Thu Jul  6 17:22:05 UTC 2017
done.
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCDXDgRVrbX6Nueu0LFtqBMTuhNNNLVbGEqRDj+ZNsgqo5oPcKtZgGKQDe9zPGx0H3GLGS1Pu0/h7S6A5NNmnKedFirQZPMOvdoIMFGQ3GzZ1pRSZGDcdEdaKssP0hyFwctpUrf2prCZlewGgIOXercFpRuM6yx7Ux9aJnacRKThXsnTA+Bhkj1K8SJt4BZkfq19O/fg5kZHV58eLidzf8wNOwn+D7AJji+KcVVX3Z65/UVcKMiVd874JLme84H+I5mYHQWPDUKCynMLjvhslvqvVWQIiyJjsH9/HBWyMvkBjX0FYpToopYvtFBZPCX9udJ8/OD8MbqihCiFo+tYQzR root@plnx_arm
Fingerprint: md5 be:91:76:14:3f:01:2a:eb:43:9f:30:38:32:e1:73:7c
dropbear.
plnx_arm login: root
Password:
root@plnx_arm:~# ping 127.0.0.1
PING 127.0.0.1 (127.0.0.1): 56 data bytes
the phy node in your device tree doesn't need to go under the mdio node.
try this:
&gem0 {
       phy0: phy@7 {
        reg = <7>;
you can try also to add:
        mdio {
              status = "disable";
Rocco
/dts-v1/;
    aliases {
&gem0 {
        #size-cells = <0>;
        phy0: phy@7 {
            reg = <7>;
&gem1{
........ TIMEOUT !
Manufacturer ID: 28
OEM: 4245
Name:
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.5 GiB
Bus Width: 4-bit
reading image.ub
     Type:         Kernel Image
     Architecture: ARM
     OS:           Linux
     Hash algo:    sha1
     Type:         RAMDisk Image
     Architecture: ARM
     OS:           Linux
     Hash algo:    sha1
     Architecture: ARM
     Hash algo:    sha1
Starting kernel ...
Zynq clock init
Brought up 2 CPUs
vgaarb: loaded
EDAC MC: Ver: 3.0.0
brd: module loaded
loop: module loaded
ALSA device list:
 mmcblk0: p1
done.
dropbear.
Password:
These dts settings did the trick.
